Old 03-25-2013, 07:36 PM   #7531
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by Captain115 View Post
Thanks for that Royal, I've been wanting to see if I could run a brighter light than the 35W one. Might grab that bulb you mention.
Also, sweet looking XR!
John
Thanks broski!
Make sure you buy the HALOGEN light one!!!! the cheaper one runs a oldskool bajonet fitting (same as stock..)
And make sure your stator can run it!
Tomorrow (today already, its 2.37 am..)is the dyno day.. wish me luck.. Hope the piggy will survive it!!!
Royal Club screwed with this post 03-25-2013 at 07:43 PM
Royal Club is offline   Reply With Quote
Old 03-26-2013, 09:30 AM   #7532
elsalvadorklr
southern xr rider
Oddometer: 4,154
good luck man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!: D
elsalvadorklr is offline   Reply With Quote
Old 03-26-2013, 11:32 AM   #7533
deejay_xr
deejay_xr's Avatar
Oddometer: 496
And? How did the piggy fare on the big bad dyno?
Did you just do a baseline check for the hell of it, or did you take it to the dyno to finetune the carb and whatnot?
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 03-26-2013, 12:44 PM   #7534
Royal Club
Royal Club's Avatar
Oddometer: 392
Piggy survived!
36Hp / 50NM
DIN power / DIN Torque.
With the open airbox it GAINED 2hp!!!!!
I adjusted the mixture screw a little bit since it was running a little lean, other than that just took off my airbox cover tape (had it masked till i'd get to the dyno).
With the the airbox "closed" it had a little dip @ 6800rpm but it was due to a slight too big main jet. with the airbox open it revved all the way up with no problem to 7300rpm.
When pulling the tape on the box I "lost" 1nm, but that could be due to acceleratorpump setting. The dude agreed that finetuning the acc. pump would solve that little loss.
Wiseco11:1
hotcam stage1
FCRMX40
Open airbox.
stock 2in1steel header
I'm pretty sure the pig will gain some HP when using an aftermarket header.
Royal Club screwed with this post 03-26-2013 at 12:52 PM
Old 03-26-2013, 02:18 PM   #7535
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Originally Posted by Royal Club View Post
36Hp / 50NM
Dafuq
Depending on your source it supposedly made 43 or 46 hp stock
The specifications are probably exagerated, and maybe they mention crankshaft hp instead of rear wheel hp which would make a substantial difference, but how can it have 36 hp after these mods?
Old 03-26-2013, 05:42 PM   #7536
LandsVW
LandsVW's Avatar
Oddometer: 297
Here she is...
Here's my thread:
http://advrider.com/forums/showthread.php?t=835547
thanks all, for the help and parts.
(I ignite the engine)
(and ride into the sunlight)
(My dust-trail never quite catching me) -LFN 2008
LandsVW is offline   Reply With Quote
Old 03-26-2013, 06:43 PM   #7537
Royal Club
Royal Club's Avatar
Oddometer: 392
Dafuq
as I mentioned, stock header :)
Old 03-27-2013, 05:12 AM   #7538
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Yeah, the numbers the interwebs mention are completely stock too, so header & muffler.
I find it hard to believe that a high comp piston and aftermarket cam will make less power with the steel header than the original setup would have.
What's going on here fellas ?
Can anyone chime in on whether the original numbers were THAT much exagerated or not?
Old 03-27-2013, 05:59 AM   #7539
Royal Club
Royal Club's Avatar
Oddometer: 392
I can promise you a stock XR will NOT make anywhere near 43hp stock,
see this reply
http://www.thumpertalk.com/topic/252.../#entry2087191
And remember there are a LOT of dynos that are a little positive when reading power..
besides, its not the power it makes, its how you use it :)
Progress is far more interesting compared to peakpower.
also see these
http://www.thumpertalk.com/topic/929.../#entry9712206
http://www.thumpertalk.com/topic/929.../#entry9712856
Old 03-27-2013, 06:05 AM   #7540
fiep
fiep's Avatar
Oddometer: 1,938
does it make any difference what number the dyno puts out?
honestly?
if you NEED MORE POWER
get a modern bike with a lot more power bone stock
but will that make you faster?
and (to me) more important:
will that make you happier?
am in need of a spedo plus cable plus drive
maybe an original headlight cowling + headlight
and heat shield for the headers
for the 86 I am trying to restore back to it's original beauty
if you have something flopping aroud
and are wiling to part with it
without breaking the bank,
please
please
there are enough mutilated XRs out there
I am on the quest
restore them back to stock
fiep is offline   Reply With Quote
Old 03-27-2013, 06:10 AM   #7541
Royal Club
Royal Club's Avatar
Oddometer: 392
I rode a 2001 Fazer 1000 for the last 6months, and yea, I do notice the power difference, but the XR is so much more fun to ride!!! peak power does not equal fun.
Old 03-27-2013, 07:49 AM   #7542
fabrizio
fabrizio's Avatar
Oddometer: 9
on the topics of sprockets....
greetings pals,
I am new to the XR600R community but i bought an 86 this past fall and have been restoring it and turning it slightly more supermoto-ish. I intend to do mostly street riding and i am switching to a 19" front wheel and a 18" rear.
is there anybody out there that could advise towards if any sprocket combinations?
I will be feeling it out this spring/summer when i get it on the road but i was wondering if anybody had any experience on the matter and could weigh in.
thanks kindly.
fabrizio is offline   Reply With Quote
Old 03-27-2013, 08:12 AM   #7543
deejay_xr
deejay_xr's Avatar
Oddometer: 496
I'm not one of those 'pissing contest' guys that's all about having more power than the next guy and rubbing it in, far from it.
A friend of mine is like that, rides a GSXr 1100 and is all pissy about me not being able to keep up with him on the straights.... gee you think?!?
Gets all childish when I tell him he looks like a clown dragging that lump through tight corners
Atleast he's a good guy other than that...
I was just genuinely suprised to see how big the difference is between what the internet will have you believe and reality.
The articles Royal posted clear up some confusion.
I suppose the factory numbers would atleast HAVE to be crank hp's instead of wheel hp's to explain the discrepancy
I've had more powerful bikes aswell during the time I've had my XR, this is the one I kept
deejay_xr screwed with this post 03-27-2013 at 08:22 AM
Old 03-27-2013, 09:12 AM   #7544
mcma111
mcma111's Avatar
Oddometer: 11,896
Originally Posted by fabrizio View Post
greetings pals,
thanks kindly.
14/42 or 15/42 for more hiway usage
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-27-2013, 10:04 AM   #7545
deejay_xr
deejay_xr's Avatar
Oddometer: 496
greetings pals,
thanks kindly.
Welcome !
What Steve said
I run 15/42 on a 17" wheel, it works for me.
It's still a little bit buzzy on the highway, but I don't do long strectches of highway often, so this is a good compromise.
If you use an 18" wheel it should be even a little less buzzy
Times are GMT -7.   It's 06:23 PM.
