Old 03-30-2013, 12:57 PM   #7591
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Originally Posted by mcma111 View Post
These are going on my XR
Sweet !
Is that anodized or powder coat?
'87 XR600R, 17's and fully black
deejay_xr screwed with this post 03-30-2013 at 01:02 PM
deejay_xr is offline   Reply With Quote
Old 03-30-2013, 01:35 PM   #7592
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,510
Originally Posted by deejay_xr View Post
Sweet !
Anodized. Besides mentioned in the XRL thread, the detail is the other give away on the top. Powdercoating "blurs" the details.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 03-30-2013, 03:20 PM   #7593
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by RoostMaster View Post
Mate of mine has an old XT600 that had a strange miss on idle, every 20 or so seconds it would hiccup and briefly cut out before continuing on idling...
Mechanic suggested that a valve was leaking, only when that valve rotated to a position where the mate against the seat was foul... ie: every time it rotate to the 12 o'clock, if briefly missed. I never have thunk it !
thats EXACTLY what my first thought was...
the worst case scenario is a loose valve seat OR bent valves...timing is good though...since I just reinstalled my oem cam and rocker set.
thanks for the help I will let you guys know as soon as SEMANA SANTA or holy week is over
holy week means beer week down here! jajaja
elsalvadorklr is offline   Reply With Quote
Old 03-30-2013, 04:46 PM   #7594
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Cheers then !
Old 03-30-2013, 06:05 PM   #7595
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Ah yes, I see it
Old 03-30-2013, 09:33 PM   #7596
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Valve rotation is not an uncommon occurrence, but one revolution every 20 seconds is extreme for idle speed.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 03-31-2013, 10:38 AM   #7597
Royal Club
Royal Club's Avatar
Oddometer: 392
ffffffffffuuuuuuuuuuuuuuuuuu
gonna heat the linkpipe and bend it a bit inwards and give it a new clamp..
Royal Club is offline   Reply With Quote
Old 03-31-2013, 12:09 PM   #7598
elsalvadorklr
southern xr rider
Oddometer: 4,154
carboned up?
Im going to try to mist the intake since this all happened after a ride with low quality 87 gas down here, thats all I could find...of course the bike handled it fine but with the hrc cam and whatnot maybe I carboned it up way to much and now my seats and head are all carboned up and therefore not sealing 100 percent of the time..
just me thinking out loud here. I really dont want to tear the engine down again for craps sake...especially since my rocker cover does NOT leak now jajaja
so
water intale throttle fun coming soon1 jajaja
if it improves just a bit then I know I can try some seafoam or similar stuff and run some super high octane gas and boost
maybe just maybe it will clean it up
I DOUBT IT THOUGH JAJAJAJAJAJA:ro fl
Old 03-31-2013, 12:11 PM   #7599
The Dogger
Oddometer: 148
Compressing piston rings
Evening all
I'm having a bit of trouble compressing the piston rings . I've got a ring compressor , the sort that has a square key on the side to ratchet it up . For "small engines" with a piston size of between 53 mm & 125mm
Am I right in thinking that the new piston is fitted to the rod , then the barrel is slid over it ? ( with compressor in place ?? ) If so , how do I remove the compressor ?
You tube vids show the piston and rod being dropped into place together during a full rebuild process ( admittedly for a car rebuild )
I've had a look at Steve's excellent rebuild thread http://www.advrider.com/forums/showthread.php?t=713831 ( which inspired me to have a go at this myself ) but I can't work out how to get the tool off , or to be honest , how to get the rings into the barrel with the tool in place
Cheers , Stu
Any help greatly appreciated
The Dogger is offline   Reply With Quote
Old 03-31-2013, 12:20 PM   #7600
elsalvadorklr
southern xr rider
Oddometer: 4,154
here is what has worked for me, and I dont use any special tools just patience beleive it or not
1. drink a nice cold beer
2. clean barrel nicely
3. do not oil anything but the piston skirt bottoms, I have become a huge fan of dry fitting a pistion and rings now after seing those nice japanese fellows man dangle and install xr600 pistin dry as well you know on youtube vids, sekei something they are called.
4. install piston with all rings on rod...lube pin rod
5. jack the rod on both sides with some wood and balance the piston bottooms on it so the piston and rod combo stands alone by itself
6. with completely dry barrel and gasket installed I have luck by compressing the rings individually while jiggling back and forth from front to back. I have small fingers so I can usually feel the ring ends or gaps and thats where I compress, then I push down on barrel a bit, then compress mid riungs, the do the same till you get to the top ring.
I also break in the engine with a lot of engine compression DOWNHILL and nic long streteches of proggresive throttle
this method works great. I had a bad experience on my first rebuild and over oiling everything and among other things I had bad sealing rings that never did their job...
cheers
Old 03-31-2013, 12:43 PM   #7601
The Dogger
Oddometer: 148
cheers
Cheers Christian
1. Beer......... sounds good so far
2.Ok , ..........after beer
3.Bugger , just oiled it . Back to youtube I go ( with beer )
4.Ok
5.Got a wooden support made up ready
6.In the order Ring 1, Ring 2 , Oil Ring ( top to bottom , no ? )
I'd tried it by hand , but the oil didn't help .
Thanks , and good luck with your bike
Old 03-31-2013, 12:48 PM   #7602
elsalvadorklr
southern xr rider
Oddometer: 4,154
yeah oil does NOT help with the hand install
if you dont want clean all oil you can also simply use metal zipties the thicker the better and loosely compress them like steve shows, you install over rings overlapping in a sense loosely then you install barrel over rings and ziptie(Im brain farting here, metal clamp or 2 is what I mean) and then you push down on barrel top firmly and more often than not you go straight in}
MAN DOES THIS SOUND LIKE SEX OR WHAT? jajaja
sorry
Old 03-31-2013, 01:25 PM   #7603
The Dogger
Oddometer: 148
Jubilee clips ??
By overlapping , do you mean a bit of the ring sticking out of the top ( of whatever works to compress it ? ) . They're 1.2mm & 1.5mm wide , not sure if my eyes are up to that
Looking back at Steve's thread , I omitted to check the ring gaps , now I'm worried that the rings are too big / or the gap's not big enough . It's a JE Piston , btw
Cheers , Stu
Old 03-31-2013, 03:51 PM   #7604
Dino3310
Oddometer: 673
Originally Posted by Royal Club View Post
I still have to try using a heatgun to get it a bit glossy, its all matte now.
i just use the odd spray and wipe with silicon 808 to keep her semi glossy, but hey its an XR rough and dirty looks good too
Dino3310 is offline   Reply With Quote
Old 03-31-2013, 03:54 PM   #7605
joexr
Oddometer: 3,773
Originally Posted by The Dogger View Post
Jubilee clips ??
Cheers , Stu
Put each ring in the cylinder by itself and slide the piton in to square the ring up in the cylinder. Remove the piston , leaving the ring. Now measure the end gap.
Times are GMT -7.   It's 02:08 AM.
