Old 12-16-2008, 04:26 AM   #1
joan-gs OP
If I were a rich man.....
joan-gs's Avatar
Oddometer: 51
Tubliss on the 950SE?
If you did not hear about the tubliss, here a link
http://www.nuetech.com/tubliss.shtml
I only see advantages on this system, provided that they make 2.50 Rims systems.
Anybody mounted this in his KTM?
joan-gs is offline   Reply With Quote
Old 12-16-2008, 04:36 AM   #2
pete40
Life Behind Bars
pete40's Avatar
Oddometer: 1,134
I doubt anybody has on a 950. Last time I looked, the guy making them could not supply too many sizes, especially 18".
The thing definitely works. When the guy does eventually get his act together and produce this thing in large quantities and multiple sizes, it will be a goer for sure.
pete40 is offline   Reply With Quote
Old 12-16-2008, 04:39 AM   #3
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,105
Nice setup.
I find it overpriced though. I believe a fair price would be in the vicinity of $40. The market will descide. Cheers.
There is always a reason!!
gefr screwed with this post 12-16-2008 at 07:11 AM
gefr is online now   Reply With Quote
Old 12-16-2008, 05:58 AM   #4
Hammer
Hawlin' aZZ
Hammer's Avatar
Oddometer: 2,299
I'm running tube-LESS spoke wheels from Woody's. They work fine and hold air. I'm sure he can do the same thing with 18" & 21" as he did with 19 & 17. Guess I don't see the fuss.
Hammer
“If liberty means anything at all, it means the right to tell people what they do not want to hear.”
George Orwell
'06 525 XC "Sledge"
'04 KTM 950 Adventure Thunder
Enough yappin'! Let's ride!
Hammer is offline   Reply With Quote
Old 12-16-2008, 07:06 AM   #5
pete40
Life Behind Bars
pete40's Avatar
Oddometer: 1,134
What method do they use to seal the spoke nipples?
These are on road tyres I presume - it's abit more difficult on off-road.
Old 12-16-2008, 10:34 AM   #6
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 3,667
no speed rating or testing........
Nowwhat is offline   Reply With Quote
Old 12-16-2008, 05:07 PM   #7
Hammer
Hawlin' aZZ
Hammer's Avatar
Oddometer: 2,299
Best to direct your questions to Woody. I bought them 2nd hand, mounted, working fine.
I don't know that sealing spoke nipples is more difficult on an off-road wheel. It may be more difficult on a butter rim like the stock KTM. A good stiff Sun rim and O/S spokes should stay together fine. In fact, I think Woody will gaurantee them.
Hammer
George Orwell
'06 525 XC "Sledge"
Old 12-16-2008, 05:15 PM   #8
twofur
Oddometer: 110
I'm running the tubliss on the 21" wheel on my 530. Works great and holds air at least as well as a tube.
Kurt
twofur is offline   Reply With Quote
Old 12-17-2008, 09:04 AM   #9
charlie264
charlie264's Avatar
Oddometer: 4,997
Didn’t someone here convert their Adv wheels with some kind of aircraft sealant around the inner rim so he could run tubeless?
http://www.advrider.com/forums/showthread.php?t=131165
http://www.teamincomplete.com/Projec...elesswhee.html
charlie264 screwed with this post 12-17-2008 at 09:09 AM
Old 12-27-2008, 08:48 AM   #10
claferal
Oddometer: 156
The problem of the tubliss for road use is that it is failed the tube becomes flat inmediately, like a "boom" and no air into it
www.lc8.es
claferal is offline   Reply With Quote
Old 12-27-2008, 03:47 PM   #11
dlrides
1:1.618
dlrides's Avatar
Oddometer: 4,795
The stock rear is easily converted to tubeless. I have converted the rear on two 950's, never had a leak in 40K + miles.
I must work, millions of losers are depending my taxes for a check.
dlrides is offline   Reply With Quote
Old 02-22-2009, 11:34 AM   #12
farfar
Lejos , lejos
farfar's Avatar
Oddometer: 3
Anybody mounted this in his KTM?[/quote]
I`ve just do it and it seems that it works. This weekend I run 300 km without leaks.IMO, the great advantage is that you can go with 20 Psi or less without flat´s risk .
farfar is offline   Reply With Quote
Old 02-22-2009, 01:35 PM   #13
mookymoo
Mookish Mook
Oddometer: 4,286
I thought it was the opposite - he was discouraging ppl from going that way...
mookymoo is offline   Reply With Quote
Old 02-23-2009, 09:46 AM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,864
I'm going to give it a try on my 950 ADV when I get my new front rim. (1.6") I'll be sure to report back.
This setup should be similar to a sportbike tubeless setup in a flat situation.
The reply I got back from the owner is they may plan to do wider version too.
2.5"x 18" seamed possable for the SE rear. 4.25" he's not so sure.
2.1" for stock front maybe in the future.
I'm sure the more people that contact him showing interest in differant sizes the sooner they may be made.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 04-08-2009, 10:22 AM   #15
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,864
I got my new rim setup back and installed Nuetech 1.6" Tubless system.
Installation was pretty straight forward, W/ a thinner rim, I found getting the new tire on a bit more of a challenge than the wider stock 950 rim.
It's all aired up and ready for testing.
Times are GMT -7.   It's 01:58 AM.
