Old 02-06-2010, 06:06 AM   #826
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,805
Originally Posted by bigtrailie
Has anyone used the SRC fork brace kit on their XR 600? I found one of these kits with about an inch of dust on it at a local Honda shop that was going out of business. I got a good deal (considering what these things went for back in the late '90's) and would like to try it out in hopes of avoiding the BIG $$$ CRF front end swap.
Who can tell me what the air fittings at the top of the stock forks are for (besides letting air in and out). Is there a setting we should run on these? For example -- 180# rider = 2 psi, 200# = 3psi, 250 = 5psi, etc
I would imagine that you would eventually start blowing oil out of your fork seals if you pressurize the fork tubes with too much air pressure. What gives?
I run the SRC brace, actually I worked there when they were still in business. It is the origional and still the best fork brace made!
Always run 0 psi in your forks, the valve is only for letting air out because pressure builds in the forks as you ride it or change elevation.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 02-06-2010, 06:12 AM   #827
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,055
There is always a debate on this just as with oil and tires, BUT I agree fully. The valves are there so that you can get a zero pressure with temperature and altitude changes.
Marc
84 R100RS LE, 14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is online now   Reply With Quote
Old 02-06-2010, 06:42 AM   #828
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,212
I have one on my XR. I also had one on my XR400. They work well and stiffen up the front quite a bit. Debris get caught in the sliders from time to time but no biggie.The acual brace looks simular to the RSW still available, which I have on my NX650. I just bleed out the air from the fitting never put any in.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 02-06-2010, 06:52 AM   #829
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I too have a real SRC fork brace(with fork skins and plastic guards) and it's the best thing short of a USD fork swap. Since SRC is long gone, I am going to blueprint it and make a few when I get some access to a machine shop.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 02-06-2010, 08:32 AM   #830
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,805
It's going to be hard to source the rubber wipers I would think. This is why the SRC brace is better than the ones that mount directly to the aluminum fork tubes.
Old 02-06-2010, 10:21 AM   #831
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Nah, fortunately other companies still offer comparable neoprene fork skins.
Old 02-06-2010, 12:04 PM   #832
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,805
The neoprene isn't enough. The rubber wiper was part of the function of the brace. You want a very minor bit of flex between the brace and the fork leg. This where the rubber came into play.
Old 02-06-2010, 02:42 PM   #833
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,297
Originally Posted by 'Flagger
greetings. apologies for interrupting but would any of y'all have a line on who might be selling a rear shock from a late '80s XR600R. Specifically, I'm looking for one of the remote reservoir versions for a project bike.
A PM with any information would be very appreciated.
PM sent.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 02-07-2010, 06:38 AM   #834
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,360
Originally Posted by MortimerSickle
PM sent.
Thanks! Reply sent.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 02-11-2010, 02:01 PM   #835
CoosBayKLX
Oddometer: 5
Hey guys, quick question, I'm sorry if it's been covered already, but my dad is looking at an '89 XR600 that is in need of some cosmetic work. Will any other year body parts fit the '89? The newer ones all look the same in pictures I have seen but I have no access for comparison.
CoosBayKLX is offline   Reply With Quote
Old 02-11-2010, 02:41 PM   #836
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
as far as i know yes the plastics did not change in fitting wise.
acerbis , cycra , ufo etc universal head light ,front guard/rear guard & side panels will also work
do a part No: search & cross ref to the newer models
http://www.bikebandit.com/honda-moto...arts/oem-parts
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 02-11-2010 at 03:04 PM
veetwo _tls is offline   Reply With Quote
Old 02-11-2010, 03:44 PM   #837
misterkridered
Red Rider
misterkridered's Avatar
Oddometer: 237
The tank, fenders, seat and side panels are interchangeable from 1988 to 2000. 1988 to 1990 had different exhaust (2 into 2 into one muffler vs 2 into 1). 1988 to 1990 had rear drum brake. After that the suspension was upgraded and the rear disk was added. 1988 to 1990 had magnesium cases and aluminum head and was lighter than the later models and a little more powerful according to the seat of my pants.
misterkridered is offline   Reply With Quote
Old 02-11-2010, 05:23 PM   #838
veetwo _tls
RENOVATIO:
Oddometer: 1,849
i'll add also the 92 had a larger front axle to the smaller 97.
2 into 2 exhaust system can be exchanged for the 2 into 1 & vice versa if you wanted too.
CHEERS: brett
MY07 950 SER
Old 02-11-2010, 05:26 PM   #839
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I don't think the crankcase halves were magnesium, but the stator and clutch covers were. '88-90 also had a Nikasil-plated aluminum cylinder, not an iron sleeve like the rest.
Old 02-11-2010, 05:32 PM   #840
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,805
You mean the smaller 91 axle. 92-2000 has the larger 17mm axle.
Times are GMT -7.   It's 09:30 AM.
