Old 12-19-2012, 12:03 PM   #6436
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
This one looks pretty cool.
The build pics
http://s174.photobucket.com/albums/w...xr600%20build/
xladv.com
MentalGuru screwed with this post 12-19-2012 at 05:01 PM
MentalGuru is offline   Reply With Quote
Old 12-19-2012, 12:38 PM   #6437
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Something I did on my old KTM was to use a 1" hole saw on the foam, from the bottom and remove SOME of the foam. This was done to make the granite KTM seat a little softer. Example: If the foam is 2" thick, use the 1" hole saw to remove 1" of foam nearest to the seat pan side. Drill in and pull out a plug of foam. Do it in a pattern that makes sense for your seat shape. Don't see why this wouldn't allow you to sit a little lower in the seat without having to do any major upholstery work.
I saw this thread/idea on KTM Talk some time ago. I'll see if I can find it and link it.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 12-19-2012, 12:41 PM   #6438
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks man however Im confused by your last post...about the holes?
I like the first xrl seat pic...and YES I love that crf xr build...I remember the guy, however its all crf seat, fenders and subframe...
jejeje
elsalvadorklr is offline   Reply With Quote
Old 12-19-2012, 02:42 PM   #6439
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by elsalvadorklr View Post
yeah man! thats about right! how tall are you? Im like 5.7/ 5.8feet with boots! jajajaja
whats your technique for tight singletrack when you fall down? have you taken some foam off your seat or do you only ride street?
cheers bud
just ride street, used a lowering link but it hits the underside of my rear fork so im gonna take it out when I get to it. Maybe try a koubalink if money is available. I'm 5.6, on sneakers zo boots will make it a bit more..
Royal Club is offline   Reply With Quote
Old 12-19-2012, 03:23 PM   #6440
fiep
fiep's Avatar
Oddometer: 1,908
Originally Posted by MentalGuru View Post
I do like having a 36" inseam.... I crash less....
I don't mind being 5'6 1/2"
the pucker factor makes me carsh less
fiep is offline   Reply With Quote
Old 12-19-2012, 04:03 PM   #6441
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Tried to find the thread on KTMtalk, but is seems the article is missing (or I'm missing the article). Basically it amounts to removing the foam and cover from the pan and removing plugs of foam from the pan side of the foam. You don't want to go too deep to keep the holes from showing thru the cover. If I were to do it, I would work on the front 1/3 of the seat. If you soften that area, it will compress more and get you a little closer to the ground. If you search KTMtalk, there are a number of articles on shaving the seat foam as well.
1991 Honda XR628R
1978 Yamaha XT500
Old 12-19-2012, 06:32 PM   #6442
elsalvadorklr
southern xr rider
Oddometer: 4,154
I gottcha now...you soften the underside so it compresses a bit when on it...hmmm
I wonder how easy ungluing the foam from a 25 yeard old seat pan is...
well I got options and this should be a "frree" mod
I ride only dirt...with tarnac to connect to...so for me as soon as the trails get tight and uphill I really need to think...as soon as I tipover might as well have a beer and chillout...
Old 12-19-2012, 06:37 PM   #6443
Royal Club
Royal Club's Avatar
Oddometer: 392
I see no problem.
Old 12-19-2012, 06:44 PM   #6444
elsalvadorklr
southern xr rider
Oddometer: 4,154
EXCEPT i dont carry a beer and have a hard time chilling out when im like an add cat on crack with all the adrenaline going on! jajajajaja
ill figure something out....
Old 12-19-2012, 06:53 PM   #6445
Royal Club
Royal Club's Avatar
Oddometer: 392
fixed...
Still havent completed it though, dont know what to use as a lid..
Old 12-19-2012, 06:58 PM   #6446
Mike the Yank
Oddometer: 439
I just lowered the spring adjuster and slid the forks up 10mm. Checked sag and it was within 3 mm of being spot on!
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 12-19-2012, 08:35 PM   #6447
129CBRider
Oddometer: 10
my '96
New rear wheel, Michelin S12, damper, Cartridge System in the forks, Clarke big tank, Baja Designs headlight
http://s246.beta.photobucket.com/use...38117794611433
http://s246.beta.photobucket.com/use...93611395100631
http://s246.beta.photobucket.com/use...97081835021365
129CBRider is offline   Reply With Quote
Old 12-19-2012, 08:44 PM   #6448
129CBRider
Oddometer: 10
Peel back the seat cover, get your electric carving knife, very slowly slice a nice 3/4" piece of foam off the top of the seat, staple the cover back on.
I'm 5'8 1/2" and can now touch the ground.
Otherwise, CRF230L.
Old 12-20-2012, 03:57 AM   #6449
Royal Club
Royal Club's Avatar
Oddometer: 392
Otherwise, CRF230L.
I think ill try the drill holes from underneath trick, since I wont be able to tack the cover back on as nice as it its now..
and no, I dont have the cashflow to 'just' buy an other bike.. If I had that I'd have bought a DRZ of 625 way long ago
Royal Club screwed with this post 12-20-2012 at 04:06 AM
Old 12-20-2012, 07:25 AM   #6450
elsalvadorklr
southern xr rider
Oddometer: 4,154
Ill be trying either of those methods...Ive never unglued the foam from the pan so maybe Ill do the knife carving..ive been wanting to do this forever but just scared...
Times are GMT -7.   It's 02:35 PM.
