Old 03-05-2013, 03:03 PM   #7171
Kenno
Kenno's Avatar
Oddometer: 793
TM38 settings (with 38mm bore)
I hadn't looked for a while so I pulled the slide out to get the settings for you and found I had been dusted via the filter box somehow, need to investigate further but this donk is coming out for a new crank anyway, this is the mid eighties crank I put in to get to an ADV gathering last August that successfully knocked its way for 4000klms to Cape York and several rides since, bloody tuff engines. Answers below in orange.
Originally Posted by elsalvadorklr View Post
KENNO!
I didnt know you had the flatslide too, is it the tm38? TM38 38mm Bore.
ok here are my questions:
what needle clip are you running? 6FJ40 needle with clip at top groove, throttle response would be better at 2nd or 3rd but I use this for trials type riding and like it soft.
what exhaust and or headers are you running? Stock headers and muffler without baffle.
do you have stock cam? Stock cam.
Im running a 220main but that is because the hrc cam needs less fuel at wot and mid...I need to put the 230 back in and play with the needle. 12.5 Pilot and 230 Main and the Carb bore is 38mm, air screw 2 turns out.
I had a flat spot midrange that just developed(jetting takes a while) jajaja
I had a killer flat spot on my 02 650L with the TM38 flatslide but it has been bored to 41mm, I found the needle clip at the top so I moved it down to the middle and changed from a 12.5 pilot to a 20 pilot, it has a 230 main, I figure I could go back to a 12.5 pilot now but it was terrible until warmed up the way it was.
thanks
oil cooler is next for me
Mine is sitting on the bike but not connected yet.
thanks so much for the help
My pleasure.
christian
Ken
"Parts left out cost nothing and cause no service problems" (Kettering)
Kenno is online now   Reply With Quote
Old 03-05-2013, 03:35 PM   #7172
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by deejay_xr View Post
Not as open as yours, you hacked the whole top out right?
I removed the snorkel and cut away the 'baffle' at the top.
Sides are like this, pics from older setup, but you get the idea
yeah I drilled the fudge out of the top.
those caps are nice, where did you get em?
Royal Club is offline   Reply With Quote
Old 03-05-2013, 03:40 PM   #7173
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Search Ebay for ´Uni air vents´
deejay_xr is offline   Reply With Quote
Old 03-05-2013, 04:06 PM   #7174
Royal Club
Royal Club's Avatar
Oddometer: 392
thx dude!
Old 03-05-2013, 04:20 PM   #7175
Captain115
Captain115's Avatar
Oddometer: 287
Originally Posted by RoostMaster View Post
Hey Captain,
sorry I can't answer your questions however I do have some experience with the front braided hose. If you choose to DIY bear in mind (this is getting fussy but don't want to see you caught out) that here in Vicco a braided brake line requires a SEA/Approved type tagged attached to it for a RWC/pink slip/police canary's, otherwise will get knocked back....
I got mine from Ballards (not the cheapest), sent me one that was too short, they wanted me to pay to send it back before they sent the new one down !
Very worth while upgrade. I tried a few pads and settled with SBS. Roost.
Hey mate, thanks for the info (you too, deejay_xr).
Because I didn't want to buy the wrong size hose and bolts I was just going to do what deejay_xr suggested and buy my own stuff so that I can size it correctly myself. But then after reading what RoostMaster said about the need for it to be ADR-compliant etc (whatever that stupid standard they've made up for in Australia) I thought I would just contact the company to see.
A few emails later and we have found that the newer hose and bolts should be identical to older ones so should bolt up fine, which was confirmed by elsalvadorklr too (thanks!).
The company I am considering buying through, Venhill, seems to be pretty well know in this scene and are DOT/ADR/TUV approved, like the ones Ballards sells which i believe are Goodridge. I had only heard of Galfer before as that what made Dad runs on his BMW's.
Anyway, I'll let you all know if I do grab them and see if it makes much difference.
Cheers,
John
EDIT: Just found these guys too: http://helperformance.com.au/store/p...oducts_id=8431 for $54 AUD it seems like a pretty good price. Might check Ballards to see what there prices are too.
