Old 02-20-2013, 08:23 AM   #6946
elsalvadorklr
southern xr rider
Oddometer: 4,154
Heeeeeeeeeeeeeelp!
damn guys dint mean to bum any of you guys out
hey I need some REAL help here
I found out my mitusbish montero 2.6l gas 4 cylinder had head corrosion...some of the water passages needed welding,but its not cracked! so my question is this
Im not familiar with this engine however it is a very simple durable design same as dodge raider for you guys in the us.
it is an inline single overhead cam design
my question is the rocker arms and design look the same as my xr600, in other words the lifters are adjusteable with the locknut and screw design
however Im getting conflicting opinions on how to adjust after a complete head rebuilt including valve seats, GUIDES etc...
its obvious if they have adjuster that they need to be adjusted but how does this compare to adjusting our valves?
I also need to retorque the head after a few miles to prevent head warpage and another blown gasket.
Im going to replace all head bolts with new 12.9 grade ones so I dont have this issue as the previous owner decided it was a great idea to mix and match grade steel and hex and allen bolts too!
PLEASE any input is greatly appreciated
christian
elsalvadorklr is offline   Reply With Quote
Old 02-20-2013, 09:02 AM   #6947
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
christian
They adjust just like your XR6 .......get the piston to tdc and adjust each one that way.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 02-20-2013, 11:27 AM   #6948
elsalvadorklr
southern xr rider
Oddometer: 4,154
do you do all intake and then all exhaust or do you go by piston individually
thanks so much bud
christian
p.s. non related do you have experience jetting for dual headers on the xr6? I went back to stock on my 88...Im guessing I need to jet down on the pilot and up on the main maybe...
still using the flatslide
thanks!
Old 02-20-2013, 11:33 AM   #6949
mcma111
mcma111's Avatar
Oddometer: 12,279
You adjust one cylinder at a time. Which ever is at TDC from where you start.
Head torque. I beleive you start at the middle and work towards the ends of the head.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-20-2013, 11:53 AM   #6950
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks man
Im having a hard as hell time finding the torque specs for a dodge raider or montero head bolts
the idiots that put the allens used 100ftlbs and then the other ones where at 60 or so, no wonder I blew a gasket...
so in then out check.
anybody with some INTERNET voodoo wanna help me find the torque specs please? Im usually pretty good at this but man!
brain farting big time...
Im looking for dodge raider, mitsubishi montero generation 1 head bolt torque specs
thanks again boss
Old 02-20-2013, 12:39 PM   #6951
deejay_xr
deejay_xr's Avatar
Oddometer: 496
http://www.ebay.nl/itm/Mitsubishi-Pi...f#ht_500wt_969
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 02-20-2013, 12:41 PM   #6952
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
You adjust all the valves on a given cylinder when it's at TDC. It will be easy to see when the rockers are on the cam's base circle since it's an OHC engine.
There is another technique where you adjust only the valves that are completely closed so the engine only had to be turned over two revolutions instead of eight. Which valves get adjusted when depends on the firing order.
I can't verify that these numbers are correct, but it's something I found real quick looking for Montero 2.6L torque specs.
http://www.4x4wire.com/forums/showfl...?Number=929385
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 02-20-2013, 12:41 PM   #6953
RoostMaster
Oddometer: 255
Thumb '85 head on '92 model?
Hey XR People, have been searching for a second hand/spare head for a big fin & porting project, easy question for some here... will a 1985 model head (duel carbs back then?) fit onto my 1992 barrel and engine?
Cheers RooSt
RoostMaster is offline   Reply With Quote
Old 02-20-2013, 12:41 PM   #6954
mcma111
mcma111's Avatar
Oddometer: 12,279
I just entered what you have and hit enter and I get :
http://www.automotix.net/autorepair/...uide-2414.html
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-20-2013, 12:43 PM   #6955
mcma111
mcma111's Avatar
Oddometer: 12,279
Next question. Are the head bolts a one time use?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-20-2013, 12:45 PM   #6956
mcma111
mcma111's Avatar
Oddometer: 12,279
http://mitsubishimontero.danielcadam...pecifications/
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-20-2013, 12:51 PM   #6957
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks HT real good stuff,. indeed I have been on that site before but my computer was just being more dumb than even myself...I couldnt find it
I found out after posting this previous question that the REVISED torque is 80ftlbs...hot or cold...as blown head gaskets were an issue with the lesser torque spec
you guys are reall good and thanks
deejay a but late to order a manual but I will in the futire I need the truck tomorrow to go the restaurant
jejejeje
Old 02-20-2013, 12:53 PM   #6958
elsalvadorklr
southern xr rider
Oddometer: 4,154
apparently the ALLENS ARE STOCK! jajajajajaja either way the po screwed me
Im getting new ones as a set $70 for 10 of them
whatever cant risk having my truck fail me to go to the mountains
geeeeeeeeeeeeeeeeze
Old 02-20-2013, 03:12 PM   #6959
elsalvadorklr
southern xr rider
Oddometer: 4,154
well got the bolts, they were hex, whatever,m they are new.
see what happens tomorrow
now for an xr related question...
has anybody ever bought gasket donuts? you know the copper ones for the exhaust ports? BUT at an autoshop or over the counter somewhere?
My left port is leaking...I jiggled and git the right one to seal again, but not the left port
I got 3 pinhole leaks in the muffler but most important at the port...
also
Im down on power bigtime which is a bummer...so I got to rejet yet again and see if maybe I can get some power back
Im really at a loss as to what jetting these headers will need with the MIKUNI flatslide as well its just a different beast all together...
Im guessing at a minumum I need to fatten up the needle and main jet...I can start and restar pretty damn well and idle is smooth as butter...
so does this sound good to you guys?
Old 02-20-2013, 03:20 PM   #6960
mcma111
mcma111's Avatar
Oddometer: 12,279
Christian,
I should have the pipe to head gaskets/seals. I can tape them to a thin card and mail them to you if you want them.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 06:44 AM.
