Old 06-29-2013, 01:40 AM   #8326
Captain115
Captain115's Avatar
Oddometer: 286
First off, thanks for the info on the forks. It is interesting to hear about the comparative differences between the different XR's and the USD conversion.
Moving on: some of you may remember that my XR was knocking badly at the start of March. I pulled it apart and found that a whole bunch of metal had blocked oil to the head, destroying the top end.
Since I didn't know where the metal came from, and there was some transmission problems (2nd/3rd like is commonly the case) I also had to split the bottom end.
Didn't bother replacing the rod since a lot of people said that 'the rods rarely go bad' and neither my machinist nor I could feel anly vertical play. Put a 100mm forger Wossner in, replaced the gears, cams, rockers, timing chain, oil seals.
Put it all back together, started it up and the prick of a thing knocked like crazy. Pulled it apart again (there goes $40 worth of gaskets) and got the machinist to press apart the crank just in case. Lo and behold the bottom was destroyed. Clearly this was where the metal came from original, and was the reason for burning it down the first time and now the second. Let my mistakes be a lesson (along with benno.h's similar occourence), that the big end can go in these XR's and in some cases it can't be even felt!
So put a new rod in, got the bore honed and polished up the 100mm Wossner, reground the valves to improve sealing, replaced the valve stem seals etc.
Started it up for the first time today...came to life on the second kick, with no knock! Quickly got on and went for a 50km ride, varying the throttle and riding the torque band and using a lot of engine braking. Hope this is an ok break in method!? Jeez it's got power now! the front constantly wants to lift in the first few gears, crazy fun.
However, I saw a good hill to engine brake down, got partway up and began to turn and promptly dropped the bike! This is my first time ever dropping a bike like that, I guess I just wasn't used to the height and down it went. Obviously this shouldnt matter as it is a dirt bike, however I had forgotten to reattach the right handgaurd and of course it went down on the right side with a lovely crunch, which was my brake lever snapping. Turns out it is very difficult to lift a bike up on a hill without a front brake since it just slides down the hill, even in gear (it was steep and slippery hill). I couldn't get back on it from the downhill side due to the height so had to do a walk of shame, half carrying it down the hill.
Then I had to start the bastard! Yes, normal routine for starting a dropped XR except the drop had bent the footpeg in so the kickstarter would get stuck under it each stroke. Very frustrating! Oh and then I had to ride back through the city with no front brake, but at least that meant I employed engine braking a lot.
So yeah, that's my story. Pics below.
John
Captain115 screwed with this post 06-29-2013 at 05:55 AM
Captain115 is offline   Reply With Quote
Old 06-29-2013, 01:55 AM   #8327
lookfar
from the land of OZ
Oddometer: 627
Put it all back together, started it up and the prick of a thing knocked like crazy. Pulled it apart again (there goes $40 worth of gaskets) and got the machinist to press apart the crank just in case. Lo and behold the bottom was destroyed. Clearly this was where the metal came from original, and was the reason for burning it down the first time and now the second. Let my mistakes be a lesson (and benno.h), the big end can go and in this case it can't be even felt!
John
Sorry to hear of your misadventure.
You couldn't have swung aboard using the footpeg from the downhill side, then clutch start it rolling downhill?
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 06-29-2013, 05:58 AM   #8328
Captain115
Captain115's Avatar
Oddometer: 286
Hmm probably could've but didn't trust my balancing abilities. I do wish I had roll started it though, didn't even think of that!
Old 06-29-2013, 06:04 AM   #8329
booniebasher
booniebasher's Avatar
Oddometer: 623
Did 400 miles on my plated xr . What a great dualsport on the cheap. 200 dirt two and single track and 200 @ 80 on slab. Who needs a beemer.
