Old 06-11-2010, 09:31 PM   #1186
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 715
Originally Posted by mcma111
I would suggest you go to www.cheapcycleparts.com and use their parts fitch and compare the fork innards for the different years. They have a very good parts fitch and also the cheapest prices I have found for OE parts.
As for my forks PM me a bid and we'll see. They are just spares resting in the garage.
I've spent some time at Babbitts looking at the diagrams, but I'll check out cheapcycleparts next.
I have four sets of XR500 43 mm forks. So far I've put together the best pair I can manage from the parts I have on hand. Problem with my used stuff is the teflon bushing in the housings. I have eight lower housings, and all of them have worn teflon bushings. This part was not supposed to be replaced as far as I can tell, and it would take a special tool and press fitting to swap in a new one. Only problem that that idea is I can't find any new 43 mm teflon bushings for sale that will fit these original 43 mm housings.
So I quickly realized that a fork upgrade was needed to get parts with replaceable sliding surfaces. If you're looking at a used older XR and you see vertical scratches in the side of the fork rods, it's probably because the teflon coating has worn away and there is metal to metal contact causing the scratches. That's how my old forks were.
I'll send you a PM with an offer double what I paid for the ones FedEx Ground lost. But that is still really cheap compared to the going rate
Ghost_Mutant is offline   Reply With Quote
Old 06-14-2010, 05:26 PM   #1187
elsalvadorklr
southern xr rider
Oddometer: 4,154
hey guys!
Any of you have info on the crank bearings?
I managed to get a 6308 left hand bearing but the supposed 6307 rh bearing is not standard(hence the oem price I guess) anybody have any experience with non oem bearings and why 6307 is not the size?
by the way the diff is its 3mm narrower than the standard 6307 one.
Im all ears once again!
christian
elsalvadorklr is offline   Reply With Quote
Old 06-14-2010, 10:40 PM   #1188
docious
Shit Needs a Rebuild...
Oddometer: 32
Valves
Hello all,
its been a while since i have been around here, but I had a quick question that some of you could answer. Last summer I had my valves re-seated and new ones put in along with new valve seals. While doing an epic ride on the OBDR I realized that my bike was still burning oil. Now that the weather is nice again I decided to go up a size on my piston and bore it out to 98mm (hoping that I would finally stop burning oil). While putting the engine back together I was cleaning up the head and noticing how much carbon built up on my valves after only about 900 miles. I tried scrubbing things the best I could, but after spraying some carb cleaner in the ports to test the seating of the valves I noticed that at least 2 of the 4 were slowly leaking.
So here is my question... Do you think I need new valves and have them re-cut again? I don't have the tools to take the springs off, but I can see there is a fair amount carbon build up on the valves around where they seal. I did try to clean them up with a wire brush and some compressed air.
I am assuming there should be no liquid coming out, or is there a small amount of tolerance?
Thanks for all of your wisdom.
1992 XR600R (Plated)
docious is offline   Reply With Quote
Old 06-15-2010, 05:41 AM   #1189
Dino3310
Oddometer: 673
Hi guys, is the air valve on the top end of the forks(93 XR6) just for bleeding or can air be added for more stiffness, if so how much air?
just watching the wolrd cup - NZ v SLOV 0/0 half time
Dino3310 is offline   Reply With Quote
Old 06-15-2010, 07:53 AM   #1190
mcma111
mcma111's Avatar
Oddometer: 12,588
Valves
docious,
No there should be NO leaks. With such low usage on the engine I would suggest that you return the head to whoever did the machine work for a check up. If you don't get any satisfaction it's time for a new machinest. As to replacing the valves it all depends on the mating surface of the valve seat, if there is enough material for another cut while still seating correctly.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-15-2010, 12:09 PM   #1191
docious
Oddometer: 32
Thanks Steve. I figured as much, but just thought I would double check!
Old 06-15-2010, 12:11 PM   #1192
docious
Oddometer: 32
You can add air, but I think stock settings are 0 psi or close to that. If you are going to add air make sure that your forks are completely uncompressed. Good luck!
Old 06-15-2010, 12:50 PM   #1193
dougrender
Bike Polo is not a Crime
dougrender's Avatar
Oddometer: 1,127
And what is the recommended pressure on the rear reservoir?
-Doug
Boulder County Trail Riders--serving riders' interests in Boulder County, CO
A Bridge Through Laos :: 5 Days out of Vientiane
Moto Catalunya :: A Week Between the Pyrenees and the Mediterranean
Two weeks in Thailand and Vietnam and all you get are these blurry pictures and rambling text.
dougrender is offline   Reply With Quote
Old 06-15-2010, 01:38 PM   #1194
mcma111
mcma111's Avatar
Oddometer: 12,588
The rear shock has a nitrogen charge. For some reason I think the pressure is 185lbs but that is just a guess. It is not something you want to play with.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-15-2010, 04:22 PM   #1195
jamin_mathis
jamin_mathis's Avatar
Oddometer: 2,519
Hay all just picked up a 89'
with
CA plate
Mikuni Flatslide Carburetor
Scott triple clamp
Ansur bars
Rear disk conversion
uni filter
super trap exhaust
And some other stuff I can't remember right now
It had been sitting for months and it was running poorly bad idle and bogging but I cleaned the tank and carb and changed the fuel filter and now its pulling a lot harder than my XR650l
Any how I haven't been able to get it to cold start with out rolling it down a hill. I've jumped up and down on the thing like a monkey for 10mins at a time with no luck. Once warmed up it will usually start with 1 or 2 kicks. Any tips on how to cold start this beast?
A riot is the language of the unheard MLK
jamin_mathis is offline   Reply With Quote
Old 06-15-2010, 06:52 PM   #1196
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Sounds like the idle screw is set on the lean side. Is there a choke on it?
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 06-16-2010, 12:14 AM   #1197
Dino3310
Oddometer: 673
cheers Mate
Old 06-16-2010, 11:25 AM   #1198
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
If you think it idles OK my reco would be to keep the throttle closed when you kick it cold. On my 600, if I even look at the throttle when cold, no start. Make sure the idle and pilot circuits are clear and set. Make sure the plug cap and wire are in good order. Good luck.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 06-16-2010, 11:52 PM   #1199
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 704
if you have not tried it give it a few pumps to prim it, before you kick it two pumps at first. I started doing three pump of gas for the first start and its first kick now cold. mind you this is with a fcr on my 600.
BigNastybrp is offline   Reply With Quote
Old 06-17-2010, 06:08 AM   #1200
elsalvadorklr
southern xr rider
Oddometer: 4,154
clutch part question
hey dudes whats up?
anybody know where part # 11 goes, its not in my box of parts that the bike came with and I have assembled the clutch(out of the case) and everything is there except this PIECE A. also the manual makes no mention of it on installation and dissassembly...is it in the case somewhere?
Im asking because I have to make another order and this one has to be the definitive one in order to start rebuilding(I couldn't find the RH crank bearing at all the bearing suppliers here. oh well) sooooo...please help me out!
Cheers
Times are GMT -7.   It's 11:27 PM.
