Old 12-13-2008, 07:10 PM   #1
DisTech OP
DisTech's Avatar
Oddometer: 616
DisTech's DR650 rebuild
Hello!
Thanks to everyone that contributes to the forums at advrider.com. I've learned a lot here and hope my contribution is not boring.
The goals of this project:
1. Buy 96+ DR650 for $2000 or less.
2. Strip it, then rebuild/reassemble with easily attainable items.
3. A resulting DR650 that is arguably better than a new one and cost less.
Let's begin. There were a lot of people selling newer DR650's for too much at the end of summer. Finally in November on craigslist a one owner 96 with 6800 miles for $2000 in Portland. The wife and I drove down and got it the next Saturday. We stayed at the Hotel Monaco in Portland and came back on Sunday. I felt out of place riding the DR into the underground parking at the Monaco, but was pleasantly surpised at the croud it drew. It seemed all the attendants had DR stories of thier own. The ride back was sunny and the bike ran great. Here she is in all here purple (cringe), yellow and white splendor.
The parts list:
unsourced
Dunlop 606's0.00
Handlebar grips0.00
Dakar Tall Windshield Black0.00
DR350 18" rear wheel0.00
0.00
craigslist
1996 Suzuki DR6502000.00
2000.00
ebay or ebay stores
Acerbis Rally Pro Enduro Handguards Black80.96
ProTaper Contour Cr High bend handlebars Silver62.96
Protaper Oversize Rubber Bar Mounts34.94
Stainless Bolt Kit DR650SE24.99
203.85
ProCycle
Black plastice with UFO front fender319.00
IMS Sainless Steel Footpegs75.95
IMS Tank 4.9gal Black249.95
Moose skid plate75.95
Top End Gasket Set w/metal base gasket49.95
TM40 Mikuni Pumper Carburetor kit449.95
Two Brothers M7 Exhaust34.94
Two Brothers P4 Powertip34.94
Vapor speedo/tach115.95
1406.58
Kientech Engineering
DRC EDG2 LED taillight with license backing65.00
DRZ250 tailight40.00
FMF Hi-Flo stainless steel header179.00
284.00
Cogent Dynamics Motorsport DR650 Shock Rebuild
RaceTech Emulators139.00
RT Fork springs94.00
DR Shock spring 7.1kg @90.00
RT dust seals25.95
RT oil seals16.95
RT Inner bushings17.95
RT outer bushings25.95
Chain roller lower10.00
Shock conversion399.00
Ceramic coating-AOL3-45.00
863.80
Corbin
Seat with build up front like this one.379.00
379.00
Surdyke Harley-Davidson / Buell
HEADLIGHT GRILLE (M0023.1AJAYT)33.10
HDLIGHT ASSY RH (TRAFFIC Y0421.1AD)46.80
MOUNT HEADLAMP (M0645.1ADA)18.84
98.74
mother!5235.97
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech screwed with this post 12-16-2008 at 05:45 PM Reason: prices
DisTech is offline   Reply With Quote
Old 12-13-2008, 07:25 PM   #2
DisTech OP
DisTech's Avatar
Oddometer: 616
Phase 1: Collect underpants
Old 12-13-2008, 07:28 PM   #3
DisTech OP
DisTech's Avatar
Oddometer: 616
Begin depurpleization.
Seattle Powder Coat
The frame, rack and oil cooler guard got sand blasted, two coats of silver and a clear coat. Dropped them off Tuesday and picked them up Thursday. Seattle Powder Coat is great!
Old 12-13-2008, 07:34 PM   #4
brucifer
brucifer's Avatar
Oddometer: 2,474
I love this stuff!
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 12-13-2008, 08:07 PM   #5
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,775
If you're taking the bike off road, you will love the shock after Cogent is done with it.
Did you play hell getting the motor out of the frame? I did. Had to remove the clutch cover to get it back in.....
Fubars is offline   Reply With Quote
Old 12-13-2008, 10:16 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,000
tape off the frame before putting the motor back in so as not to ding it.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-13-2008, 10:42 PM   #7
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
Another Seattle DR650 here. What part of Seattle are you in? I'm near Alki beach.
Your choice of mods is pretty close to mine.
After reading horror stories here and on Thumpertalk about Moose skid plates and it's clones that clamp to the bottom frame tubes, I would recommend against it. If you ride off road you will eventually case a log or rock to get through bad roads. I don't consider myself a radical rider by any means and I have had to drag my bike over a couple things now. There are several stories now of the rear mount bolts on that style skid plate poking holes in the cases and causing oil loss. Watch ebay for old stock Baja Designs DG skid plates or look around for others that mount to the frame bosses further back on the frame.
Here's mine:
Eibach springs
Cogent shock
I have cartridge emultors for the forks that will go on in the next couple months.
Vapor speedo
D606s (great off-road, a bit scary on the slab over 60 or so.) If you get them mounted at a shop, insist that they balance them. I does make a difference. Most will not balance knobbies unless you insist.
Acerbis Rally Pro hand guards and spoilers
DRZ 250 taillight
Baja Designs skid plate off ebay
DJ jet kit
Turbo City rack
I kept the stock exhaust for noise concerns and because I don't want to deal with repacking it.
itsforrest is offline   Reply With Quote
Old 12-14-2008, 02:11 AM   #8
LukasM
Oddometer: 5,425
Ah, the memories... Loving the PC color, silver looks much nicer than the normal grey.
