Old 03-22-2013, 04:04 PM   #7486
Royal Club
Royal Club's Avatar
Oddometer: 297
So,
I allmost don't want to ask this.. I know its been asked a zillion times, but all I read is people arguing on what is right...
I have a COURSE spline countershaft.
this model.
My sprocket has a flat side and a side with a lump..
which side goes outwards??
I have it set OUT-wards at the moment, the rear sprocket/chain/front sprocket/ seem to align pretty good..
Royal Club is offline   Reply With Quote
Old 03-22-2013, 04:32 PM   #7487
lookfar
from the land of OZ
Oddometer: 253
Originally Posted by Royal Club View Post
So,
this model.
I have always had the flat side to the outside.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL600R
1988 XR600
lookfar is offline   Reply With Quote
Old 03-22-2013, 04:51 PM   #7488
Royal Club
Royal Club's Avatar
Oddometer: 297
this is my old sprocket, used with the flat side out. as you can see the sprocket has wear toward the engine.. dunno how to describe it correctly, the wear directs toward the engine.. the other side is pretty clean, no strange lumps and strange wear..
Old 03-22-2013, 06:31 PM   #7489
Captain115
Captain115's Avatar
Oddometer: 99
Alright so my current parts list:
Wiseco 98mm 11:1 Piston..................$142
OEM Honda Cam...............................$112
4x OEM Honda Rockers.....................$128
OEM Honda Cam Chain.....................$70
Bore and hone...................................$70
Cosmetic 98mm Top End Gasket Kit...$29
Cosmetic Bottom End Gasket Kit........$35
BikeMaster Magnetic Drain Plug..........$7
Plus a million dollars for the fucking transmission
Anything I'm missing?
John
Captain115 is online now   Reply With Quote
Old 03-22-2013, 07:32 PM   #7490
lookfar
from the land of OZ
Oddometer: 253
Got a pic of the other side?
Stu in FNQ
1985 XL600R
1988 XR600
Old 03-23-2013, 04:00 AM   #7491
Royal Club
Royal Club's Avatar
Oddometer: 297
Old 03-23-2013, 04:06 AM   #7492
lookfar
from the land of OZ
Oddometer: 253
Definately flat side out...otherwise the locking collar can't be bolted properly to the sprocket...
Stu in FNQ
1985 XL600R
1988 XR600
Old 03-23-2013, 04:24 AM   #7493
Royal Club
Royal Club's Avatar
Oddometer: 297
Then why does the sprocket have such strange wear on it?
Old 03-23-2013, 04:29 AM   #7494
deejay_xr
deejay_xr's Avatar
Oddometer: 470
John
How's the con rod and big-end bearing, and is it the factory rod or was it already replaced? I forget.
It might not be a good idea to run 11:1 compression on the factory rod...
IF you're going to swap out the rod, add two new crankshaft bearings to the list.
I would atleast change all the seals in the cases aswell as the gaskets, since you're splitting them anyway.
Gasket kits contain all kinds of o-rings, but not the seals.
Get a new camchain tensioner spring, just in case. They're like 3 bucks.
Oh, and add an oil filter and 3 liters of quality oil to your list
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 03-23-2013, 04:30 AM   #7495
lookfar
from the land of OZ
Oddometer: 253
Slight misalignment between the front and rear sprockets. Could come from anything...rear wheel not set properly in swingarm..bent swingarm...twisted frame...etc.
Stu in FNQ
1985 XL600R
1988 XR600
Old 03-23-2013, 05:53 AM   #7496
Captain115
Captain115's Avatar
Oddometer: 99
Thanks deejay! The rod is Pro-X, no idea when it was replaced but looks good and no vertical play (though a little side to side but I gather this is normal).
What do you mean by the seal, sorry? I'll replace them if you reckon it's worth it, I just don't know what they are! Cam chain tensioner spring is a good one, I'll add it to the list.
I bought 8L of mineral oil today since the local auto shop was having a special on, saved about $35. Supercheap auto for those in Australia, $28 for 4L of Castrol Activ 4T!
And embarressingly I already have a spare oil filter...I bought it for the first oil change I was going to do at 500 km...but it never got there
But yeah I can get 4 of them for $13 from the site so I'll order a bulk amount while I'm there.
So: new seals (?), new tensioner spring and new filters...what else?
Thanks man,
John
Old 03-23-2013, 07:04 AM   #7497
elsalvadorklr
Oddometer: 3,960
John
is the wiseco true 11.1 or less? youre going all out man!
not a fan of the magnetic plugs, they are hollow and break using normal torque, you can make one yourself thats stouter.
good luck!
elsalvadorklr is offline   Reply With Quote
Old 03-23-2013, 07:07 AM   #7498
elsalvadorklr
Oddometer: 3,960
are you using the same numbers on the chain snail adjusters?
you must measure from axle to a fixed point on the frame or swingarm to see if your rear wheel is straight...a lot of times the adjusters are the cause of problems with bad wear at the front sprocket...
one assumes that equal numbers equals a perpendicular axle but no, you must measure
or you have a tweaked frame
Old 03-23-2013, 08:02 AM   #7499
joexr
joexr's Avatar
Oddometer: 750
good luck!
I think the Bikemaster drain plugs are steel.
Old 03-23-2013, 08:54 AM   #7500
Royal Club
Royal Club's Avatar
Oddometer: 297
Yeah I am, and as said, from the looks of it the chain and sprockets are aligning..
Times are GMT -7.   It's 05:55 AM.
