Old 04-10-2013, 04:39 AM   #7741
mcma111
mcma111's Avatar
Oddometer: 12,446
Originally Posted by kirbi69 View Post
after a harsh winter here in south texas on the coast... (mid to upper 50's) i am ready to ride again now that its not so cold :p
i need to put my horn back on and go through my wireing harness and buy a new battery to get my tags renewed. but im BACK!!!
You don't ride because it's in the 50's???
It's like that all the time here. I ride EVERY day. Rain or shine.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-10-2013, 05:56 AM   #7742
elsalvadorklr
southern xr rider
Oddometer: 4,154
^^^^ôooooooooooooooh quit bragging
I get cold if it gets in the 70´s down here! ajajajajaja
I will ride rain and beat the crap out of ya thats for sure!!!!!!!!!!!!!!!!
sidways rain, upwards rain, you know like forrest talked about in GUMP! jajajajaja
bikes back in business btw with my super duper ultra maximus fantabulous external oil pipe gizmo!!!!!!!!
yay
elsalvadorklr is offline   Reply With Quote
Old 04-10-2013, 08:59 AM   #7743
elsalvadorklr
southern xr rider
Oddometer: 4,154
new high temp braided oil line yay!
notice tanning of the stainless pipes already! jejejejeje
later dudes
Old 04-10-2013, 09:06 AM   #7744
deejay_xr
deejay_xr's Avatar
Oddometer: 496
That's one way to go !
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 04-10-2013, 09:23 AM   #7745
elsalvadorklr
southern xr rider
Oddometer: 4,154
sure is!
better than that stupid kinky bent honda line...!!!!!!!!!!!!!!
I will be doing an oil cooler too, except I will be using swaged banjo bolts and stuff same hose
cheers
Old 04-10-2013, 02:40 PM   #7746
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,219
later dudes
NICE MOD! Did you just cut an OEM oil line? Do you think it makes a difference in flow or volume?
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 04-10-2013, 04:10 PM   #7747
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks Jeff!
there is a reason I did not modify the banjo bolts and that is in order to maintain stock flow or flow of volume if you will
If I had a bad ass hrc pump and reversed oil orifices in the case then yeah its recomended to drill out the upper banjo bolt holes equal size and match them to the LOWER banjo bolt hole sizes
the reason I did it this way is
1. there are too many bends and kinks and dents in the stock oil pipe and its also metal and more prone heat, its also thin!!!!!!!!!!!!!!!
mine was rubbed by a loose old header and I got tired if the small weep it had.
2. this braided line is extra strong and the internal diameter is the same as the external diameter of the original pipe...so you do gain a little more volume from lower banjo to upper banjo but Im sure it has no effect on how much gets to the head, as that is determined by rpm and restriction mostly in the upper banjo bolt hole.
if this line were all metal then it would kind of act like a heat sink before entering the head which would be very cool in my mind and something I would love to do down the road...
so far so good after 100miles now and city driving too,
Old 04-10-2013, 04:37 PM   #7748
Royal Club
Royal Club's Avatar
Oddometer: 392
nice work christian! Mcguyver is proud!
Royal Club is offline   Reply With Quote
Old 04-10-2013, 05:12 PM   #7749
Nixels
Face fears - live life
Nixels's Avatar
Oddometer: 7,751
New XR600R owner here.
I have been given a broken '88 and have to fix to ride.
There's no spark when I kick it through. Tried numerous times - in the dark.
A buddy of mine has an '86 XR600R - and I was going to swap the CDIs to see if that's the problem. But I have looked at a couple of replacement houses and they all show date ranges of 1988 to 2000.
Can I use the older CDI to test for spark?
Coffee first, then all your other mundane bullshit. Benjava
SmugMug coupon: cwbkgu7KGL2D2/save $5
Nixels is offline   Reply With Quote
Old 04-10-2013, 05:15 PM   #7750
mcma111
mcma111's Avatar
Oddometer: 12,446
Cdi
I have a CDI you can try
It's probably the pulse generator
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-10-2013, 05:19 PM   #7751
Nixels
Nixels's Avatar
Oddometer: 7,751
Uh, ok.
Pulse generator - do I need to try a spare or just get one off fleaBay?
PM Sent.
Old 04-10-2013, 05:45 PM   #7752
elsalvadorklr
southern xr rider
Oddometer: 4,154
hey nixels welcome fellow 88er
ok
first try stator resistance: 230-320ohms
then try primary and secodnary coil resistance
the try cutting and snipping some nre wire off the sparkplug lead and rescrew the honda cap back on
then if nothing try replacing the sparkplug cap resistor with a metal rod
if none of this THEN try cdi as its the only one you really cant diagnose other than by switching a known good one
if its not electrical then try other stuff like compression check, leakdown test, valves etc...
good luck and welcome man!
read STEVES rebuild thread for a step by step rebuild if you have to do so.
christian
Old 04-10-2013, 05:47 PM   #7753
elsalvadorklr
southern xr rider
Oddometer: 4,154
hell yeah he is!
need a beer now
ps fixed my cracked footpeg bracket, as well as the bent kickstand...too!
damn Im going to miss this bike if it ever sells!
Old 04-10-2013, 05:54 PM   #7754
elsalvadorklr
southern xr rider
Oddometer: 4,154
some racing springs for sale if anyone is interested
http://advrider.com/forums/showthread.php?t=877904
cheers
Old 04-11-2013, 01:02 AM   #7755
Dino3310
Oddometer: 673
Originally Posted by Fourstring View Post
Another stupid (probably already answered) question:
I'm looking at a set of Kenda 270s, but I can't figure out the preferred size for a front and rear; it's in English instead of metric.
What sizes are you guys running as far as tire sizes? 3" front, 4.1" rear seems about right, but does it work well with the bike or should I go bigger?
im running 3.00 -21 and 510 - 18, 460 is good, ive run 410 in the past but only cause they were cheap as
Dino3310 is offline   Reply With Quote
Times are GMT -7.   It's 12:11 PM.
