12-14-2008, 01:27 PM
#1 |
Vintage Noob
Oddometer: 53
How unsafe to wear helmet past rating?
I just picked up a used HJC dirt helmet. In good shape...never had a accident.
I noticed the sticker after I bought it (I'm new to riding) and saw the sticker on the back under the Snell & DOT rating. 1996-2008. So...if I'm just trail riding, how unsafe is it to wear this? Do they really get dangerously bad after that rating?
1978 YAMAHA DT400E Vintage Noob & ADVrider wannabe. "Life's too short to be taken seriously" Oscar Wilde |
12-14-2008, 01:44 PM
#2 |
Tryin Hard
Oddometer: 2,764
helmets are generally recommended to be replaced after 5-7yrs (not 12 years by that date range).
Are you sure that the dates don't correspond to when the certification was put in place? Like copywrite notices that say TM 2001-2007 for example? What you are interested in is the label telling you when the hat was manufactured. The Snell date doesn't matter. Other minor point is that used helmets probably won't fit you head anywhere near as well as a new one (the foam does shape to your head) and the plastic shells can easily hide a few drops.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider) |
12-14-2008, 01:47 PM
#3 |
Vintage Noob
Oddometer: 53
Ah...ok.
Thx. Just found it. Feb 07. So..no go, huh? What happens to them...the materials get brittle?
12-14-2008, 01:57 PM
#4 |
Tryin Hard
Oddometer: 2,764
Feb 07 as a manufacture date is practically a new helmet - if you really are sure it hasn't been dropped.
WHat happens to them? UV can degrade the shell, but the biggest problem is that the foam liner collapses. Every time you put it on and wear it, the more you compress the foam. THat's why a helmet gets looser over time. Also, the foam breaks down over time (becomes more brittle and less able to absorb the energy of a collision), and solvents like the petrol coming off the bike also eate the foam (ie don't leave the helmet sitting on the bike filler cap for example). There isn't really a hard and fast rule about replacing helmets, but the more you use it, the more regularly you should replace it. And the recommended 5-7yr life from the manufacturer is probably as good a figure as any for an outside limit.
#5 | |
nrpetersen
Oddometer: 229
If you have a limited budget (and only the govt does not) spend your money where it will do the most good. Do you have a good riding suit etc? I'd rather crash in full leathers w an old helmet vs a new helmet & jeans........ |
12-14-2008, 01:59 PM
#6 | |
Tryin Hard
Oddometer: 2,764
12-14-2008, 02:08 PM
#7 | |
jack of all trades...
Oddometer: 6,587
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
12-14-2008, 02:12 PM
#8 | |
Tryin Hard
Oddometer: 2,764
Has anyone done a test on a 7 yr old helmet, worn often and loaded with sweat?
#9 | |
Vintage Noob
Oddometer: 53
Well...it's actually FEB -97 I'm seeing nothing on the helmet that would suggest anything near any type of impact, no dents, depressions....only light scratches. So...don't use it, huh?
12-14-2008, 02:16 PM
#10 | |
Tryin Hard
Oddometer: 2,764
but it's your call. PS: the composite helmet liners leave a mark of an impact. THe plastic ones happily pop out again and except for a small scratch, can give no indication at all that there is no useful foam under it. To answer your original question, I certainly wouldn't say that a 12yo helmet is "dangerously bad", and is likely to do something better than wearing nothing, but there is probably a lot of good to be said for replacing it.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider) bonox screwed with this post 12-14-2008 at 02:21 PM |
12-14-2008, 02:18 PM
#11 |
Vintage Noob
Oddometer: 53
Ok good point. It IS my head, after all...what little brain it does enclose.
Thx
12-14-2008, 02:28 PM
#12 | ||
Tryin Hard
Oddometer: 2,764
http://journalsip.astm.org/JOURNALS/JAI/PAGES/404.htm but that is an unused shelf life - the hats were not worn, nor were they ever used in an environment that includes volatile solvents. Anecdotal info from a manufacturer: Quote:
12-14-2008, 02:33 PM
#13 |
Vintage Noob
Oddometer: 53
Hmmm...
interesting Thx. I'll be picking one up. I actually just bought a new open face, but I'm thinking full face would be best on trails.
12-14-2008, 02:45 PM
#14 |
Oddometer: 10,901
Only if you'd like to keep your face
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
12-14-2008, 03:06 PM
#15 |
Yeah I'm a chick
Oddometer: 3,448
How about this, it's an HJC. I wouldn't wear it in the first place. Sorry, don't mean to offend.
The sweat is what makes the EPS brittle. If it's a dirt lid, it will be sweat in a lot. The EPS is to be a cushion when your brain slaps against your skull. If the EPS is hard and brittle, then your brain smacks your skull that much harder and that's when things like forgetting how to tie your shoes happen. Like I said, get a good lid which doesn't include an HJC.
[quote=Insert witty comment here] |
