Old 10-03-2012, 09:55 AM   #5896
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by ID XR600 View Post
This is what I did on an XR650L
I have the 10 row which is overkill,,,but a Harley dealer was selling it for $75 brand new. I made a bracket to mount the cooler on, from a piece of flat steel,,,it needed rubber washers to stop it from vibrating. The guard is a radiator protector for a KX500. I made sure the hoses could reach and then covered them with plastic wire covering like the XRL has for wiring harness. I have about 2000 miles no problem. I run easily 20 degrees cooler.
I still think Marks cooler is the bees knees,,, looks factory. Mine looks frankenbike
I have your same style forks, unfortunately they dont have the bolt mounts forward like the australian felllow with the setrab cooler...
hos cooler was off a 97 baja 500 xr600...
anyways can I see your oil line connectors, where they meet the tubes?
what did you use to connect the hoses to the oem lines?
thanks a lot for the pics
I dont think you cooler looks bad at all...this is where it should mount for optimal airflow and protection
cheers
elsalvadorklr screwed with this post 10-03-2012 at 10:00 AM
elsalvadorklr is offline   Reply With Quote
Old 10-03-2012, 09:59 AM   #5897
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by S.t.t.G. View Post
That's something I've been thinking about also.....something low-buck but effective and durable. But I don't know, I don't think I'd want the lines to the cooler flexing every time I turn the bars....
Maybe something off a VW engine or something....
Or this...
http://www.aliexpress.com/item/ALUMI...505539656.html
yup Im looking for tranny coolers off cars/trucks down here
dimensions should be about 6-9 inches by 3 inches or something like that so ot sits right under the headlight shell...
the lines must be flexible and string enough to not kink
looks like idxr600 has transmission hose..
yes?
Old 10-03-2012, 10:25 AM   #5898
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,241
The VW cooler idea is interesting. They are supposed to be pretty efficient. I think there are aftermarket mounts/brackets. There are (for the aircooled engine) at least 3 styles I can think of. The old original tower style, the later "dog house" or offset style and the pancake/type 3 style. Might be able to use a power steering cooler from a truck as well.
1991 Honda XR628R
1978 Yamaha XT500
JAB is online now   Reply With Quote
Old 10-03-2012, 10:57 AM   #5899
elsalvadorklr
southern xr rider
Oddometer: 4,154
yeah power steering and tranny coolers seem to be the ticket...
now more ideas on what connectors and or lines people are using would be great, Im not worried so much about cutting the pipes, just what guys are actually using coming out of the oil coolers and sizes...
thanks guys
Old 10-03-2012, 11:25 AM   #5900
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,241
Are you thinking of mounting the cooler to the forks (need clearance and flexy lines) or the frame behind the headlight sort of like the XR400 cooler?
1991 Honda XR628R
1978 Yamaha XT500
Old 10-03-2012, 03:46 PM   #5901
elsalvadorklr
southern xr rider
Oddometer: 4,154
originally on the frame, thing is Ive only seen one pic of an xr400 with usds installed and the guy had to grind some fins off the cooler to fit...so Im thinking it might be an issue with my usds...
dunno
so Im thinking it might be easier to install on the forks and have flexy lines...BUT if I find a small cooler that will fit on the headtube then that might still work too...
Im just looking for ideas at this point
Old 10-03-2012, 05:55 PM   #5902
rod.whayt
Oddometer: 11
Originally Posted by mrfixit54016 View Post
Jeff,
This picture BEGS the question...How tall ARE you? You have bar risers + ROX Risers + the tallest bars I have seen on a dirt bike.
Originally Posted by Alaskajeff View Post
I am 6'3" with long arms and legs. I have it set up so I can comfortably (without being hunched over) ride standing on the pegs. I could actually use another inch or so
this is a bike my neighbor had .. guy was 6"9' they are 4 inch risers wow here is my neighbor on it when he got it he is 5"9'
rod.whayt is offline   Reply With Quote
Old 10-04-2012, 02:27 AM   #5903
benno.h
cageracer
Oddometer: 437
Been trying to make a new dash to mount on my Trailtech racelight.
