Old 04-08-2009, 01:49 PM   #16
ARod2000
ARod2000's Avatar
Oddometer: 443
Seems he's made some progress on fulfilling orders. I got mine about a month ago and have them on my Husky WR250. What a difference. Very noticeable. Hadn't even thought of putting them on the big bike but I may move the front over to the 990.
ARod2000 is offline   Reply With Quote
Old 04-08-2009, 02:54 PM   #17
RXV_Poor
RXV_Poor's Avatar
Oddometer: 447
I had 1 of the first generations. Work well once then they didn't reseal. 1 of them wouldn't even seal from the factory. They did standby their product and shipped me new replacements.
I haven't had time to try them yet.
02 Aprilia Mille
06 KTM 525XC
06 KTM 950 ADV S
07 KTM 525EXC
07 Aprilia RXV 550
AMA, BLC, D36, IMBA, STM
Disclaimer:
I'm impulsive, hard headed and sometimes really stupid. Please do not take anything I say or do as a "correct thing" or a "fix" as it could be harmful to your wallet or person.
RXV_Poor is offline   Reply With Quote
Old 04-08-2009, 05:50 PM   #18
Yzlvr
Oddometer: 838
New shipment coming in in a couple of weeks. The 18" are available, but they are only fitting a 1.65" front, or 2.15 rear rim. They said maybe later this year for a 2.5" rim. Also not dot rated.
Yzlvr is online now   Reply With Quote
Old 04-08-2009, 07:14 PM   #19
Katoomer
Katoomer's Avatar
Oddometer: 1,466
Tubliss? A couple of questions for CJ
Hey CJ! How's tricks?.....loving my rack with the new TT panniers. Blockout plates look cool too! I'm thinking of installing the tubliss system on my SE. Doug at Alaska Leather is giving them a try on his ATK 604.....kind of pilot testing them for me. Once I see his report, I'll probably spring for a set too.
Just wondering if you had to drill another hole for the inner bladder? Would I be able to use the rim lock hole instead? I've mounted up a set of TKCs for some on and off-road duty. Had the Dunlops but wanted to get a few more miles out of them. I'm going for a more hard-edged adventure touring mount.
Keep us posted.
Katoomer (a.k.a. Larmo)
Katoomer is offline   Reply With Quote
Old 04-09-2009, 08:51 AM   #20
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,864
The A60 Excel has two 8mm holes in it stock. I opened one up to 10mm for the Rim lock/Air fill stud.
Mine sealed up no problem, I did a test last night.
I aired the tire up to 38psi. and slowing aired down the bladder. When I got to about 80psi air started leaking around the seal. Aired it back up and it stopped....just like it should. These are not d o t approved, but I like living on the edge and trying new things at my own risk. We'll see how it holds up and I'll keep you posted.
Wild bike you have there Katoomer, nice job.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 04-09-2009, 09:20 AM   #21
hollywood_72
Oddometer: 331
Cool idea, but I can buy a lot of tubes (even HD tubes) for the cost this system. And what happens when you get a nail or the like that punctures the inter tube that’s pumped up to 110psi?
Kennedy
'06 KTM 400 EXC Dual Sport W/ Plate Sold and looking for a replacment
www.GLDSMC.org
hollywood_72 is offline   Reply With Quote
Old 04-09-2009, 09:50 AM   #22
Johnf3
Oddometer: 989
Kennedy
If the inner tube punctures, you're SOL. That's the reason I can't convert my dirt bikes over to this system. Not that we have nails on our trails, but have you ever seen a mesquite thorn? It's common for those to be several inches in length and they will make short work of the inner tube in the Tubliss system, I suspect.
I'll stick with the tried and true regular tube/liquid sealant combo for now. Really the only choice for thorn country, besides Mousse inserts.
Otherwise, the Tubliss sustem is the way to go, especially if you are running heavy duty tubes to prevent pinch flats. The tubliss system will save you a couple of pounds of unsprung weight, which is nice.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 01-20-2013, 04:09 PM   #23
homerj
742 Evergreen Terrace
homerj's Avatar
Oddometer: 4,391
How are you liking the tubliss? I'm trying to decide between this and running mousse on an Adv but I dont' really like that solution for dualsporting. And I don't want to have to buy a second front rim (1 for commuting, 1 for dirt riding)
What sort of pressures are you guys running? Is there any special prep necessary for such a heavy bike?
04 KTM 950 ADV
2001 KTM 400 SX
"We're going out Marge, if we don't come back avenge our deaths." -Homer Simpson
"Some people will tell you that slow is good – but I’m here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…"-Hunter S. Thompson
homerj is offline   Reply With Quote
Old 01-21-2013, 06:10 AM   #24
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 205
Tubliss
Yes !
I'm a big fan.
There were a few speed bumps - the initial rim lock had a raised bolt head that could (and did for me, twice) impact the tire on extreme impacts (like a sharp-edged pothole at 40 MPH) causing the tire carcass to be pierced.
This has been addressed by a new forged rim lock that is actually scalloped allowing the tire to compress much more AND not hit against anything solid (yeah the rim does that impact now . . . )
I've found changing tires easy (once I learned the Armor-All trick) and the tire performance and wear has been incredible. My Karoo2's used to be good for a maximum of 4500 miles and last 6500+ miles, now.
Tubes are awful and right behind chains on my hate list. But at least chains have an upside - modifying gear ratios.
2011 Husky TE 630 2011 Husaberg FE 570S
EXC-R 2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good."
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Times are GMT -7.   It's 03:20 PM.