Did the same thing to my 96 DR which was in really bad condition. My list of mods is similar, it never ends! Speaking of which, I should get going on my Scotts damper today.
Good luck and keep us posted.
Old 12-14-2008, 09:11 AM   #9
DisTech OP
DisTech's Avatar
Oddometer: 616
Originally Posted by brucifer
I love this stuff!
First reply, thanks!
Yes, I should have made a video of myself taking it out, because it must have looked ridiculous! I used a 4x4 to lift the engine, one end on my shoulder and the other on a 5' 6x6 and the engine suspended in between. So with my right hand I was trying to guide the direction the engine was being pulled and keep the 6x6 from falling over and with my left I could hang on to the frame and persuade (violently shake) the engine to free itself. I'll definitely do something different putting it back in.
Excellent tip, thanks.
Nice looking bike. I'm in the Wallingford/Greenlake area.
I haven't decided if I want a center stand or not. Do the skid plates that extend further back interfere with DualStar center stands?
Good tip, thanks.
I don't want a loud bike either. I hope the 93db with the P4 Powertip is true.
Lukas, excellent! Lukas' Ultimate DR650 Adventure build up/ rebuild was a huge inspiration. Thanks, I hope the silver looks as good when it's back together.
Old 12-14-2008, 09:25 AM   #10
GB
Mod Squad
GB's Avatar
Oddometer: 56,698
Looking forward to progress reports on this project
Old 12-14-2008, 09:44 AM   #11
DisTech OP
DisTech's Avatar
Oddometer: 616
Toolkit
Tool compartment contents:
toolkit
registration
spark plug
condom
Wait, what was that last one? Apparently, the original owner thought the DR650 was for the ladies!
On another note, it took me a good five minutes banging the tool compartment on the bench to get the toolkit out. I have no idea how you would get it out if the compartment was still on the bike. The tools in the toolkit look like they have never been used. A new tool compartment will have to be part of the rebuild.
Old 12-14-2008, 09:57 AM   #12
DisTech OP
DisTech's Avatar
Oddometer: 616
Thanks, and that reminds me I need to order a couple ADV stickers.
Old 12-14-2008, 11:24 AM   #13
BillC
BillC's Avatar
Oddometer: 1,579
Cool Project Thread
This will end well. Best of luck with your project. The best first step was blasting off that purple paint. I'm guessing suzuki had a bunch of leftover paint, mixed it all together and that's what it produced.
Originally Posted by DisTech
BillC is offline   Reply With Quote
Old 12-14-2008, 11:32 AM   #14
LukasM
Oddometer: 5,425
Glad to hear it, that was my hope when I started the thread. The DR is a great base to start from (solid engine and frame) and since most owners change a lot of the parts anyway, it just makes sense to a buy a used older model. Even with all my upgrades I am under the cost of a new one (well, almost).
If you have any questions or need input on something give me a shout, it's likely that I have been there.
Lukas
Old 12-14-2008, 12:03 PM   #15
DisTech OP
DisTech's Avatar
Oddometer: 616
Broken Exhaust Header bolt
Step 1: Break exhaust header bolt while attempting to remove exhaust.
Step 2: Attempt to remove the rest of the bolt sticking out of the head with vise grips! Optimal results are a red face and a smooth slightly conical shaped stud that make vice grips shoot off (similar to trying to squeeze a watermelon seed (in reverse)).
Step 3: Buy the cheapest "easy out" bolt extractor kit you can find.
Step 4: Attempt to drill the center of the broken bolt. This part went surprisingly well and I was getting my hopes up.
Step 5: The easy out is basically a reverse threaded tap. So the theory is that as you tighten the easy out in the loosening direction of the stuck bolt, the bolt will eventually unscrew. A nice theory, but since you bought the cheapest extractor kit you could find this is what happens. You get the easy out started and at about 3ft/lbs it breaks off in your broken bolt.
Step 6: Learn about tap disintegrators.
Step 7: Try and find a local machine shop that knows what a tap disintegrator is. Favorite responses.
  • a very long pause (with whispering in the background), no.
  • I hate being disintegrated (in the best Marvin the Martian voice summonable on short notice).
  • They make those? Where do you get em?.
Step 8: Send the head to a state where they have tap disintegrators and perform tap removal for a reasonable fee. I used Jerry's Broken Drill and Tap Removal. The head should be back on Tuesday.
The Art of Extraction gives a great explanation (annealing vs hardening) on how to use heat to help get broken bolts out. I decided against using heat because I wasn't sure what that might do to my aluminum head, but Manley's recommendation for brass or stainless steel on exhaust lead me to looking for the DR650 stainless steel bolt kit.
I had also found several references while Googling to bolt removal using various kinds of acid. My favorite is this one,
"I don't know where to get it, but nitric acid will eat the steel bolt and not touch the aluminum. It will also eat flesh, lungs, clothes and the like." This reference also contains a couple reasons why I didn't try this method.
Originally Posted by Richard_A
another option for bolt extraction , weld a nut on the busted bolt , then soak the crap out of it with some PB Blaster , it should then break free , too late for that now huh
Yes indeed! That could (should) have been Step 2. I don't have the means to weld anything myself so I would have had to take it to a shop, but the local shops could have done that faster and cheaper. Ahh, hindsight.
DisTech screwed with this post 12-14-2008 at 05:27 PM Reason: Richard_A
Times are GMT -7.   It's 04:44 PM.