The dash itself is easy, bent a piece of perspex to fit.
The electronics are annoying the shit out of me. I want a high beam and indicator light and they're proving troublesome. I forgot that the bloody headlight runs on AC, so the LEDs I bought won't work for that.
And the resistors I bought for the indicator LED are two low, so the light stays on even between blinks. Frustrating! I'll have to go get some different resistors tomorrow and have another go, and look for an incandescent bezel for the high beam light, or maybe run both as incandescent.
Back side: accessories switch, indicator relay, reg/rec and indicator light all mounted up.
Rough position on the bike:
Originally Posted by GodSilla View Post
I'll step out on a limb here and state that bikes without kick starters are just plain gay, for pansies, ladyboys, and suchlike. Furthermore, they should have to ride at the back, not speak until spoken too, and set everyone else's tents up, then cook and wash up afterwards, before sitting up all night guarding the real men's bikes.
benno.h is offline   Reply With Quote
Old 10-04-2012, 07:56 AM   #5904
ID XR600
ID XR600's Avatar
Oddometer: 245
dunno
I cut the oil line and slid the hoses over the pipe on the XRL with front mount cooler. I've found some pics of a cooler I installed on another bike in 2010. The aluminum cooler was made for Harley's an they had tapped too may holes,,, so I just used plugs and braided hose with fittings that screwed right on to OEM fittings.
sorry for the blurry pics
I really liked the braided lines and would have done the same on the XRL but the cooler has hose nipples already on the cooler and it seemed too difficult to do at the time.
"Endeavor to persevere."
ID XR600 is offline   Reply With Quote
Old 10-04-2012, 10:30 AM   #5905
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks for the ideas man
on your cooler what hose lines did you use? I read transmission on on of the hoses in one of the pics
simple rubber tranny hose will do?
thanks
Old 10-04-2012, 11:14 AM   #5906
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 364
allright so I found out the coolers are made by setrab...
they are mounted on the forks...so they turn
so who has experience with the oil lines and connections? for a flexible oil cooler mod
cheers
Hi
I dit it a few Times befor i get it near perfect .
After i try a few differnt coolers i end up with a cooler from a GS650
I try different routing of the oil hoses to and end up with the pipe /hose combination in the pics .
Hoses has to be cross over for minimal bends .(over the cooler in front off the headstock )
and Pipes end close by the headstock . all to keep the movement of the Hoses as low as possible .
Watch that the hoses don't kink on any position . Keep the hoses short , long hoses seams to restrict the flow
just from the friction inside the hose especially in tight bends even without kinks .
restrict the Oilflow and you are in trouble . quality reinforced oil hoses are a must .Trust me on that .
The red one in the pics was just for testing .
The Pipes are self made from Hydraulic pipe so as the brackets for the cooler .
Pics are from my XL but this will also work on a XR
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 10-04-2012, 11:23 AM   #5907
elsalvadorklr
southern xr rider
Oddometer: 4,154
wow klaus thanks!!!!!!
is there a reason you made the new piping?
or is that a cut oem pipe in the pics?
thanks a bunch
Old 10-04-2012, 11:44 AM   #5908
Schrauberklaus
***ifyer
Oddometer: 364
As i writhe , new hydraulic Pipe , the OEM one is not long enough .
Klaus
Old 10-04-2012, 12:12 PM   #5909
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks
Ill see what options I have for coolers down here...
ideally id like something like the xr400 cooler mounted on the frame, but I will see what I come up with...
thanks for the great ideas
christian
Old 10-04-2012, 02:29 PM   #5910
kirbi69
Oddometer: 219
you can use a smallblue neon light for the highbeam indicator. they work on ac
1994 XR600R dual sport
kirbi69 is offline   Reply With Quote
Times are GMT -7.   It's 03:10 PM.
