02-12-2013, 04:45 PM
#6841 |
Oddometer: 3,961
little ride today, finally have someone take a pic of me and the bike
![]() brap on fellas, see you around christian |
02-12-2013, 09:02 PM
#6842 |
Oddometer: 100
Hi everyone, I'm back.
So since last time I posted I have completed disassembled the front brake system. Cleaned all the brown gunk out of the master cylinder, took the master cyclinder piston and spring out and inspected the seals/cups (looked fine). lso tried to clean the holes in the reservoir, which is where I encountered a problem, namely the needle I was using to clear the hole snapped while in it. Yes, it sucked as there was almost nothing to grab onto to pull it out yet it stuck through into the master cylinder so I couldn't put the spring and piston back in. Went and got some tiny drill bits (less than 1mm) and drilled it through which seemed to work. I read some stuff on the net that says that it was ok to do, whether that is true I'm not sure? Anyway, seemed to be fine so I connect the MC back to the bike, hooked up the brake hose and caliper, bled it and tried. Success! Wheel would freely spin and then stop instantly on application of brakes. However, after doing this about 4 times, the wheel would spin slower as it got harder and harder to move it. Turns out I still have the same problem as before but this time I have some extra info at least:
So the pistons just don't seem to be returning back after the brake is released. I assume it is not the MC as the holes are clear, and not the brake line as the pistons don't release even if the bleeder valve on the caliper is opened. I just don;'t understand why I can push the pistons back with my thumb, but they don';t seem to when on the disc. Thanks John |
02-12-2013, 09:10 PM
#6843 |
Oddometer: 3,961
captain I repeat replace inner seals
the piston being able to be manually pushed is only half the battle...they need to be able to return to their original position...this is done by the seals angle. the seals are not flat they are angled so that when you pull the lever on the caliper it pushes the piston outwards BUT its the angle of the seals that RETURN the piston back to its position, along with the release of pressure and consequent sukcing back of the fluid. old seals will not do this lastly if you had gunk the seals are more than likely shot. what you must do is take out seals then manually clean THE GROOVES where the seals sit in..the brake fluid crystalizes and pushes against the seals making the pistons hard to operate you can also polish the pistons so they are nice and smooth good luck |
02-13-2013, 01:23 AM
#6844 |
02-13-2013, 02:59 AM
#6845 |
Oddometer: 298
02-13-2013, 03:05 AM
#6846 | |
Oddometer: 100
Thanks, John |
02-13-2013, 03:37 AM
#6847 | |
Oddometer: 641
![]() I don't have a beach close by...unless I count riding by Lake Tahoe.....but I have some of the best mountian and desert riding in the U.S. BTW the XR6 is looking damn good
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
02-13-2013, 04:47 AM
#6848 | |
Ivanych
Oddometer: 213
02-13-2013, 04:59 AM
#6849 |
Oddometer: 641
02-13-2013, 06:55 AM
#6850 | |
Oddometer: 1,625
![]() That's some pretty cold looking sand, Ivan. Looks like you and Royal Club have the same type.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
02-13-2013, 07:02 AM
#6851 |
Oddometer: 3,961
02-13-2013, 07:04 AM
#6852 |
Oddometer: 3,961
#6853 |
Oddometer: 8,000
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
02-13-2013, 07:09 AM
#6854 | |
Oddometer: 3,961
good stuff you guys need to ride down here so we can have some beers and ride around... ![]() thanks, btw... the bike is always an ongoing project...its part of my life...jajaja I rescued it from BOXES completely blown apart...thanks to steve and many many many others here it started for the first time in like 10 years about 3 years ago...then some rebuilds, some mods, a crash that almost totaled it and then well, some good mods again! you know how a bike should progress over its lifetime! TASTEFULLY ![]() cheers bud |
02-13-2013, 07:12 AM
#6855 | |
Oddometer: 3,961
![]() ![]() ![]() jajaja joking aside...if I do get a bud to ride with Ill try... BTW I suck at wheelies...my thing is riding 2 lane trails FAST...bed of rocks hit the throttle and fly over it...stuff like that, everyone has their niche...that and beach riding and going trough little estuaries is what its all about down here... btw I hate enduro...99% of people ride that down here... just goes to show...we are all different... Ill see if I can get some pics...jejejeje christian |
