Old 08-20-2012, 10:39 AM   #5416
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by speedmonkey7 View Post
Hey all, my front brake caliper on my 96 XR6 recently started sticking pretty bad (not releasing). I was looking at either a caliper rebuild kit for $30 or so, or a caliper off a 2003 650l for $45 off of fleabag. They say their caliper is in good working order and it looks clean. Which way would you guys go?
replace seals man,
youre just going to get a replacement caliper with equally bad seals
easy to do
push pistons out, replace 2 seals in each piston, clean the pistons with a rag, use a qtip to clean the inside if the calipers, and if you feel like it you can polish up the insides
bleed caliper
bam, brand new
elsalvadorklr is offline   Reply With Quote
Old 08-20-2012, 10:45 AM   #5417
boomshakalaka
Oddometer: 143
Originally Posted by elsalvadorklr View Post
too bad im in el salvador
have some nice 98 rebuilt forks with new seals, cut(stiff) springs, axle, even a new excel wheel and buchanan spokes... all complete
ask steve, he has it all
ha, you were the first person I thought of, since you just did your USD swap. I actually deleted my post, because I think it may have been a bit premature. Ive been told that there is a strong chance that the forks may just bet twisted in the clamps, and just need to be fiddled with. Ive never delt with something like this before, so I just figured that if the bars arent the problem (brand new renthals), and the front end is still wonky, then it must be bent forks.
boomshakalaka is offline   Reply With Quote
Old 08-20-2012, 10:57 AM   #5418
elsalvadorklr
southern xr rider
Oddometer: 4,154
oh though you checked that already
well in that case take fors off bike, remove springs, then cycle tubes up and down inside the sliders, if one or both sliders/tubes dont fully compress or slide allllllll the way down you have a bent tube
I know because one of my 88 original forks is bent
these are the forks that got hit during my accident when hit by a car
one tube will not go all the way down into the fork lower
you can also check by dissassembling the forks completely and roll them on a flat surface old school style
in any case
it might be as simple as relase pinch bolts on fork clamps and whack the wheel against a tree or use youre knees and realign
simple really
let us know how it goes also there is a method to retightening torquing the front end
where to start fist and all
it can be a bit argumentatitve on which method is best...jajajaja
like an oil war of sorts
p.s. I am back in business with a new laptop thanks to the wife, geeeeeeze!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! missed you guys....jajaja like for a week! jajajajajaja
Old 08-20-2012, 12:10 PM   #5419
kirbi69
Oddometer: 219
i was about to send the search and recue party after you christian!!!
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Old 08-20-2012, 12:41 PM   #5420
elsalvadorklr
southern xr rider
Oddometer: 4,154
jajajaja
you do know that posting on here keeps me sane do you? jajajajaa
I think Im not the only one...too
jajajajaajaja
cheers
now, if I could only get my new pg down here, should be soon and maybe I can start riding again
Old 08-20-2012, 12:43 PM   #5421
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,706
Originally Posted by nonfatwater7 View Post
Hey guys...
I still have some parts left from the xr
Still have:
-Clarke gas tank
-Wheels
-Frame
-Lots of motor parts
-Hand guards
-Side panels
-Foot pegs
-Seat
-Rear shock
Just shoot me an email and ask away and I'll let you know what I have and give you a price as well
Nonfatwater7@yahoo.com
I sent you an e-mail or two regarding the side covers....let me know whats going on....
S.t.t.G. is offline   Reply With Quote
Old 08-20-2012, 03:06 PM   #5422
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,215
Acerbis 5.8 installed!
I had to tweak the mounts a bit to get it to sit straight on the bike but it finally gave in. I still can't believe that they send a PLASTIC Y fitting and cheap clear tubing for the fuel lines and expect you to use them. I upgraded to a beefier T fitting and some 1/4 fuel rated hose that worked quite well. With my 1.5 gallon aux fuel container I believe I have the range to plan a trip up the Dalton Highway next summer. It's around 270 miles from Coldfoot to Deadhorse with NO FUEL STOPS inbetween so you have to plan accordingly. OR walk
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is online now   Reply With Quote
Old 08-20-2012, 04:37 PM   #5423
jcshew
Oddometer: 33
Bent Forks
boom:
If you find you need forks, let me know. I have a set of 92s that are in very good condition.
jcshew is offline   Reply With Quote
Old 08-21-2012, 01:59 AM   #5424
raytriplej
Oddometer: 30
Nice screen there Alaskajeff, any more pics of it?
raytriplej is offline   Reply With Quote
Old 08-21-2012, 09:15 AM   #5425
Royal Club
Royal Club's Avatar
Oddometer: 392
Apart from the 88 and up XR's having a offset to the left for shock absorber mounting, would an 88 and up shock fit in an 87 frame/prolink?
Royal Club is offline   Reply With Quote
Old 08-21-2012, 10:26 AM   #5426
Dan_Gearhead
Dan_Gearhead's Avatar
Oddometer: 8
Just joined the world of XR600R:s a couple of weeks ago when this thumper came into my possession. Don't know that much about the bike other than it has a full Sebring system and the front forks and rear damper has recently received new oil. The top end has received a new wiseco piston and the valves has been done about 5000km ago, and that the frame was painted last winter..
Just changed the chain and sprockets and went with the stock 14/48 gearing. Not that pleased with that gearing on the trails so a 13 front sprocket is on the way. I'm a newbee to this since I've spent most of my riding on a gsxr1000, and that is a tad bit different But it sure is fun!
Dan_Gearhead screwed with this post 08-21-2012 at 12:48 PM
Dan_Gearhead is offline   Reply With Quote
Old 08-21-2012, 11:02 AM   #5427
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Nice bike there Dan. Be sure to use a Honda front sprocket to protect the splines on the output shaft.
1991 Honda XR628R
1978 Yamaha XT500
JAB is online now   Reply With Quote
Old 08-21-2012, 11:12 AM   #5428
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,215
Thanks, If you are referring to the windscreen it is a Cee Bailey's sport model. They make a nice product and have different styles to choose from for the XR and many other bikes. Check out their website.
Palmer, ALASKA
2011 Verys ADV
Old 08-21-2012, 12:45 PM   #5429
Dan_Gearhead
Oddometer: 8
Hmm, bought a JT sprocket, you don't think the splines will like it? It's not that big of an investment so it really doesn't matter if I get another one....the sprockets that are currently on are Primary Drive from rockymountainatvmc...
Old 08-21-2012, 12:51 PM   #5430
elsalvadorklr
southern xr rider
Oddometer: 4,154
85-87 xr600 shocks are longer and have beefier mounts so some shaving and or modding has to be done to fit other year models, so the 88 shock for example will be slightly shorter and the bottom mount if im not mistaken will have to be widened...
thing is they are pretty thin as is
cheers
can take measurements on my 88 shock if you want
Times are GMT -7.   It's 08:57 PM.
