Old 03-31-2013, 03:59 PM   #7606
mcma111
mcma111's Avatar
Oddometer: 12,275
Dogger,
Use a 4" or 100mm hose clamp. Once the cylinder is on the piston you can unscrew the clamp and remove it. The hose clamp is just wide enough to compress all of the rings.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-31-2013, 05:02 PM   #7607
Royal Club
Royal Club's Avatar
Oddometer: 392
so, ended up grinding a slit halfway through the linkpipe, bending it over, and welding it shut.
Royal Club is offline   Reply With Quote
Old 03-31-2013, 06:50 PM   #7608
RoostMaster
Oddometer: 254
Originally Posted by HeadTrauma View Post
Valve rotation is not an uncommon occurrence, but one revolution every 20 seconds is extreme for idle speed.
I have no idea how fast a valve rotates.... just for an explanation... there was a terrific clip on youtube that had a slow mo valve rotating on running engine but can't find it.
RoostMaster is offline   Reply With Quote
Old 04-01-2013, 01:40 AM   #7609
The Dogger
Oddometer: 143
Originally Posted by joexr View Post
Put each ring in the cylinder by itself and slide the piton in to square the ring up in the cylinder. Remove the piston , leaving the ring. Now measure the end gap.
Thanks , that's the bit I omitted from Steve's thread. Just checked them , the top 2 needed a little adjustment , oil rings were in spec.
Cheers
Edit : Broke the 2nd ring getting it off again ............woeful attempt at re-checking
The Dogger screwed with this post 04-01-2013 at 03:23 AM Reason: Update
The Dogger is offline   Reply With Quote
Old 04-01-2013, 01:48 AM   #7610
The Dogger
Oddometer: 143
Originally Posted by mcma111 View Post
Dogger,
Thanks Steve
OK , I'll go and get one.......it's a 100mm piston , so I'm guessing to get a clamp slightly over that ?
I'll add the ring compressor to the pile of CoolTools tm in the Man Cave that will never get used again
Cheers
Old 04-01-2013, 01:58 PM   #7611
elsalvadorklr
southern xr rider
Oddometer: 4,154
yay
leaky valves and head for me!!!!!!!!
elsalvadorklr is offline   Reply With Quote
Old 04-01-2013, 04:04 PM   #7612
mcma111
mcma111's Avatar
Oddometer: 12,275
Damn it Christian.
I just wish you were up here and a little closer so taking care of you was easier.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-01-2013, 04:53 PM   #7613
elsalvadorklr
southern xr rider
Oddometer: 4,154
Damn it Christian.
noooooooooooooooooooooooooooooooooooooooooooo
shhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhh
icago
yeah tell me about it...is it something I do to the bike? jajja doubt it
bad luck thats all
Old 04-01-2013, 07:58 PM   #7614
Huskylove
Oddometer: 54
I could take care of him via ups
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Old 04-01-2013, 08:14 PM   #7615
elsalvadorklr
southern xr rider
Oddometer: 4,154
you dont think I would of done this by now if it were easy to do? jajajaja
hey I need an engine, complete, plug and play for my bike no hassles just ship it in a cooler...done
yeah right! jajajajaja I wish
Old 04-01-2013, 08:34 PM   #7616
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,262
A little more carb tuning
I was out riding lots of highway last weekend and suspect I am rich on the pilot jet. Running at about 1/2 throttle, stock gearing, 55-65 MPH on level ground I get a miss. If I am pulling a hill, it is less. WOT and it is go, go, go. I had dropped the needle a while back and things improved, but still persist. Don't want to lean it out too much, just seems to need to be a bit leaner. To verify, I added some choke at speed and the condition did not improve. This is with a stock Keihin, 100mm piston, slightly ported head, S/S exhaust with SuperTrapp. I do need to take the carb off again to get all of the jet sizes documented. The only change that was made since the needle change was taking a few discs out of the 'Trapp, so maybe that makes it a little richer again, no? What do you kids think?
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 04-01-2013, 08:50 PM   #7617
Huskylove
Oddometer: 54
Is shipping to El Salvador a problem? Just curious.
Old 04-02-2013, 04:24 AM   #7618
mcma111
mcma111's Avatar
Oddometer: 12,275
Shipping to El Salvador is not so much a problem as it is expensive.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2013, 09:48 AM   #7619
Royal Club
Royal Club's Avatar
Oddometer: 392
got a new headgasket, for myself that is
Old 04-02-2013, 10:33 AM   #7620
elsalvadorklr
southern xr rider
Oddometer: 4,154
sorry for the snip, yeah big stuff is a no go unless you have somebidy with a freight company, and I dont
we have had awesome luck with steve on some things...I even had a gas tank sent down by 4strokesonly...
its all a toss up, sometmes you pay up the wazoo like those custom stainless spokes for my rear drum 18 inch excel and sometimes you pay nothing like used parts or even the tank for some reason
shipping a 100lb engine in a crate would easily cost 1500 plus the hassle of regsirering it and changing numbers blah blah blah
anywhoo
good luck selling the engine, I cant imagine it lasting long!
cheers
Times are GMT -7.   It's 03:49 PM.
