Old 03-15-2013, 11:55 AM   #7321
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Originally Posted by mcma111 View Post
What your not showing is that pipe as it mounts to the case. I'll bet it's not seated correctly.
Which do you mean exactly? This one?
It's seated correctly.
I think I know what happened.
While back I took out the oil pump, since I didn't wanna take out the entire clutch etcetera I just slightly bent the internal line to be able to get the pump out.
Upon replacing the pump and bending back the line it must have taken a slightly different curvature, resulting in the drivegear rubbing the thing.
Yes I know, not how the people at Honda would like to see it done
I gave the internal line a few firm taps with a small nylon hammer to nudge it further into the case a little, now when I replace the gear it appears to run fully free.
Not too happy with this and myself though...
I'll just file this one under 'live and learn' I guess
deejay_xr is offline   Reply With Quote
Old 03-15-2013, 11:56 AM   #7322
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Originally Posted by elsalvadorklr View Post
word!
the pipe not seating correctly is also part of the reason you are having oil system malfunction and more than likely the reason you topend started starving for oil
also when I replaced those orings I purposely BENT the tang that hold the pipe in place as well as use the best fitting oring even though it might not have been the exact part by honda.
these orings along with the outer crank case seal are so important words cannot describe! jajaja
cheers
Must have me confused with someone else
My top-end is just fine buddy
Old 03-15-2013, 12:08 PM   #7323
mcma111
mcma111's Avatar
Oddometer: 7,981
There is the right way to do something and well, everything else.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-15-2013, 12:48 PM   #7324
deejay_xr
deejay_xr's Avatar
Oddometer: 470
I'm more of a grey area kind of guy
But yeah, live and learn
Old 03-15-2013, 01:08 PM   #7325
elsalvadorklr
Oddometer: 3,960
thought you were reposting a pic of jhons engine, geeze sorry
still you almost killed youre engine jajajaja a little mor grinding an poop
elsalvadorklr is offline   Reply With Quote
Old 03-15-2013, 02:22 PM   #7326
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Sure did, lucky I found this by accident !
Could have ended badly
Old 03-15-2013, 04:33 PM   #7327
Captain115
Captain115's Avatar
Oddometer: 98
Haha, I feel like I'm now the example for problems from oil starvation.
Originally Posted by RoostMaster View Post
Holy Shit Captain. Nothin worse. Hope all that shrapnel is not from gear box hard facing??? Anyone?
Yeah man I hear you, really hope not as well. But as mcma111 says, where else would it come from? Damnit hey
Well the one good thing about all those bits on the pulse generator is that the material wasn't flowing through out the rest of the engine but that may not be good anyway.
OK, I went back and looked at the cam and rocker pictures again. The material isn't from them or the cylinder. There just wasn't enough damage to the cylinder to generate that much stuff.
So where did it come from? I'll bet from the transmission. Was the bike making any kind of whining noise as you rode it?
We will find out shortly when you split the cases.
Whining noises? Well I was whining a fair bit myself. My constant stream of curses, abuse and encouragement drown out a lot of the other noises as I limped it home the last 20kms. But no, I didn't hear it (although I had earplugs in) just that solid knocking noise.
I'm sure we'll talk about this when I split the case, but if the transmission is fucked as well, then will this become to $$$? We'll see I guess.
Re the parts, I was thinking OEM cam (do you or others here suggest the hotcam?).
I would like to keep the compression around stock so 9.1-10.5, with the maximum bore out to 100mm. I'm fairly sure it doesn't have the Nickasil lining anymore, my magnet sticks pretty damn well to it. I was probably going to stick with OEM, Pro-X, JE or Wossner although looking at cost (and possibly reliability) maybe just OEM. Can you get that is oversized?
Head and base gasket will be OEM, crankcase covers I don't care. Something cheap.
I'm still a bit pissed off that I was told (and for that matter the previous owner was told too) that is has a Ballards 630cc kit in it. Lying pricks, a sticker on the swingarm isn't the same as a oversized piston in the bore.
John
PS. Can you split the crankcase without a splitter? Cause otherwise I'm fuckkkked
Captain115 is offline   Reply With Quote
Old 03-15-2013, 05:40 PM   #7328
elsalvadorklr
Oddometer: 3,960
hotcams wtf?
how bout what I told you about? jajajajajaja
good luck
spliitin cases isnt that hard, need a friend or place with an air gun or a helper to hold the clutch basket etc...same for stator wheel, etc...after that its like 11 allen bolts and cases come apart
easy peasy! jajaja someone else says that..I think you know who that is
ps HOTCAMS?????????????????????????????
Old 03-15-2013, 05:46 PM   #7329
mcma111
mcma111's Avatar
Oddometer: 7,981
The only reason to pull the stator is if the crank is coming out otherwise leave it in place.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-15-2013, 06:46 PM   #7330
Captain115
Captain115's Avatar
Oddometer: 98
hotcams wtf?
good luck
Ahhh sorry man, I completely forgot (already I know). So much shit going on with this bike in the space of like 3 days! I should've said, what about the CW cams, and how do they compare to OEM?
Also, for other people who are going to get the clutch off...you don't need a rattle gun or clutch holding tool. Well at least my dodgy ghetto home version didn't: put it in top gear, apply the rear brake and undo the centre nut. Viola, done.
Photos to come soon!
Old 03-16-2013, 12:01 AM   #7331
Swan3609
Swan3609's Avatar
Oddometer: 37
So after I did a very similar thing with my 6er (got toasty mid July and ran out of oil) , I boxed the motor up left for school and decided to deal with it later as I didn't have the time or money to deal with it then.
So I now have some money to deal with it. I really wish I could take this project on myself, but I don't have the supplies to do it here and I want it to be ready for me when I go home for school.
I am thinking that I am going to take it back to the guy that built it back in the 90s and have him do the work unless I find someone else more local to do the work..
I will see if I can dig up my photos of the damage that I found and see what you guys think the guestimated monetary damage will be.
I just want her back together so that I can ride.
EDIT: Hmm.. The old mechanic is located in Chico now.. Which is pretty close to you mcma111.. I am heading that way in a few weeks anyways. Your 650 rebuild makes me think that I might want you to do the work for me.. PM sent..
Sent from my SCH-I605 using Tapatalk 2
Swan3609 screwed with this post 03-16-2013 at 12:43 AM
Swan3609 is offline   Reply With Quote
Old 03-16-2013, 10:04 AM   #7332
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Any suggestions on getting it out? It's almost FUBAR, everything I do one more chip comes off...
It is absolutely beyond me why Honda opted for this method, instead of a hex or something
Old 03-16-2013, 10:14 AM   #7333
mcma111
mcma111's Avatar
Oddometer: 7,981
Drill a small hole off to one side, you don't have to go all of the way through and beat it with a punch.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-16-2013, 10:45 AM   #7334
Royal Club
Royal Club's Avatar
Oddometer: 296
2euro coin and a pipewrench? (waterpomptang..)
Royal Club is offline   Reply With Quote
Old 03-16-2013, 11:52 AM   #7335
deejay_xr
deejay_xr's Avatar
Oddometer: 470
Tried it, no cigar...
What I was thinking, I'll try that later on.
Good news is, I found a used one at a wrecker of the old type, i.e. with a hex instead of the slot. Apparently they DO exist
Times are GMT -7.   It's 12:27 AM.
