Old 03-05-2013, 07:16 AM   #7141
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Originally Posted by elsalvadorklr View Post
I had the same PUCKER moments you speak of yesterday...
My very first bike was a POS XL500S, drum brakes front and rear.
Those weren´t pucker moments but straight up ´shit your pants´ moments
Hooray for disc brakes !!
deejay_xr is offline   Reply With Quote
Old 03-05-2013, 07:51 AM   #7142
cognugget
cognugget's Avatar
Oddometer: 73
Xr650r In singletrack
http://www.youtube.com/watch?v=HIPdb...Rg9udw&index=2
xr650r vs crf450r
http://www.youtube.com/watch?v=hJCGd...zLOE_xiHRg9udw
xr650r road test (1st street ride)
http://www.youtube.com/watch?v=Eyy4t...Rg9udw&index=4
xr650r crash
http://www.youtube.com/watch?v=BpOzJ...Rg9udw&index=1
cognugget is offline   Reply With Quote
Old 03-05-2013, 09:36 AM   #7143
elsalvadorklr
Oddometer: 3,960
bleeding
well captain and deejay inspired me to do the hose swap and bleed my brakes
good news is the new hose and mc bolted right up and looks good
the soon to be seen news is wether I can get ALL the bubbles out
its just taking me longer than usual but Im getting firm at the lever(please no jokes jajaja)
so the lever is sitting there while I bleed the lower banjo every 5 minutes or so and tap tap tap at the mc
yes I know reverse bleed blah blah blah, thing is I dont know where I put all that crap when I moved
so its old school style bleed for me
so far so good
now just need to rejet the needle on the carb I think and maybe up the main jet and I should be ok for the meantime
Im getting close to 50mpg which is too lean now that I think about it for the way I ride jajaja
peace
elsalvadorklr is offline   Reply With Quote
Old 03-05-2013, 09:38 AM   #7144
Royal Club
Royal Club's Avatar
Oddometer: 296
I'm digging the low end grunt the XR makes compared to the highrevving brep from the crf.
Royal Club is offline   Reply With Quote
Old 03-05-2013, 09:53 AM   #7145
mcma111
mcma111's Avatar
Oddometer: 7,974
Christian,
When ya park the bike for the day get a strap, zip tie, bungie cord or whatever and put it on the front brake lever in the applied position and turn the bars so the master cylinder is at the high position. The real tiny bubbles will find their way to the top and out of the system.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-05-2013, 10:08 AM   #7146
elsalvadorklr
Oddometer: 3,960
Originally Posted by mcma111 View Post
Christian,
thanks boss thats what Im doing! jajaja
Ill leave it like this tonight and see how she firms up tomorrow
just wanted to get a headstart this way
thanks
Old 03-05-2013, 10:23 AM   #7147
Royal Club
Royal Club's Avatar
Oddometer: 296
thanks
What helped for me was putting the fluidcap back on, and tilting the bike over from right to left allmost all the way. helps the stuck bubbles on their way up.
also tap the banjobolts and the caliper with a small ringspanner (10/12mm)
Old 03-05-2013, 10:29 AM   #7148
mcma111
mcma111's Avatar
Oddometer: 7,974
What's the matter with the BFH???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-05-2013, 10:33 AM   #7149
Royal Club
Royal Club's Avatar
Oddometer: 296
Nothing,
see here, me checking the valves.
Old 03-05-2013, 10:59 AM   #7150
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Kinda looks like mine at the moment !
Old 03-05-2013, 11:22 AM   #7151
Royal Club
Royal Club's Avatar
Oddometer: 296
what are you gonna do to it?
Old 03-05-2013, 11:32 AM   #7152
elsalvadorklr
Oddometer: 3,960
DONE!
you guys must be in my mind cause I used all those little tricks, jajaja
brake is bled...I also use the needle in the bleeder hole technique in the bottom of the cylinder cap
thanks guys!
all done!
Old 03-05-2013, 11:42 AM   #7153
Royal Club
Royal Club's Avatar
Oddometer: 296
Chris what sparkplug are you running in the piggy?
Old 03-05-2013, 12:09 PM   #7154
deejay_xr
deejay_xr's Avatar
Oddometer: 470
When I did a partial top-end rebuild last year I made the royal mistake of using a chinese gasket set to put er back together again.
Replaced the stator and clutch gaskets in the meantime cause they´re easy to get to, but I still have an oil leaking problem. Time has finally come to replace the base and head gaskets.
Lesson learned !
Meantime I'll be replacing my crank puls generator aswell, maybe that'll finally fix the problem of erratic idling and stalling
Old 03-05-2013, 12:44 PM   #7155
elsalvadorklr
Oddometer: 3,960
stock dpr8 or dpr9 for long high speed
I learned to gap them at 1mm instead of .8-9 for better burn
Times are GMT -7.   It's 06:36 AM.
