Old 06-16-2013, 03:59 AM   #8266
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
looking good Stu
bought myself a little abrasive blaster this week from Super Cheap,tried
it out today,got covered in blast but the alloy is coming up nicely :)
Geoff
96 XR600 currently undergoing a makeover
voltz is offline   Reply With Quote
Old 06-17-2013, 07:22 AM   #8267
TopDogDave
Manly, NSW, Australia
TopDogDave's Avatar
Oddometer: 160
someone say oil cooler......
here's some instructions to fit one
'90 R100GS PD - large
'94 XR600R - medium
'73 BSA B50MX - small
TopDogDave is offline   Reply With Quote
Old 06-19-2013, 05:43 AM   #8268
Captain115
Captain115's Avatar
Oddometer: 278
Hey guys,
Wasn't thinking and tried to undo the stator cap with an imperial allen key...grabbed it from the wrong kit. Needless to say it stripped super fast so now I'm left with a circle instead.
Thoughts on how to remove it? Stator cover isn't currently connected to the bike. I know it only uncovers the flywheel to turn it for valve clearances and I could do it with the kickstarter but that sound annoying. Plus, since everything is still apart, I might as well fix it while I'm here.
I've started trying to chisel a cut to use a flat head screwdriver or chisel etc to turn it but no luck. Oh and it isn't siezed as I had it out previously and only tightened it back up a small amount.
Thanks,
John
Captain115 is offline   Reply With Quote
Old 06-19-2013, 05:57 AM   #8269
mcma111
mcma111's Avatar
Oddometer: 11,867
Mount the cover back to the engine to stabilize it so you can beat on it. Now get a 1/8" drill bit and drill a hole 3/16 in from the outer lip. Now you have somewhere for your punch to go as you beat the cover off the stator. I'd drill at the 1 o'clock position.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 10:50 AM   #8270
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Here's what I did
- drill 2 holes for two punches (in my case differently sized)
- place punches in holes
- stick screwdriver sideways through punches
- bunch punches together in your fist (pinching the screwdriver) and use screwdriver as leverage
cover came right out
Works best when having the case mounted, so you can exert some leverage.
Don't drill too deep, 0.2" is plenty. You don't want to risk punching through with the drill and ending up with shavings in the engine.
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 06-19-2013, 03:07 PM   #8271
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
^^^^ this would be my recommendation
Geoff
Old 06-19-2013, 03:25 PM   #8272
Thebusdweller
Oddometer: 36
Wrist pin clearance
Does anyone know what the clearance is on the small end of the con rod? Ive downloaded the factory book, but it allows allmost .003. That seems like too much in my mind. Its a 94 xr600, and was quiet on tear down, just using too much oil. Thanks for the info! Tom
Thebusdweller is online now   Reply With Quote
Old 06-19-2013, 03:40 PM   #8273
mcma111
mcma111's Avatar
Oddometer: 11,867
.024 to .049 Thousand
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 03:48 PM   #8274
Thebusdweller
Oddometer: 36
Thanks Steve, you rock!
Old 06-19-2013, 03:57 PM   #8275
mcma111
mcma111's Avatar
Oddometer: 11,867
It's quite common for the small end of the rod on the big XR/XRL's to have some slop. Like a Timex watch, they keep on ticking.
I didn't like how much play was in my son's XRL so my machinist bushed it for me as a favor.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 05:03 PM   #8276
Captain115
Captain115's Avatar
Oddometer: 278
Thanks team! And deejay, that pic is definitely worth 1000 words, cheers!
Will try it tonight,
John
Old 06-19-2013, 06:32 PM   #8277
TopDogDave
TopDogDave's Avatar
Oddometer: 160
The XR600 standard stator power output is well known to be feeble and its easy to rewind extra coils to increase the available wattage from the lighting circuit.
But what is less well known is the high voltage (separate) winding that feed the ignition is prone to fail if (a) it's old and (b) the bikes done a lot of hard vibration klm like riding over corrugations etc.
What happens is the thin fragile copper wires in the ignition windings eventually get frail after so many heat and vibration cycles, rub together and short or break.
(the thicker lighting wires seem less prone)
This happened to me in the middle of nowhere and just after a set of bad corrugated country roads!
When I spoke with an ex racer of these old girls he said "well known i'd never do a desert trip without carrying a spare"....
Funny how after the fact everyone knows....but never thought to mention it till afterwards.....
So here's a tip.
Get an extra (spare) set of ignition windings added and run the wire under the seat and just leave it wrapped in plastic. If you ever have an ignition winding fail just swap to the backup winding.
Test it by swapping over from time to time.
You have to sacrifice a couple of lighting coils assuming your starting with an upgraded stator with all poles wound.
if you have a standard stator there are plenty of spare poles to stick another backup circuit on anyway so nothing lost.
Pic shows two ignition windings. The rest are lighting. Note two red wires on left are the 2 ignition lines going up under the seat.
Had this working for 2 years now and feel its a good mod. for those on remote trips.
'94 XR600R - medium
TopDogDave screwed with this post 06-19-2013 at 06:40 PM Reason: stator mod
Old 06-19-2013, 07:05 PM   #8278
voltz
Rebuilding
voltz's Avatar
Oddometer: 94
good tip Dave !
I have read a little about rewinding the stator but I figure I might be better
off just paying for an upgraded one..........perhaps I can buy a 2nd hand unit
and have a crack at rewiring one myself
Geoff
Old 06-19-2013, 09:15 PM   #8279
elsalvadorklr
southern xr rider
Oddometer: 4,154
I have a failed ricky stator that one can try rewinding for the cost of shipping if anyone is interested...
or an oem one too...
elsalvadorklr is offline   Reply With Quote
Old 06-19-2013, 09:22 PM   #8280
mcma111
mcma111's Avatar
Oddometer: 11,867
Stator
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 04:16 PM.
