Old 07-24-2013, 05:37 AM   #8536
rmhrc628
rmhrc628's Avatar
Oddometer: 2,555
Originally Posted by drakehouse View Post
Will a '85 xr400r stator bolt in a '87 xr600r ?
Looking to purchase a cheap stator to rewind and install without taking current stator out for the rewind to have more .
Thx
Didn't make xr400rs in 85.
Sent from my iPhone using Tapatalk 2
rmhrc628 is offline   Reply With Quote
Old 07-24-2013, 10:06 AM   #8537
drakehouse
Burnin' & Turnin'
drakehouse's Avatar
Oddometer: 122
edited previous question about stators.
Thx
Riddin' for a Livin'
Best to swim against the curent than float down stream
drakehouse is offline   Reply With Quote
Old 07-24-2013, 10:29 AM   #8538
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 641
Drakehouse,
Why not just post here or better yet in the fleamarket that you want a used stator for your project from an 85 - 87 XR600R? I would gladly send you one if I hadn't just thrown mine away a week ago...
A lot of people have upgraded to the Ricky Stators, so the old burnt up originals are probably still sitting in garages all across this great nation just waiting for you to take them....
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 07-24-2013, 12:51 PM   #8539
elsalvadorklr
southern xr rider
Oddometer: 4,154
What other XR stators (400/500/650) will bolt '87 xr600r ?
Thx
I have 2
my 88 oem one that was rewound still worked when I took it off but the epoxy is brittle
then a ricky stator that burnt the exciter coil...either are good for a rewind
cheers
elsalvadorklr is offline   Reply With Quote
Old 07-24-2013, 04:02 PM   #8540
Wout67
Wout67's Avatar
Oddometer: 2,183
Originally Posted by mcma111 View Post
Why when I look up your bike on the parts fich it shows it as having a 18" rim?
"parts fich" ? Is there a website that shows that stuff? I thought bikebandit.com would have it, but not so much.
The thing about quotes on the internet is that you can never confirm their validity.
- Abraham Lincoln
www.iamsecond.com
Wout67 is offline   Reply With Quote
Old 07-24-2013, 04:06 PM   #8541
mcma111
mcma111's Avatar
Oddometer: 12,097
Here:
http://www.cheapcycleparts.com/oem-parts/honda
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-24-2013, 10:49 PM   #8542
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Originally Posted by Big Tall Bastard View Post
So I would be better off getting the whole rear wheel, brake assembly, etc and swapping it all.
Its a 17"
You can re-lace a 18" rim onto the stock hub. Its been done before and I just posted on this topic in the XR500 thread. My 84 XR5 came with the 17" rear and the previous owner of my bike had a Sun rim put on the stock hub with new/longer spokes.
Its the middle wheel in this photo. The wheel on the right is the stock 17 rear, and the one on the left is an XL6 with cush hub.
Ghost_Mutant is offline   Reply With Quote
Old 07-25-2013, 12:40 AM   #8543
Big Tall Bastard
Voice of Reason
Oddometer: 332
Awesome! Thanks for the insight.
Current rides: 07 Aprilia Tuono R, 87 XR600R (Hell Yeah!)
Some of bikes owned in the last few years: 2007 990 Adventure ,2001 Aprilia Mille RSV, 2000 XR 650 R, plated Sold (what a dumbass) 2001 CR500R, 2001 Cagiva Gran Canyon
Big Tall Bastard is offline   Reply With Quote
Old 07-25-2013, 07:06 AM   #8544
Redspiker
el gadañon
Redspiker's Avatar
Oddometer: 4
Good 50/50 tires
Hey guys, I have to buy some new enduro tires for my '85 XR and just wanted to get some insight as to what the best 50/50 tire is. Any suggestions are much appreciated. I've never had to buy any before and It's that time. Thanks in advance.
FOR SPAMALOT
Redspiker is offline   Reply With Quote
Old 07-25-2013, 08:30 AM   #8545
Wout67
Wout67's Avatar
Oddometer: 2,183
Thanks, man!
That'll come in handy for sure.
A while back, I had mentioned that it looked like I had a leak at my front sprocket. Someone had mentioned that it's probably an easy fix with a dental tool and a new gasket. The main reason I was looking for an exploded view of the bike was so I could see what it looked like.
Do you guys know where I could find that gasket if I needed it? We are going to take a closer look at it this weekend.
- Abraham Lincoln
www.iamsecond.com
Old 07-25-2013, 08:48 AM   #8546
mcma111
mcma111's Avatar
Oddometer: 12,097
Did you install a Ricky Stator? If so the leak is most likely where the wiring comes out of the stator cover. If not then it's the countershaft seal.
Item #30
http://www.cheapcycleparts.com/oem-p...l/transmission
Stab the seal with an ice pick and pry it out. When you install the new one make sure that you only insert it so it's flush with the outside lip. If you push it to far in it will rub on the bearing inside.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-25-2013, 11:35 AM   #8547
Wout67
Wout67's Avatar
Oddometer: 2,183
I bought the bike, and my wife and I noticed the leak after we got home from the sellers. I haven't done any work to it at all.
Thanks for the tips, and the link.
- Abraham Lincoln
www.iamsecond.com
Old 07-25-2013, 09:37 PM   #8548
Captain115
Captain115's Avatar
Oddometer: 282
Alright, so what is the general thought on the oil line banjo bolts?
The one with the smaller cross hole is on the head and the larger cross hole is on the case?
I've read stuff about people enlarging the smaller bolt to have the same sized crossholes as the other one, and other people have said stuff like 'enlarge both cross holes' etc etc.
What is the general consensus? Useless? People just fucking around, thinking it works? Or does it actually improve oil flow?
Cheers,
John
Captain115 is online now   Reply With Quote
Old 07-26-2013, 03:45 AM   #8549
wayne the one
Explorer
wayne the one's Avatar
Oddometer: 251
Cheers,
John
Leave it the way it is. Increasing oil flow to the top end will reduce oil flow through the crank and gearbox.
Its not a ride it's an Adventure
Disclaimer : Ride with me at your own risk
wayne the one is offline   Reply With Quote
Old 07-26-2013, 06:53 AM   #8550
mcma111
mcma111's Avatar
Oddometer: 12,097
Both banjo bolts to the bigger size.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 12:05 AM.
