Old 04-29-2013, 02:53 AM   #7906
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Hey John,
Those holes serve no purpose in sealing or mounting, they are usually where the rivets are in layered steel gaskets and they sit above the bolt holes for torqueing down the cylinder jug
Cheers
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 04-29-2013, 03:54 AM   #7907
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by The Dogger View Post
Hi Guys
Got to the stage of fitting the new carb , and I'm having issues with clearance.
I've read where others have had a problem with the tank , however my situation is that the top of the carb ( cable housing ) is hitting the frame.
It appears I may be able to swivel the carb anti-clockwise , but I'm concerned about causing problems with the float level. Will it still function correctly ?
Alternatively , does anyone have any experience of fitting an XR 650 ( L or R ?? ) intake manifold ? I'm sure I've read that they have a different angle........
Thanks in advance
Stu
slight tilting wont do it harm.. Just try it... Strangely mine just sits near up right..
Royal Club is offline   Reply With Quote
Old 04-29-2013, 03:55 AM   #7908
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by deejay_xr View Post
I warped my front brake disc
320 mm, floating
Don't know how I managed that
maybe one of the floaters is stuck?? so it looks warped??
Old 04-29-2013, 04:10 AM   #7909
deejay_xr
deejay_xr's Avatar
Oddometer: 496
I've been having this real annoying rubbing and scraping sound when coming to a gentle stop lately.
I had it on the lift yesterday and when I turn the wheel it very clearly rubs more on the brake pads on some points than others.
Old 04-29-2013, 04:17 AM   #7910
Royal Club
Royal Club's Avatar
Oddometer: 392
so try and wiggle the disk on the floater at that point, maybe it'll change??
Old 04-29-2013, 06:55 AM   #7911
elsalvadorklr
southern xr rider
Oddometer: 4,154
rebuild caliper, replace seals, polish pistons, then clean and if needed buy a master cylinder rebuild kit...
check bleed hole in bottom of mastercylinder recervoir...flush and clean brake line.
all these things will get your brake to work 100 percent
drag is caused by any of these things mentioned...if its not this then look at caliper pins, lube them up nicely and lube the piston cap to pad contact area(if not lubed they squeel)
I just did this while replacing my brake hose line...all good and feel is better, my old 88 line had some give to it, spongy.
elsalvadorklr is offline   Reply With Quote
Old 04-29-2013, 08:25 AM   #7912
Royal Club
Royal Club's Avatar
Oddometer: 392
does anyone recognize this shock?? WhitePower perhaps?? Doens't look like a stocker??
Old 04-29-2013, 08:41 AM   #7913
mcma111
mcma111's Avatar
Oddometer: 12,385
Looks like a WP to me.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-29-2013, 09:32 AM   #7914
deejay_xr
deejay_xr's Avatar
Oddometer: 496
I'll give them a wiggle tomorrow
Disc is clearly rubbing more on some points than others, so a caliper rebuild is not gonna solve this anyway
Old 04-29-2013, 09:43 AM   #7915
mcma111
mcma111's Avatar
Oddometer: 12,385
I have tweaked a few of the front disc's on my dirt bikes. I just tap the high spots with a mallet to get the disc back in true. Easy-peasy.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-29-2013, 10:19 AM   #7916
Royal Club
Royal Club's Avatar
Oddometer: 392
worth the money, and how does it compare to the stock shock?
Old 04-29-2013, 10:37 AM   #7917
elsalvadorklr
southern xr rider
Oddometer: 4,154
thought the disc was straight
nevermind
do what steve says, if oem they are thin and easy to bend back....i did on my original 88 one
Old 04-29-2013, 11:05 AM   #7918
mcma111
mcma111's Avatar
Oddometer: 12,385
OE XR disc's start at 5mm. CRF disc's are 3.5mm
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-29-2013, 11:10 AM   #7919
Royal Club
Royal Club's Avatar
Oddometer: 392
should explain why mine is so crappy.. its under 3mm..
Old 04-29-2013, 02:41 PM   #7920
elsalvadorklr
southern xr rider
Oddometer: 4,154
dayum!
jajaja
you lose some weight going to a crf wheel for sure, both the rim, disc and hollow axle weigh less than xr stuff...not to mention spokes and nipples too
all oem discs have a minimum thickness marked on them. I think oem minimum is 3.5mm
Times are GMT -7.   It's 09:37 PM.
