Old 12-13-2012, 07:21 AM   #6391
mcma111
mcma111's Avatar
Oddometer: 7,965
Originally Posted by Royal Club View Post
What would you guys recommend as a aftermarket exhaust for a XR600 with FCR40, wiseco 11:1 and Hotcam?
Just the header by the way.
XR's Only over size stainless steel header.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-13-2012, 12:00 PM   #6392
Royal Club
Royal Club's Avatar
Oddometer: 293
would the FMF be comparable? price is about the same at powerplussports
Royal Club is online now   Reply With Quote
Old 12-13-2012, 12:23 PM   #6393
mcma111
mcma111's Avatar
Oddometer: 7,965
The XR's Only has larger tubing than the FMF. More flo, Bro...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-13-2012, 12:31 PM   #6394
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,008
Originally Posted by fiep View Post
I recently aquired an XR600
the seller posted it as an 85 and it turned out to be an 86
yes, my bad, I did not pay attention enough
in GA up to and including model year 85 is easy to register
anything newer is a pita going on impossible
now I am pondering
wheather to restore and keep or to part out
bike fires up and once in the mid-range sounds fine,
fairly unmolested and unabused basis for a full restoration
to stock beauty
I like this XR600
but love my XR250s
what would you do?
if you do decide to sell it, give me a PM. I can give it a good home next to it's sister.
"Living just to keep going, goin' just to be sane." - The Black Keys
I prefer kick starters, air-cooling, and carburetors over anything.
motomike14 is offline   Reply With Quote
Old 12-13-2012, 02:57 PM   #6395
T4EaterJonny
Not too hip...
T4EaterJonny's Avatar
Oddometer: 27
Okay! My tail light problem was because the Acerbis wires on the tail light harness were spinning around and touching each other. I "engineered" a Ford Aspire tail light However, I probably threw in a higher wattage bulb. Now she dims like hell when i hit the brake. Now... What do most of you use as batteries? I've been reading and some people on thumpertalk use 10 NiMH A cell batteries. Suggestions? I never ride this thing at night and I'll NEVER be offroad at night. I do'nt want to have to charge it everytime I ride it either.
1994 XR600R - Plated
2007 Yami R6
and a turbo neon and turbo Furd.
T4EaterJonny is offline   Reply With Quote
Old 12-13-2012, 04:38 PM   #6396
Alaskajeff
Alaskajeff's Avatar
Oddometer: 688
Yeah, you should try an LED tail light of some kind. That Aspire thing you have probably isn't compitable with your system. Like I said my NiCad is long since dead and doing NOTHING on my bike and all lights work fine when running!!
Jeff Reichel
Palmer, Alaska
1 Tim 6:11-12 "FIGHT the GOOD Fight"
funinak@mtaonline.net
PLATED 88 XR600R & 92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 12-13-2012, 05:18 PM   #6397
Tachedoutoffroad
Tachedoutoffroad's Avatar
Oddometer: 474
Ok!
I bought my 250 and 600 two days apart and I'm finally getting to play with 600....
I knew it rode like shit and seemed to sit low...
---> Every compression and rebound adjustment on it was maxed out or almost maxed out on the hard side??
And the sag was ...3/4" rear spring was super squished. It's at 3" now. Got to be supper time.
I'm guessing a fatty just had it as a road bike-- 50/50 tires, no bark busters, no skid plate, low, stiff suspension.
It rides x10 better now it's my fault for not noticing, I knew my 250 suspension was super built and just figured the 600 just sucked stock also noticed the forks and rear shock have a shock company stickers on them.....
Questions:
1) does anybody know if the stock 96 rear spring was dark blue/ purple?
2) when just standing next to the bike and you shove down on the front end, how long does it take for yours to go all the way down and rebound? My 250 is about --one mississippi-- the 600 is about --one mis-- maybe the front springs are stiffer than stock??
Going to call the company on the sticker and see if they keep any records. I have the last two owners names.
'09 Husky 510 TE/SM
'07 Husky 610SM SOLD
'96 Honda XR250/300R (plated)
'96 Honda XR600R (plated) FOR SALE
Tachedoutoffroad is offline   Reply With Quote
Old 12-13-2012, 05:35 PM   #6398
brucifer
brucifer's Avatar
Oddometer: 1,618
I can answer #1--The stock spring is purple.
2006 KLR650 2002 Yamaha FZ1-2002 Husaberg FC550E w/2008 FE550E engine-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 12-13-2012, 05:57 PM   #6399
Tachedoutoffroad
Oddometer: 474
I felt like I was getting high on the threaded collar trtimg to get 3.5" sag and was thinking it might be a stiffer spring?
Hummmmmmmmmm
'09 Husky 510 TE/SM
Old 12-13-2012, 10:38 PM   #6400
T4EaterJonny
Not too hip...
Oddometer: 27
The spring was out of adjustment on the brake pedal. Its all good now. I still would like to know what batteries you guys like using though. :)
2007 Yami R6
Old 12-14-2012, 04:38 AM   #6401
kirbi69
Oddometer: 194
Check this out on AMZN:
12V Tenergy 2000mAh NiMH Battery Pack with Bare Leads for RC Airplanes
http://www.amazon.com/dp/B00408X4LU/..._am_us?ie=UTF8
1994 XR600R dual sport
kirbi69 screwed with this post 12-14-2012 at 04:52 AM
kirbi69 is offline   Reply With Quote
Old 12-15-2012, 10:50 AM   #6402
LandsVW
LandsVW's Avatar
Oddometer: 134
Originally Posted by mrfixit54016 View Post
Before:
After:
My tank looks exactly like your before tank. How'd you get it cleaned up?
LandsVW is offline   Reply With Quote
Old 12-15-2012, 01:56 PM   #6403
beechum1
beechum1's Avatar
Oddometer: 4,796
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Originally Posted by Tachedoutoffroad View Post
Ok!
Questions:
stock springs were different colors but same rates over the years.
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 12-15-2012, 01:56 PM   #6404
beechum1
beechum1's Avatar
Oddometer: 4,796
Does the NX2nd gear swap work for the 600 also? I mean, does is close the gap also?
Old 12-15-2012, 03:17 PM   #6405
mcma111
mcma111's Avatar
Oddometer: 7,965
The XR and XRL both have the same 17 tooth second gear. What is different is the main shaft on the XR600 is 13 tooth and the XRL a 12 tooth.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 12:54 PM.