Sent from my SPH-L900 using Tapatalk 2
booniebasher is offline   Reply With Quote
Old 06-29-2013, 06:31 PM   #8330
motozona
motozona's Avatar
Oddometer: 25
XR pics
How do I download pics on this site? I have a couple of beautiful XR's that I would like to share. Mark in Mayer. The Race bike has twin pipes :) And the 96 has the original IRC Volconduros. May have 3 hrs on her ( maybe) picked her up last week.. shes like brand new :) all smiles , Oh thanks Jungleplant for the help
motozona screwed with this post 07-01-2013 at 10:39 AM Reason: Add picture
motozona is offline   Reply With Quote
Old 06-29-2013, 06:34 PM   #8331
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,850
upload your pic to the cloud like photobucket, then copy image then past in the pic link
www.manracks.com
jungleplant is offline   Reply With Quote
Old 07-01-2013, 03:38 AM   #8332
RoostMaster
Oddometer: 254
Yep, that's when these bikes are gems.. got any overall pics of the XR porn?
Get that whip out for the REALLY steep hills ! YYAAHHH!
RoostMaster is offline   Reply With Quote
Old 07-01-2013, 03:56 AM   #8333
lookfar
from the land of OZ
Oddometer: 627
So, I had a play with the XR resto project again today.
Got all the lights working as they should, bit of a hiccup with the headlight..
turns out that 6v globes don't like 12v....Who'd 'a thunk...go figure
Still got a bit to do, kill switch, horn, wiring tidy up, tyres, chain, sprockets....etc.
This is what it looked like when I picked it up.. (poor thing)
Anyway, here is an updated pic of what it looks like now..
Stu in FNQ
1985 XL250R
Old 07-01-2013, 04:05 AM   #8334
benno.h
cageracer
Oddometer: 437
Nice one mate!
So, not a machinist error after all eh?!
Originally Posted by GodSilla View Post
I'll step out on a limb here and state that bikes without kick starters are just plain gay, for pansies, ladyboys, and suchlike. Furthermore, they should have to ride at the back, not speak until spoken too, and set everyone else's tents up, then cook and wash up afterwards, before sitting up all night guarding the real men's bikes.
benno.h is offline   Reply With Quote
Old 07-01-2013, 05:24 AM   #8335
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,191
Good work Glad to see another 88 still kicking!! She looks bone stock..
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Old 07-01-2013, 06:32 AM   #8336
TopDogDave
Manly, NSW, Australia
TopDogDave's Avatar
Oddometer: 163
what size/model fcr pumper carb will fit the XR?
can anyone who has done this post some pics and experiences?
thanks!
davo
'90 R100GS PD - large
'94 XR600R - medium
'73 BSA B50MX - small
TopDogDave is offline   Reply With Quote
Old 07-01-2013, 07:04 AM   #8337
clamp007
Africaboy
Oddometer: 8
Finally brought home an 86 XR600. Oil leak help?? Pics.
I just picked my 1st XR600.....a 1986! I have searched & searched & finally she popped up for sale not too far away. Super excited & it's in wonderful shape.
I rode around the neighborhood & noticed an oil leak midway down the front of the fins. I see that on the left side of the motor, right there in the fins & above where the clutch cable is, that there are 3 small holes in the motor which seem to be leaking the oil? Below are the pics.
Does anyone know why these may be leaking & what the solution is??
When I spoke to the owner before buying, he said it had no leaks at all. He'd ridden it twice in 6 months. And there was no oil in the pickup after I brought it home, so it must have just started.
clamp007 is offline   Reply With Quote
Old 07-01-2013, 07:11 AM   #8338
mcma111
mcma111's Avatar
Oddometer: 12,269
Those holes are NOT supposed to be there. The holes look like they are drilled into the cylinder hold down bolt passage way.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-01-2013, 07:15 AM   #8339
mcma111
mcma111's Avatar
Oddometer: 12,269
thanks!
davo
Pick up a FCR carb from a CRF 250 or 450. Most of them are 40mm which will work well on the XR600. You will need a NOSS MACHINE adapter and a XR650l carb to head insulator as it is needed to change the angle of the carb as the OE XR insulator will have the carb hitting the frame.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-01-2013, 07:18 AM   #8340
elsalvadorklr
southern xr rider
Oddometer: 4,154
weird! maybe somebody wanted to drill holes to add fins or something! jajaja
wtf
elsalvadorklr is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
