Old 05-12-2013, 06:53 AM   #8071
Fourstring
Fourstring's Avatar
Oddometer: 129
After looking at those rebuild pics, I'm not even sure I want to ask my grade-school questions. That's just awesome.
My XR is starting to leak from the cam chain tensioner; bad O-ring. I think if I can pull it out just a half inch or so, I can get the new O-ring on or silicone caulk it enough to call it good.
Can I pull out the tensioner a little safely without opening up the head? If so, what's the preferred method?
Thank God I'm not cool.
Fourstring is offline   Reply With Quote
Old 05-12-2013, 07:10 AM   #8072
mcma111
mcma111's Avatar
Oddometer: 11,890
No and no
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-12-2013, 07:19 AM   #8073
Fourstring
Fourstring's Avatar
Oddometer: 129
Originally Posted by mcma111 View Post
No and no
Hey, better to ask than wing it. Off the heads come...
Old 05-12-2013, 10:29 AM   #8074
joexr
Oddometer: 3,773
You've only got to pull off the rocker box.
Old 05-12-2013, 02:28 PM   #8075
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
only going from memory but you can make a little tool to keep tension
on the camchain without having to remove the heads
it's been a long time since I did this so I did a quick search and found this
http://www.thumpertalk.com/topic/688...ionertutorial/
if you look at the third pic down you can see a small hole in the top of the tensioner
assembly,here you can make a small tool right angle in shape that will fit into the
hole and rest against the cylinder head holding the tensioner in the relaxed position
I actually made one out of the end of an old car aerial years ago
Geoff
96 XR600 currently undergoing a makeover
voltz screwed with this post 05-12-2013 at 02:35 PM
voltz is offline   Reply With Quote
Old 05-12-2013, 03:15 PM   #8076
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
any of you guys using these fancy clutch perches and lever assemblies with
the bearings in the lever pivot? (eg works connection)
$100 for perch and lever seems fairly expensive but obviously they are top
end equipment,would be interested to hear peoples experiences
Geoff
Old 05-14-2013, 09:59 AM   #8077
elsalvadorklr
southern xr rider
Oddometer: 4,154
selling my flatslide
if anyone is interested, great budget upgrade
http://advrider.com/forums/showthrea...9#post21406099
shipped!
christian
elsalvadorklr is offline   Reply With Quote
Old 05-14-2013, 10:06 AM   #8078
elsalvadorklr
southern xr rider
Oddometer: 4,154
and some good karma stuff(jets)
http://advrider.com/forums/showthrea...8#post21406148
cheers
Old 05-14-2013, 02:57 PM   #8079
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
well unfortunately I wasnt online at 4am and I missed out on the carby,but I would like to know about those headers.......are they the stockers and if so how did you get them so clean ?
Geoff
Old 05-14-2013, 03:39 PM   #8080
mcma111
mcma111's Avatar
Oddometer: 11,890
I have one of those TM flat slide carbs. Been sitting in the box on the shelf for 20+ years. Tried it and went back to stock.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-14-2013, 05:20 PM   #8081
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,140
A little wrenching during our Alaska spring snow....
-NEW LED flushmount signals. No more bustin' them off during an oopsie BTW I've never felt the need to blurr out my plate.
-New Kush Sprocket (slightly modified inner diameter to fit my 88) The bolt holes didn't need anything.
-View of countershaft sprocket after 8K+ mostly road miles without any cush hub or drive. NOT BAD if I do say so myself
_Finally the view of the XR's Only case guard after my chain came apart at 60 MPH......It did what it was supposed to do!
More to follow...
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 05-14-2013, 05:49 PM   #8082
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,140
More work on the ole' 88
-First a new rechargeable battery with pigtails for the charger. Now when the toggle switch on the BD kit is ON the tail light is actually lit up WITHOUT the motor running!! Who knew
-Next a little needed grinding of the snail axle adjusters, might be time for some new ones. These are pretty toasted in the 20-15 range (I have not ground that area out yet, but it's pretty worn..)
That is all for now, carry on!
Palmer, ALASKA
2011 Verys ADV
Old 05-14-2013, 05:49 PM   #8083
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
I fitted one to a previous XR after reading it can help with the cough/stall
(as can removing the auto decomp) and found it to be ok,nothing miraculous.
What made you change back to stock Steve ?
Geoff
Old 05-14-2013, 06:09 PM   #8084
elsalvadorklr
southern xr rider
Oddometer: 4,154
yes stock 88-90 headers took em to a shop and they welded and cleaned them up, they are starting to tan now after some use...
Old 05-14-2013, 06:20 PM   #8085
mcma111
mcma111's Avatar
Oddometer: 11,890
I didn't see an improvement. Back to OE carb.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 09:27 PM.
