Old 09-12-2012, 09:03 AM   #5611
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by mcma111 View Post
I recently worked on a fellas XR600 and it left my place running and starting fine. About a week later he calls and says he can't get it started. I go to his place and watch him do the starting drill. I then reach under the tank and fiddle with the idle screw. Turns out that he had truned it almost all the way out. I spun it in a couple of turns and it started on the second kick. DOH!!!
By any chance has either STFU or Christian played with the idle adjustment?
yeah I did, when it initially wouldnt start....
howvere I have tried all manners of turns in and out and it still just wont start...
elsalvadorklr is offline   Reply With Quote
Old 09-12-2012, 09:04 AM   #5612
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by JAB View Post
How's the coil mount? Clean and tight?
yup I get good resistances on both coils...I also sanded some new steel so the mount had a good ground...
Old 09-12-2012, 09:06 AM   #5613
elsalvadorklr
southern xr rider
Oddometer: 4,154
whats your way of checking spark?
hey dudes I have never had good results grounding the plug to the head, I mean how do you get it to not move? in any case I heard of guys holding the plug wire in their hands Im about to try this as I just cant figure out how I get zero overnight...unless electrical of course
thoughts?
Old 09-12-2012, 10:01 AM   #5614
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Take a deep breath and find a starting point. From there, check all connections, looking for broken wires or shorts. It's in the ignition circuit somewhere. Won't start after a ride? Were you playing in the puddles again? Something get wet? You could grab your spark lead and kick slowly and see if you get a tingle. How about your headlight? Can you get a few volts there? Patience Grasshopper, you will find it.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 09-12-2012, 10:06 AM   #5615
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanlks jab
Im starting from simple
Headlight is off
kill switch is off
I have my red black from statir and green ground...I have my whight connected to the blue lead that goes to my voltage regulator...
I have cleaned double and triple checked all connections...
I have not taken apart the harness
I get no tingle in my hand when holding the plug in my hand
should I try without the plug and cap? just the wire?
thanks
Im getting 35volts AC when kicking over
ground on the coil looks good and has clean steel to ground too...
Old 09-12-2012, 10:29 AM   #5616
elsalvadorklr
southern xr rider
Oddometer: 4,154
can you get a voltage reading at the coil? like black yellow and green?
Im getting some voltage at the cdi red and black...
again from the stator im getting close to 40vac...
Im undoing the harness kindof as we speak
I get no spark or tingling when holding the coil lead...nothing...
Old 09-12-2012, 10:37 AM   #5617
Johnson4x4
Johnson4x4's Avatar
Oddometer: 34
Got my front end on. Looks a bit more modern now.
Johnson4x4 is offline   Reply With Quote
Old 09-12-2012, 10:57 AM   #5618
elsalvadorklr
southern xr rider
Oddometer: 4,154
nice!
Old 09-12-2012, 10:59 AM   #5619
elsalvadorklr
southern xr rider
Oddometer: 4,154
still testing
alright guys so with a test light I confirmed Im getting no volts at the coil...at the black yellow...
I am getting volts at the black red...
it seems that either the wires or plugs out the cdi are wonky or the cdi
here is my question
if something is shortted for example, when testing the good backup cdi I have would that damage it too?
reason being is GET nothing with both cdi's
so whats up?
please any input is appreciated...
christian
Old 09-12-2012, 11:01 AM   #5620
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
You're getting power to the coil, right? And you are getting signal to the coil or CDI? Can you test the resistance in the coil all wires off?
1991 Honda XR628R
1978 Yamaha XT500
Old 09-12-2012, 11:01 AM   #5621
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 668
This is painful to watch, so I am going to chime in.
1. Remove the spark plug.
2. Put the spark plug in the rubber boot ( of course you have checked the coil lead wire and the connector inside the boot to make sure they are in good shape)
3. Find a way to clamp the threaded metal part of the plug to a good steel surface on the bike. (grounding the plug) This can be done with a friend just holding the plug again a head bolt or by using duct tape, or a spring clamp, etc. Anything that can serve as your third hand.
4. Now get on the bike, and while you are squeezing the decompression lever in with your left hand, use your foot to kick over the engine a few times. It will kick easily withe the plug out and the decomp lever pulled in. (Maybe you don't even need to pull the lever in)
5. You, or your friend holding the plug, should see a nice consistant spark.
If you have good spark, my bet is on the pilot jet being plugged.
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 09-12-2012, 11:04 AM   #5622
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
here is my question
so whats up?
christian
Unless you have 2 toasted CDI's they are probably good. Trace the dead wires back from the coil. Forgive me, but I am guessing, sitting here at my desk.
1991 Honda XR628R
1978 Yamaha XT500
Old 09-12-2012, 11:12 AM   #5623
elsalvadorklr
southern xr rider
Oddometer: 4,154
dude its painful to watch because I have exhasuted most options
I have no voltage going to the coil
I do not have spark
I do not get tingling at the coil wire
plug cap is new
coil is new
resistances are good on this coil and old oem coil
I kick over and get nothing at the coil
Im checking the harness for shorts and cut wires and nothing
seems like its the cdi
problem is I had a backup and it does not produce anything either!
Old 09-12-2012, 11:14 AM   #5624
elsalvadorklr
southern xr rider
Oddometer: 4,154
im doing this as we speak...
can any of you guys tell me whether you can test voltys going out from the cdi and which color wores would that be?
im guessing the red black and one of the greens?
Old 09-12-2012, 11:20 AM   #5625
mcma111
mcma111's Avatar
Oddometer: 12,587
Can you check continuity from the CDI end of the harness to the coil?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 08:06 AM.
