Old 04-25-2013, 01:43 PM   #7861
mcma111
mcma111's Avatar
Oddometer: 12,391
Easy test. Take the left side cover off as well as the air filter. Try starting again.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-25-2013, 01:55 PM   #7862
martin.kryjom
Oddometer: 50
Can u tell me more about that test, what it should show me?
Velves or overflot?
sorry for a dummy question:)
martin.kryjom is offline   Reply With Quote
Old 04-25-2013, 01:57 PM   #7863
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
Question Venhill braided lines
got around to checking out the fitment of new brake lines I bought online
made by Venhill.
the brake line itself lines up fine but the small rubber clamp mounts
along the line do not line up with the original mounting points.
It doesnt seem that these are supposed to slide,I figure they are molded
to the line but I havent used too much pressure on them.
have emailed the seller but figured I would check with you guys to see
if anyone else has had similar problem
Regards
Geoff
voltz is offline   Reply With Quote
Old 04-25-2013, 01:59 PM   #7864
mcma111
mcma111's Avatar
Oddometer: 12,391
Velves or overflot?
Taking off the side cover and removing the air filter will lean out the fuel mixture.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-25-2013, 02:16 PM   #7865
martin.kryjom
Oddometer: 50
HI
Ok , i did it.
When is cold now, its starts from teh 1st kick.
If hot and stoped, is hard to start.
As i do not have auto decompressor anymore, and i still try to manage kick position , may be i kick it too many times and then overfloat?
I just wondering what is happening as before ( before big bore) engine starts every kick when hot ( when cold sometimes it needed some time)
Old 04-25-2013, 02:18 PM   #7866
mcma111
mcma111's Avatar
Oddometer: 12,391
Oh, no decom assy?? Perhaps that's another reason Mr Honda installed it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-25-2013, 02:29 PM   #7867
martin.kryjom
Oddometer: 50
XR only has disassembly it as they told me it fails very often . I have only manual deco.
DO u think that no A Deco may cose problems with start?
I use amnual insteed...
Old 04-25-2013, 02:37 PM   #7868
mcma111
mcma111's Avatar
Oddometer: 12,391
As long as you have the manual you shoiuld be OK. The auto decom does NOT fail. Screw XR's Only.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-25-2013, 02:43 PM   #7869
martin.kryjom
Oddometer: 50
Im very disapointed of the service, i paid 4 k USD for a motor and exhaust , i explain that im from Poland, far away and there is no one to help me as honda in 1990 was not so popular bike in europe and very rare in Poland ( KTM is a king here), and ask the for full service.
I have imagined that it will be started before sent to me, started and adjusted, velves, jetting , exhaust...
But engine has come even with no oil and it was hard to meka the oil pump working ( thanks to U anyway i did it:) )
And now looks that i have more troubles with that then i used to have.
It need to be started even after drop on dunes , how to make it realible if i can not start it in my garage;(??????????
The good thing about that motor is that it is a beast when it starts, todays bikes can not meet that competotor. 121 kg and long travel ability with such a strong engine....
martin.kryjom screwed with this post 04-25-2013 at 02:49 PM
Old 04-25-2013, 02:52 PM   #7870
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
made by Venhill.
Regards
Geoff
quick update
got a message back from the seller saying the rubbers are tight but can
be moved :)
I'm a happy camper
Geoff
96 XR600 currently undergoing a makeover
Old 04-25-2013, 02:55 PM   #7871
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by Royal Club View Post
Mine starts hot and cold in 1 kick, no hotstart used
who said anything about a HOTSTART BUTTON? jajajajajja
thats a nice mod, id love to do it to the extra intake boot I have...
elsalvadorklr is offline   Reply With Quote
Old 04-25-2013, 03:09 PM   #7872
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,901
Hello I have 83' XL600R, pretty much same engine as the XR.
I was riding the bike today and it started to make a loud racheting/bucket of bolts noise, I never heard before. I immediately pulled over and took my helmet off for a listen, as I revved the sound got worse and louder to the point the I thought the engine was about to grenade or something. I shut it off and chill for a few minutes with my buddy. I go to start it about 10 mins later and it fires right up with no noise. I decided to ride it home 40 miles and it doesn't happen again? wtf could that noise of been?
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 04-25-2013, 03:14 PM   #7873
elsalvadorklr
southern xr rider
Oddometer: 4,154
so are you saying that xrsonly sent you the engine complete with the carb installed?
did you at least get the carb manual, and or instruction sheet that comes with what jets are installed etc?
if not your just guessing...no way to jet or fix unless you know what you have
you are just wasting your time
TAKE CARB OFF AND SEE WHAT JETS YOU have(sorry to sound annoying, but its just the only way to fix your situation)
if you dont hav jets do rejet with then you need to order some...
ps. I think xrsonly is overrated especially nowadays, plenty of private builders and or shops that do as good or better personalized work...for less $$$
steves machinist place kicks ass, forget the name...
later
Old 04-25-2013, 03:16 PM   #7874
elsalvadorklr
southern xr rider
Oddometer: 4,154
Mine not:( and i did what i did ( pay to XR only ) to avoid that kind of problems, my old engine works from the first kik as U:(
I will check velves.
If i use choke even in half way, bike does not start , is overfoted stright from the beginning.
WOW
mikuni flatslides do NOT like any choke if your temps are say 10c and up...
If I use any choke even igf jetted way lean its too much
are you using the deflooding kick cycle for xrs correctly?
just a thought
Old 04-25-2013, 04:22 PM   #7875
martin.kryjom
Oddometer: 50
HI
I do not use chock now at all, so if is normal for that carb that means that it is not indication of the overfolat
About kick start procedure, i know it well, i have used that bike a year before i have decided to spent a lot of money on that.
I did not get ANY instrucions, only for start procedure for engine to check oil pump. But without that forum help i would never start that thing.
MINUNI come as it is, no isntruction, just only set of jets.
May be i should buy MIKUNI pumper? WHat do u think?
Times are GMT -7.   It's 10:52 AM.
