03-16-2013, 02:57 PM
#7336 |
Oddometer: 7,965
The hex is the new design and the slot is the old.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
03-16-2013, 04:01 PM
#7337 |
Oddometer: 470
03-16-2013, 04:08 PM
#7338 |
Oddometer: 78
Anti-seize
Use and lot of anti-seize on your new one and don't over torque. I had to take the side cover off to get a easy-out in far enough to get mine out.
03-16-2013, 04:25 PM
#7339 |
Oddometer: 293
Did your hex wrench fit snug? I ordered a new cap from CMSNL in HEX shape and my Metric hex wrench wont fit properly, the hex in the cap is a bit bigger..
03-16-2013, 04:31 PM
#7340 | |
Oddometer: 470
Stupid... Don´t know yet, the guy will be mailing it this week |
03-16-2013, 04:35 PM
#7341 | |
Oddometer: 293
http://www.cmsnl.com/honda-xr600r-19...m_90087mn1670/ |
03-16-2013, 04:41 PM
#7342 | |
Oddometer: 470
This´ll save a boatload on shipping and customs since they´re based in The Netherlands. What´s your experience with them? Edit: HOTDAMN they're expensive ![]() Did a little comparison on some parts I've ordered from the States in the past, some are about the same and then some are stupid expensive ! |
03-16-2013, 04:44 PM
#7343 |
Oddometer: 96
Gotta grab a 30mmm socket so I can undo the primary drive nut and then I'll be able to split the cases today hopefully.
There's a fair bit of that metal from before sitting on the bottom of the crankcases, near where the internal oil screen sits. Had a look at the clutch basket and it is slightly notched...what's the general consensos in lightly sanding these down a little? I know some people swear by it, others reckon you should just buy a new basket (which is definitely not happening). The clutch worked fine when it was running, really heavy but smooth. Also the bottom of the basket where the first of the plate sits is quite scratched up, does this matter at all? Thanks, John PS, mcma111 what grease do you use in your 'building a XR650L engine' thread during the assembly? Like the green stuff you use to hold various washers and dowel in place? Captain115 screwed with this post 03-16-2013 at 04:49 PM |
03-16-2013, 04:53 PM
#7344 | |
Oddometer: 470
Do you have a pic of the scratches ? |
03-16-2013, 06:04 PM
#7345 |
Oddometer: 7,965
Bel Ray waterproof grease. Good stuff. Use it for everything.
http://www.belray.com/bel-ray-waterproof-grease Clutch basket. Go ahead and file the notches down.
03-16-2013, 06:26 PM
#7346 | ||
Oddometer: 293
03-16-2013, 10:58 PM
#7347 |
Oddometer: 96
Alright so the case is split.
First off, bulk metal shards: ![]() Secondly, I took the transmission out, slipped and a variety of the cogs cam off onto the bench. Softly mind you, but now I'm not 100% of the order. ![]() I used the 'building XR650L engine' thread to help but my main question is do the smaller dogs slot into the indented side or the less indented side? I was thinking more indented (as can be seen in the photo below on the right) so the smaller gear is more fully 'inside' the larger one? ![]() My shitty paint example: ![]() Also, what am I looking for in the gears to know if they need to be replaced? Because after a quick glance, there does not seem to be any that are obviously destroyed...so where did the metal come from then?? Cheers, John |
03-17-2013, 04:15 AM
#7348 |
Oddometer: 7,965
Captain,
Does it look like the cases have ever been apart? Perhaps all that metal is from a prior melt down and the PO didn't open the cases to clean it up. Here is the transmission layout:
03-17-2013, 04:16 AM
#7349 |
Oddometer: 7,965
03-17-2013, 04:26 AM
#7350 |
Oddometer: 293
http://www.motor-forum.nl/forum/list.../#zwakkepunten
scroll down a bit
