Old 02-02-2010, 05:04 PM   #781
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
Help Needed !
My buddy smoked his motor due to the lack of oil.
It took out the cam, head, valves, piston, and cylinder.
He found and bought a new/used cylinder and piston,
but is finding a head hard to source in working condition.
Will a XR650L head work on his 93 XR600R ???
Or does anybody here have one for a reasonable price?
Thanks for any help.
Assfault
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 02-02-2010, 05:29 PM   #782
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
This is an even better question if you are going to do the opposite swap due to electric start of the 650L needing to be automatically decompressed. In either case the answer is "yes". The positioning dowels do also match part numbers. The heads ARE different part numbers, but read on:
650L head part # 12200-MY6-670
600R part # 12200-MN1-680
If you can tell any difference between the photos ore even if they have differing parts is unimportant. What is important is whether it had the post 1988 decompression system with the cam decomp auto clutch. The cam chain width also, even if different, can be corrected. I have even used some unorthodox parts combinations from pre and post '88 valve trains that were made to work flawlessly. More part number research can be done at www.babbittsonline.com who has a microfische giving Honda part numbers unlike some OEM parts vendors. I do however have a price preference foe zanottis of Pennsylvania. Not that you'll be buying an OEM head. I actually did that on my XL600 believe it or not. Would have saved hundreds at zanottis. Never again with Bike Bandit. ugh.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 02-02-2010, 05:35 PM   #783
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,834
Originally Posted by screwit
Has anyone put a Keihin 39 FCR on a XR600? If so how hard and was it worth the trouble? As always, any help is appreciated.
FWIW: i ran the mikuni flatslide setup from ballards i found it flat of bottom as it did'nt have a fuel pump like the keihin.
check out the squish/piston to head clearence difference also.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 02-02-2010, 05:37 PM   #784
brucifer
brucifer's Avatar
Oddometer: 2,427
Regarding the 650L and 600R head compatability; Not sure about combustion chamber volume, but maybe the only difference would be the air injection ports are drilled in the 650L head and not the 600R?
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 02-02-2010, 05:57 PM   #785
Zombie_Stomp
Aspiring human
Oddometer: 2,231
What, the smog pump stuff? I thought the only interface with that was all on the cylinder.
Old 02-02-2010, 06:07 PM   #786
mcma111
mcma111's Avatar
Oddometer: 12,068
Head
What year is the XR600?
What damage was done to the XR head?
The XR650l head will bolt onto the XR600. The only problem is the air injection ports for the smog crap. If you intend to install the XRL head you can either weld shut the ports or fit a threaded plug in the passage ways. The ports MUST be sealed for the XRL head to work on the XR cylinder.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-02-2010, 06:23 PM   #787
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
1993
Smoked the cam bearing surface and the combustion chamber where pieces of the piston dented it, pretty extensive in this area, the piston rammed pieces into the head. The valve seats/valves also to quite a beating.
The XRL head is on e-bay for $200 with all the valves. Seems cheaper than fixing, if possible. Will he need to big bore the XR600 cylinder to 100mm like the XRL ?
All parts being used and original are from 1993 or later.
the XRL head in question is from 1998 I belive.
Thanks for all the quick replies.
Old 02-02-2010, 06:30 PM   #788
mcma111
mcma111's Avatar
Oddometer: 12,068
The XR600 stock bore is 97mm. There are over size pistons available in +97.25mm, +97.5mm, 98.0mm and 100.0mm
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-02-2010, 06:39 PM   #789
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
I just bought a Keihin FCR41 pumper for my XR600R.
I will let you know how it goes next week when I get it and install it.
I had to order the airbox spigot from Sudco as it doesn't have one already.
I hope it will work like the Mikuni Pumper I installed on my XR400R.
Old 02-02-2010, 06:40 PM   #790
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,188
Yea, I just didn't know if he HAD to or not. If it were mine I would, but he is financially challanged more than I right now.
Old 02-02-2010, 07:51 PM   #791
ajr49123
Oddometer: 23
Here's my newly acquired 2000 xr600
ajr49123 is offline   Reply With Quote
Old 02-02-2010, 08:13 PM   #792
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
For the air injection tubes, yes, but those holes go up through the bottom of the exhaust ports. There doesn't appear to be any clamping surface under them if used on a 600 cylinder, so I would expect that they need to be securely plugged.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 02-02-2010, 09:06 PM   #793
mcma111
mcma111's Avatar
Oddometer: 12,068
Yep, That's one clean XR600. Doesn't look like it ever was ridden in the wet. No mud dried onto the header.
Welcome aboard.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-02-2010, 09:53 PM   #794
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,243
Looks like it spent ten years in a plastic bag. Nice! But you're not going to
get it dirty, right?
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 02-02-2010, 10:10 PM   #795
ajr49123
Oddometer: 23
I'll admit I've already got it a little dirty, but i'm going to try to keep it in good condition, could be a collectors item if they ditch the 650l.
Times are GMT -7.   It's 12:26 PM.
