Old 03-06-2013, 12:05 PM   #7186
elsalvadorklr
southern xr rider
Oddometer: 4,154
I didnt mean it wouldnt work I meant they are different the tm38-85 from the tm40
plug and play indeed its an easy conversion no matter what flatslide you use
good luck!
elsalvadorklr is offline   Reply With Quote
Old 03-07-2013, 01:58 AM   #7187
Kenno
Kenno's Avatar
Oddometer: 736
Hi Christian, if yours does not look like mine then there is a fair chance it may be part of your problem, if you look closely at the hole on the right you can see threads in there but on this 38mm carb there is nothing screwed into it BUT on my 41mm TM38 sitting on my shelf there is a jet screwed into it which would reduce venturi suction at the main and needle jet possibly causing a flat(bog) spot.
Do you have all three holes open on your carb?
Originally Posted by elsalvadorklr View Post
thats just weird kenno
so is that pasage just blocked up? could I temporarily disable that to see if it works?
Ken
"Parts left out cost nothing and cause no service problems" (Kettering)
Kenno is online now   Reply With Quote
Old 03-07-2013, 05:13 AM   #7188
Royal Club
Royal Club's Avatar
Oddometer: 392
could you show pics of the top of the airbox? what you did to cut it up?
Im thinking about at least doing the side vent mods much like the xr650r guys do
It time to let my bike breathe I guess and I could just get another sidepanel or a used one if I dont like it
I think my hrc cam and flatslide could use more juice up top so maybe jetting fatter AND giving it more iar could help
maybe just maybe
I thought about the sidepanel too (the one which acts as filtercover) but decided NOT to do that.
Reason is since you move your leg around a lot on the bike there would be a chance you'd block off the holes which again would cut off airflow, next to that, when riding in open plane you'd might have change in airflow in case of strong side winds..
I'm gonna dyno it next week.. finally
Royal Club is offline   Reply With Quote
Old 03-07-2013, 05:31 AM   #7189
lookfar
from the land of OZ
Oddometer: 618
Does all that chopping REALLY make a difference???
I am only asking because I think that any hole in the airbox larger than the cross-section of the intake runners is pointless, as the intake runners can only flow so much air. And with all the chopping done to the airbox, the possibility of getting a gutful of water into the engine is increased.
I could be wrong, but that is how I see it...
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 03-07-2013, 05:40 AM   #7190
Royal Club
Royal Club's Avatar
Oddometer: 392
we'll find out Tuesday.
Old 03-07-2013, 09:31 AM   #7191
elsalvadorklr
southern xr rider
Oddometer: 4,154
wow what a ride
soooooooooo
got it jetted right
my flat spot or bog comes from bad jetting not from missing any circuits or passages etc...
but thanks for the tips.
this was confirmed yesterday
I had one of my best rides to date...I rode 30 miles of beach or so right to where my boat is jajaja
Met up with some friends and talked crap till sunset and more
the rode street home like a madman up to san salvador, ran out of fuel 2 times and used up super secret reserve and made it to the one gas station that was open just in time
flying 90mph down the beach playing with the water and birds and lofting the front wheel over the little dunes on the left was magic...must of looked crazy to the fisherman and kids that were waving at me like nuts while I was doing it but MAN
what a thrill
no pics, just the ride in my memory jajaja
PS. JETTING changes were this
needle clip to richest setting(makes sense since the dual headers flow better and use a bigger main on stock carb) change from middle clip.
mainjet up to a 230 instead of a 220
Didnt check oil temps cause apparently I was hauling ass too much and the thernometer cap flew off into the wind! jajajaja
anywhoo
a ride to remember
christian
Old 03-07-2013, 09:34 AM   #7192
elsalvadorklr
southern xr rider
Oddometer: 4,154
Oh i forgot!
the wife was pissed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!
crying and everything cause I didnt respond her call while riding back up
slept on a couch with nothing but my boxers
wtf women!
CHILAXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXX: rofl
Old 03-07-2013, 09:45 AM   #7193
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Oh i forgot!
wtf women!
Baby hormones
Mind your step buddy !!
deejay_xr is offline   Reply With Quote
Old 03-07-2013, 09:48 AM   #7194
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Putting the engine back together is on hold for now. I could have sworn I still had a fresh head gasket aswell, turns out I didn´t...
Old 03-07-2013, 10:22 AM   #7195
hallfleming
Oddometer: 19
94 XR600R throwing parts at it, still wont 'rev'
I bought a 95 with a blown motor. Put a motor in it from a donor bike. Previous owner of the donor motor went through the carb 3 times thinking he had carb issues. He ended up thinking it was electrical. That motors stock besides bore 3 over.
I put that motor in my bike. Cleaned the tank, petcock, new fuel line. Clean the carbs (stock jets), replaced every seal, new air filter (uni), stock exhaust with baffle removed and new gaskets. I've tried 2 different cdi's, 2 different stators, 2 different pulse generators, set the valve clearances. I even went back and readjusted the right exhaust valve just past tdc to make sure decompression lever wasn't interfering. The wiring harness and ignition coil, spark plug (new) off the bike with the blown motor.
Results. Bike idles but dips. I can ride it on on 1/4 throttle and walk through all gears and it pulls great. Start to give more throttle and it "bogs" "hicups" "skips" "pops". The spark plug is black and I see dark smoke when I try to rev it. I've tried everything on the idle screw from all in to 3 out. Seems the same. It will die if I turn the idle screw all the way in.
Any thoughts? Think maybe the timing is off just a tooth or so? Maybe cam chain stretched?
Thanks in advance for taking the time to read this..
Hall
hallfleming is offline   Reply With Quote
Old 03-07-2013, 10:23 AM   #7196
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,782
ask MCma111
or just wait Im sure hell be along sometime
or better yet post the question in the xr600r thread...
Sir, you got run over because you were walking to slow for the speed of traffic.
focallength is offline   Reply With Quote
Old 03-07-2013, 10:24 AM   #7197
elsalvadorklr
southern xr rider
Oddometer: 4,154
bummer!
Old 03-07-2013, 10:25 AM   #7198
hallfleming
Oddometer: 19
I've read a lot of his comments and threads. Simply amazing. I wish I was on the other side of the country! Read your thread too from a few years back when he coached you on the rebuild. Good read!
Originally Posted by focallength View Post
ask MCma111
Old 03-07-2013, 10:27 AM   #7199
elsalvadorklr
southern xr rider
Oddometer: 4,154
hell show up in a second
but here are some questions he might ask
what jets are in your carb and what needle setting and are the jets and needle stock
have you done a compression check
verify your timing
check valve clearances
good luck and welcome to the xr6 club!
Old 03-07-2013, 10:51 AM   #7200
bryantjt
Oddometer: 1,012
My Yamaha Warrior ATV did the same thing to me except it was also leaking fuel out of the overflow. Turned out the needle and seat were bad so it was getting too much fuel in the carb.
bryantjt is offline   Reply With Quote
Times are GMT -7.   It's 05:52 PM.
