Old 05-10-2004, 04:44 AM   #1
Tim OP
Tim's Avatar
Oddometer: 2,358
New Scotts Damper Mounting for KTM
Just fitted my new Scotts Damper mounting from KTM Sommer. It puts the damper under the bars and includes the risers (gives a 4cm rise over stock). It's close to the tank but dosen't touch.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 05-10-2004, 04:46 AM   #2
Tim OP
Tim's Avatar
Oddometer: 2,358
You can see the hight better in this one
Old 05-10-2004, 07:48 AM   #3
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
there we go...... much nicer than on top of the bars. what does the mount look like to get it down there? i assume you had to lift the bars a bit too?
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 05-10-2004, 09:05 AM   #4
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Looks great
Looks like a weld on rather than a bolt on, yes?
Sounds like the kit is complete, risers and all, that's cool.
Rad is offline   Reply With Quote
Old 05-10-2004, 09:09 AM   #5
Tim OP
Tim's Avatar
Oddometer: 2,358
This is the mount, the risers shown came with it.
Old 05-10-2004, 09:38 AM   #6
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Weld on?
Old 05-10-2004, 09:47 AM   #7
Carlos M
www.motoxplorers.com
Carlos M's Avatar
Oddometer: 3,373
Bolt on /Weld On.
Originally Posted by Rad
Weld on?
Sommer had a full under bars / bolt on solution that I tried to get some months ago, but for some reason Oliver from Sommer told me it wouldn't fit my 2001. The spigot was on a collar that braced the steering head upper part. It looked perfect, as it was bolt on and it would elevate the bars 40 mm.
Looking at Ktim's it looks like he is using that same kit but with a weld on spigot.
Carlos M.
MotoXplorers.com
Carlos M screwed with this post 05-10-2004 at 09:52 AM Reason: I'm wrong as usual :-)
Carlos M is offline   Reply With Quote
Old 05-10-2004, 10:06 AM   #8
Tim OP
Tim's Avatar
Oddometer: 2,358
Weld on?
Yep
Old 05-10-2004, 10:36 AM   #9
Carlos M
Carlos M's Avatar
Oddometer: 3,373
Tim,
Can you tell us waht's in the kit? Or the kit P/N?
I have a weld on tower in mine which was welded to a brace that bolted through the frame. It's not a definitive solution as the oil in the frame breathes through the holes. I don't have a good pic of it...
I would like to set up something like you have in there as we gain another 10 mm bar height, against the standard risers. Here's sommer's catalogue:
Carlos M.
MotoXplorers.com
Old 05-10-2004, 09:54 PM   #10
ktmnate
ktmnate's Avatar
Oddometer: 3,016
Damn it KTiM!!! you just screwed up my whole list of things to get for the Adventure. I have been working on this thing for just over a year and WHAMO! Thanks!
ktmnate is offline   Reply With Quote
Old 05-11-2004, 02:39 AM   #11
Tim OP
Tim's Avatar
Oddometer: 2,358
cj1150gs, Sommer part number is FLDA1 it is called a "LENKUNGSDAMPFER AUFNAHME", Price 59.48 Euros. The kit includes the damper holder, bar raisers and longer bolts.
Old 05-11-2004, 03:44 AM   #12
Carlos M
Carlos M's Avatar
Oddometer: 3,373
Thanks KTim,
Sommer people, you've got maail..
Carlos M.
MotoXplorers.com
Old 11-13-2004, 11:10 PM   #13
PASSMORE
Just the last name...
PASSMORE's Avatar
Oddometer: 4,250
So if I am getting this all right, for my '01 this kit will work, but it will need to be welded instead of bolted on?
KTim - your set-up still working dandy?
M
- Michael
facebook.com/passmoreranch
PASSMORE is offline   Reply With Quote
Old 11-13-2004, 11:27 PM   #14
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
M
The tower will need to be welded on, but I don't know of any bolt on Scotts damper mount that will work with a "640" LC4, unless you change out the upper triple, or start cutting things like steering locks, and replacing the handlebar bolt nuts on the underside of the triple. (A local machinist fabbed up a triple for his personal Duke II so he could use a bolt on tower mount, he told me there is no way he would ever do it again, major machine shop hours, and a real P.I.T.A.) IMHO, the weld on tower is pretty straight forward, and it works well.
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 11-13-2004, 11:29 PM   #15
PASSMORE
PASSMORE's Avatar
Oddometer: 4,250
Your upper clamps look different on yours Mack. What is your set up exactly?
M
- Michael
Times are GMT -7.   It's 03:41 AM.
