Old 11-29-2014, 04:49 AM   #1
Aco201 OP
Oddometer: 49
Bouncing and noise from a GSA
I have a 2011 1200 GSA which has been a great bike so far. The bike has 18000 on the ODO meter
However I have 2 small annoying issues...
1. When I reduce the speed from 80-90 km/h and down to city speed as 40-50 km/h, I have a small up and down bouncing /vibration which seems to come from the front of the bike.
I have tried to adjust the ESA, but no changes.
As soon as I speed up again, it disappear.
When I start driving up to 40-50 km/h, I dont notice the bouncing. Only when I come from higher speed and slow down.
Tires have been changed, airpressure have been changed, still the same.
2. On fifth shift only, between 2500 and 3200 rpm, I have weird noise from the bike. I do not know where this noise come from, but it`s like a frequency noise which comes and goes with a sequence between 1 and 0,5 seconds, depending on the rpm. Higher rpm, the faster the frequency noise.
Sounds kind of like a bad ball bearing on the wheel of a car.
Any suggestions?
Philippines: KTM 950 SMR, 2007
Norway: BMW R1200 GSA, 2011
Aco201 screwed with this post 11-29-2014 at 04:55 AM
Aco201 is offline   Reply With Quote
Old 11-29-2014, 05:00 AM   #2
Marki_GSA
Oddometer: 546
What tyres do you have? If you have tourance or similar semi off road these give a vibration that sets up a resonant frequency in the bike giving you number 2. Number one I would first look at tyre condition and balance. I cant think of anything else that would cause this on the front end and could change as the tyre heats and cools if it is a defect with the tyre.
Marki_GSA is online now   Reply With Quote
Old 11-29-2014, 05:10 AM   #3
Aco201 OP
Oddometer: 49
Anakee 2.
I had the same both issue with the original tires (dont remember what type)
2. If it had been the tires, I should have the same sounds on all gears.
If I gear down or up, the sound disappear. It`s only 5 shift.
I can not remember if the sound disappear when I pull in the clutch...
Old 11-29-2014, 05:26 AM   #4
Marki_GSA
Oddometer: 546
Not with a resonant frequency. A specific gear at specific revs sets everything up to be unique. Have a search and you will find lots of posts with the same thing. I can't guarantee with over the Internet diagnostics but it's very common on these bikes with dual sport tyres including mine. I am now on trail attack tyres which are much smoother and quieter and it isn't there anymore. They are useless off road though.
If you have had the bouncing front with different tyres and all have been balanced then check the wheel for being true. No idea why it reacts the way it is other than perception but it's a simple check. Other than that I am out of ideas on the front.
Old 11-29-2014, 05:31 AM   #5
Aco201 OP
Oddometer: 49
I kind of thought it could be the front suspension.
I read an article about changing to Řhlins on a GSA and they said the typical GS bouncing were gone.
I thought what I have might be "the typical GS bouncing"..
Old 11-29-2014, 05:41 AM   #6
Marki_GSA
Oddometer: 546
Something has to make it bounce in the first place though. Suspension doesn't move on its own. No doubt a better shock could cover it up. Mine certainly doesn't do it although I don't have ESA.
Old 11-29-2014, 06:30 AM   #7
Aco201 OP
Oddometer: 49
Movement of the bike and the bumps in the road.
For a while I had a thought that the front damper have air trapped inside..so its bouncing on a bobble of air...
Old 11-29-2014, 06:42 AM   #8
Beemer Rob
Stuck in Ohio
Beemer Rob's Avatar
Oddometer: 63
Bouncing GSA
Take a look at the run out of both of your wheels / tires.
They might be to BMW specs, but not even close to being right.
'Might be time to send the wheels out to Woody for a rework.
He sure cured all of my issues with bouncing and vibrations on both of my GS's with spoke wheels, no matter what tires I use.
Beemer Rob is offline   Reply With Quote
Old 11-29-2014, 06:50 AM   #9
Aco201 OP
Oddometer: 49
I think you have a good point here...I will try to have that done this winter.. :)
Old 11-29-2014, 06:54 AM   #10
JStancampiano
PhotoJoe
JStancampiano's Avatar
Oddometer: 388
Had to do the same with my GSA, stock wire wheels were not straight. Woodies did a great job.
2007 R1200GS ADV, 1978 R100T, 2009 FJR
JStancampiano is offline   Reply With Quote
Old 11-29-2014, 07:29 AM   #11
Aco201 OP
Oddometer: 49
Too balance the wheels after the tire change, a huge amount of weights were needed.
So these 2 problems I have could be a result of several issues and straighten the wheels could help out.
I will give it a try... and pray for a warm winter and an early spring...
Old 11-29-2014, 09:29 AM   #12
WindSailor
WindSailor's Avatar
Oddometer: 648
Maybe try increasing your tire pressure and see what happens....
Sent from my Samsung Note 3
WindSailor is offline   Reply With Quote
Old 11-29-2014, 09:52 AM   #13
Aco201 OP
Oddometer: 49
I have tried several different tire pressures..but it does not change any.
It might be a bad wheel bearing..
Times are GMT -7.   It's 02:21 PM.
