Old 04-02-2013, 11:02 AM   #7621
elsalvadorklr
southern xr rider
Oddometer: 4,154
hey dudes need some quick info before taking the head to the machine shop for a once over
what is the oem freelength of the valves both intake and exhaust. These are kibblehites
2. what would be a tell tale sign my valve seats are the issue? the valves do not appear sunken into the head, but I had zero lash on my valves meaning either they are sinking a bit but not obvious OR the stems are stretching.
3. has anyone had luck getting new seats cut at joe blow machine shop? jajajaa
I might be able to use my oem valves...
thanks
peace
elsalvadorklr is offline   Reply With Quote
Old 04-02-2013, 11:19 AM   #7622
mcma111
mcma111's Avatar
Oddometer: 12,435
You know the stems did not grow in length. Most likely reason for the zero lash is of the parts settling in after getting a heat cycle through them.
But then again maybe not. Shit happens. As your all to aware of.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2013, 12:23 PM   #7623
elsalvadorklr
southern xr rider
Oddometer: 4,154
well I can prove you wrong at least a bit
my kibllewhite intakes are indeed longer than my oem intakes...fo fidgure
so the stems stretched or?
I can visually see the valves are longer...
the faces are thicker than oem however
so I have my oem valves all of them...
cut seats and install them? orrrrrrrrrrrrrrrr?
Old 04-02-2013, 12:29 PM   #7624
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Originally Posted by Royal Club View Post
got a new headgasket, for myself that is
Stylish
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 04-02-2013, 01:18 PM   #7625
elsalvadorklr
southern xr rider
Oddometer: 4,154
nice helmet!
hey I lost my xr600 manual link soooooooooo
can anyone verify these numbers for me?
intake valve length: 105.79mm
exhaust: 104.34
31/36mm combo oem
thanks
Old 04-02-2013, 01:28 PM   #7626
mcma111
mcma111's Avatar
Oddometer: 12,435
I'll try when I get home. About an hour.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2013, 01:38 PM   #7627
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks bud
off to the machine shop and a beer run.........................see what they say, maybe the seats are cuttable and I can get away with the oem valves
well see!
couple of errands and whatnot
cheers guys
Old 04-02-2013, 03:05 PM   #7628
mcma111
mcma111's Avatar
Oddometer: 12,435
Valve Length
I can't get to my service manuals. Blocked by to much STUFF. I checked my on-line manual and a spec is not given. It really doesn't matter as the screw adjusters take up any slack.
Looking at that manual and your statement that you had zero clearance all the way around could be the source of the stalling.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2013, 04:44 PM   #7629
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,435
I pmd him the info.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 04-02-2013, 10:05 PM   #7630
Captain115
Captain115's Avatar
Oddometer: 287
Gaskets!
Ok people, lets talk gaskets!
I need an oversized head gasket because of the 98mm piston,yes? Which Honda don't make.
So I was going to get the Cosmetic top end gasket kit, which comes with the correct sized head and base gaskets.
Rocker cover will be cleaned and Hondabonded, ala Steve's gasket sandwhich method (see here)
Now bottom end: should I go the Cosmetic base gasket kit? Is OEM better?
More importantly, if the kit only contains the side and central crankcase gaskets, why is it more expensive ($47) than buying each of the OEM gaskets separately (total of $38)???
Finally, what's the go with sealant? From what I read, the crankcase gasket go on dry, the base gasket is dry bar some sealant near the central split due to the case, head gasket is dry, rocker cover is sandwiched as mentioned above. Does this sound right?
The sealant on the base gasket near the case split, should is be Hondabond HT? Or just normal Hondabond?
Impart your wisdom other XR owners!
Cheers,
John
Whats a thread without photos? So here's the current spread of the rebuild:
Captain115 screwed with this post 04-02-2013 at 11:03 PM
Captain115 is offline   Reply With Quote
Old 04-02-2013, 10:19 PM   #7631
elsalvadorklr
southern xr rider
Oddometer: 4,154
yamabond, honda bon, etc, great...
for the case splits and grommet exits I have been using mega grey lately by permatex which is abundant down here and does great
the only places you need sealant are
grommets stator and pg
case center gasket at rear where cylinder meets
some manuals say seal cam chain tunnel...
other than that its DRY if using oem equivalent
I have had good luck now using grease on one side and dry on the other side on such gaskets as the clutch cover gasket as it makes resuing much easier
also do NOT use any sealant on head gasket....I have however succesfully use COPPER SPRAY that goes on dry and tacky on 2 head gaskets and they sealed nicely...maybe a small weep but no effect on peroformance and or leak of air.
cheers
best complete gasket rebuild kit can be bouht on EBAY....k and s kit.
Old 04-02-2013, 11:48 PM   #7632
RoostMaster
Oddometer: 258
Royal STIG ?
RoostMaster is offline   Reply With Quote
Old 04-03-2013, 03:53 AM   #7633
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by RoostMaster View Post
Royal STIG ?
tbh, I received a free smoked visor with the helmet, just have to pick it up.. so yeah, royal stig it is!
@ gasket story, I used a athena top end set and just mounted it.. 98mm wiseco..
Royal Club is offline   Reply With Quote
Old 04-03-2013, 04:25 AM   #7634
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Sorry, couldn't resist
You are correct, only a dab of sealant at the crack under the base gasket, I did it front and back.
If OEM is cheaper than Cometic, I'd go with OEM. However if you can get a complete set with seals aswell from K&S or something that might be the way to go.
Like Christian said, never use silicone sealant on your head gasket. From the pictures of your teardown It looked like the PO ignored that one.
Old 04-03-2013, 07:12 AM   #7635
elsalvadorklr
southern xr rider
Oddometer: 4,154
gaskets and my rebuild! again! jajajaa
good luck!
so on a side note Im almost doing a rebuild myself and will be reusing some gaskets...
again Ill let you know what works and what doesnt:
stem seals can be reused if you are careful on install and twist while you install...
valve cover gasket if metal can be resused using steves sealant sandwich technique
head gasket can be reused if copper and you anneal or if its laminated and you use some sort of dry copper spray, or aluminum etc..
Ill see when I get her done
ps. my issue was BADLY PITTED (dirt, humid air? saltwater from beach riding? possibly) valve faces and non proper face to seat contact, in other words the valve cutting and grinding performed originally was not up to par...as was what made it worse.
my machinist said that my kbs were not bent or stretched enough to throw away, and said they were still better to fix than my oem ones cause they had more meat on the faces and would stick out more.
anywhoooooooooooooooooooooooooooooooo
Times are GMT -7.   It's 01:47 AM.