Captain115 screwed with this post 03-05-2013 at 04:36 PM
Captain115 is offline   Reply With Quote
Old 03-05-2013, 04:54 PM   #7176
elsalvadorklr
southern xr rider
Oddometer: 4,154
update
brake bleed a complete success and I have better lever feel...however I still need new pads, doh!
bad news is change in needle clip has brought back the famous BOG flatspot.
uuuh
so I had it at second from bottom and went to 3rd clip it made it worse so apparently my bog there(if im not brain farting here) is from not enough fuel not the other way around
I will reverse this tomorrow and go 2 clips the other way...
thats pretty much how my jetting goes nowadays, i change this way...
if worse I go 2 changes the other way, if better I leave it or go back one
screw plug chops
jajjajaja
peace and thanks to all for the help especially kenno
I have a non bored tm38...not 41 like xrsonly sells
my needle is leanest at 6fj41
elsalvadorklr is offline   Reply With Quote
Old 03-05-2013, 05:58 PM   #7177
Kenno
Kenno's Avatar
Oddometer: 793
Air jet removed?
I have 3 TM38 85 carbs, one is 38mm and two are 41mm and they all have the 6FJ40 needles, the 38mm carb has a Q-2 needle/main jet nozzle.
Do you still have the air jet fitted? The two carbs that are running good have them removed but the carb on the shelf still has the air jet fitted but I don't know how it runs.
No air jet fitted to the 38mm TM38 and the bike suffers no flat spots
uuuh
screw plug chops
jajjajaja
Ken
Kenno screwed with this post 03-05-2013 at 07:03 PM
Old 03-05-2013, 07:49 PM   #7178
Huskylove
Oddometer: 54
I had the sudco FCR41 on my XR I had it jetted rich, but every single time, bring it to tdc just a little past one kick of all 140lbs of me and it ALWAYS fired off and never needed the choke. Had instant wheelie torque right off idle. The snap everyone talks about with the fcr carbs is exactly right, once you get it right it is awesome. I had to swap the AP to a crf style to shorten the pump duration (not adjustable) but man that thing ran gooood....
Just sayin if yall are running the stock carb on these beasts time to step it up.
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Old 03-05-2013, 11:28 PM   #7179
RoostMaster
Oddometer: 261
EDIT: Just found these guys too: http://helperformance.com.au/store/p...oducts_id=8431 for $54 AUD it seems like a pretty good price. Might check Ballards to see what there prices are too.[/QUOTE]
Couple of nice pastels in there for real authentic '80's look !
RoostMaster is offline   Reply With Quote
Old 03-05-2013, 11:32 PM   #7180
RoostMaster
Oddometer: 261
Couple of nice pastels in there for real authentic '80's look ![/QUOTE]
http://www.ballards.cc/latest-catalogue
yeeeeep. 130 clammers...
Old 03-06-2013, 07:30 AM   #7181
nikolic
Oddometer: 480
I bought the TM40 but have not started the bike jet. What's the story with the air-jet? I have a pilot 30 and main 140, 100mm piston...
Home rides ;)
nikolic is offline   Reply With Quote
Old 03-06-2013, 08:09 AM   #7182
elsalvadorklr
southern xr rider
Oddometer: 4,154
thats just weird kenno
so is that pasage just blocked up? could I temporarily disable that to see if it works?
Old 03-06-2013, 08:11 AM   #7183
elsalvadorklr
southern xr rider
Oddometer: 4,154
could you show pics of the top of the airbox? what you did to cut it up?
Im thinking about at least doing the side vent mods much like the xr650r guys do
It time to let my bike breathe I guess and I could just get another sidepanel or a used one if I dont like it
I think my hrc cam and flatslide could use more juice up top so maybe jetting fatter AND giving it more iar could help
maybe just maybe
Old 03-06-2013, 08:13 AM   #7184
elsalvadorklr
southern xr rider
Oddometer: 4,154
your tm 40 is very dufferent than our non pumper flatslide tm38 you have an adjustable spray jet pump and other goodies...you willhave fun getting it set right
jajaja
or not
from this pic I see 3 holes or passages with the middle one plugged up
Old 03-06-2013, 10:55 AM   #7185
nikolic
Oddometer: 480
jajaja
or not
I've rebought the TM40 I had on my DR650RS... It was plug and play hope it will be like it agan :)
Home rides ;)
Times are GMT -7.   It's 08:48 PM.
