Old 12-09-2008, 07:48 AM   #1
PETDOC OP
Oddometer: 1,212
Good glue to repair hard plastic parts?
I have a broken stem on one of the blinkers on my 1150 GS . I have tried to repair it with Locktite Epoxy which is listed for plastics, but after appropriate curing time you can snap the piece at the break and remove the epoxy with your fingernail--obviously not sticking to hard plastic. Anyone have a recommendation for a glue that will repair hard plastic parts?
PETDOC is offline   Reply With Quote
Old 12-09-2008, 08:53 AM   #2
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,910
JB Weld
Not the prettiest repair method, but it works. Scuff and clean the surface on each side of the break, put JB in the break AND coat the surface on each side where you scuffed, clamp or tape together. Let sit for 24 HOURS MINIMUM (preferably inside this time of year).
I've tried darn near every other glue out there, I keep coming back to JB weld because it works.
Guzz is offline   Reply With Quote
Old 12-09-2008, 09:06 AM   #3
Fleg
Fleg in 2012
Fleg's Avatar
Oddometer: 2,127
gorilla glue
Fleg is offline   Reply With Quote
Old 12-09-2008, 09:31 AM   #4
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,223
Dunno if this will work on your 1150 but here's my standard 1100 fix:
This bike recently took a really hard fall and slide on pavement, landing right on that turn signal and it's unbroken.
Old 12-09-2008, 09:49 AM   #5
GSbiker
new and un-improved
GSbiker's Avatar
Oddometer: 11,738
Excellent!!
TRLcam
GSbiker is offline   Reply With Quote
Old 12-09-2008, 10:08 AM   #6
NJ Moto
Running Free
NJ Moto's Avatar
Oddometer: 7,420
Originally Posted by Fleg
gorilla glue
That stuff works great. I've used it outdoors and it's holding up well after 3 years in the elements.
You only need a tiny bit as it expands a lot.
Every ride is an adventure
http://www.youtube.com/watch?v=OuKeu...feature=relmfu
http://www.youtube.com/watch?v=rYqF_BtIwAU
"Can we get a party to finally represent us?" - Cenk Uygur
NJ Moto is offline   Reply With Quote
Old 12-09-2008, 10:36 AM   #7
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
Shoe goo
http://forums.vwvortex.com/zerothread?id=4078371
Scroll 1/3 down.
The guy says this: "Shoe Goo. Seriously, you can't believe how good this stuff works sealing & fixing little crap on your car on the cheap. Even glues broken plastic parts. Like a cross between silicone seal & rubber glue that's 100 times stronger. Get it at a shoe shop, clear or black, $5. You'll wonder how you ever got along without it."
scooteraug02 is offline   Reply With Quote
Old 12-09-2008, 11:46 AM   #8
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 6,110
Just order a new one.
A little wear and tear is expected.
little foot is offline   Reply With Quote
Old 12-09-2008, 12:42 PM   #9
Ozaround
Just kinda riding around
Ozaround's Avatar
Oddometer: 280
There are plastic welding rod kits out. Check into them for fenders/body panels... They work pretty darn good, and you can get teh plastic rods in different colors.
Ozaround is offline   Reply With Quote
Old 12-09-2008, 12:49 PM   #10
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
No matter what type of glue you use, prep the surface first with PVC cement primer. Use a Q-tip as it can mar the surface when it runs. Also, it is made in clear and purple so make sure you get the clear.
GreaseMonkey is offline   Reply With Quote
Old 12-09-2008, 03:43 PM   #11
NJ Moto
Running Free
NJ Moto's Avatar
Oddometer: 7,420
Not only that but if possible I would rough up the two pieces being joined with some sandpaper.
Old 12-09-2008, 04:07 PM   #12
bullfrog
Dismember
bullfrog's Avatar
Oddometer: 591
R1150GS Hacked, Speed Triple 1050, 450XCW Plated
bullfrog is offline   Reply With Quote
Old 12-09-2008, 04:24 PM   #13
scooteraug02
Dog Rancher
Oddometer: 4,527
If everyone just 'ordered a new one" this forum would suck.
My wheel broke, bought a new one....
My engine quit running, bought a new one....
My bike quit running, took it to the dealer....he fixed it....
Old 12-09-2008, 04:42 PM   #14
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,754
Why didn't I think of that???!!
def is offline   Reply With Quote
Old 12-10-2008, 11:28 AM   #15
scooteraug02
Dog Rancher
Oddometer: 4,527
If you like the rubber fix above look at funny pipe in the irrigation section of Home Depot. It is stiffer and about the same diameter. It comes in rolls and 18" pieces.
Times are GMT -7.   It's 12:23 AM.
