12-19-2008, 06:05 AM
#1 |
Oz Safari Addict
Oddometer: 2,819
Husaberg '09 FE570 rallye bike build
Well after putting in an order with the local WA dealer Wanneroo Motorcycles on 7 November 2007 (day after the Milan show release) for the new to be released 2009 Husaberg FE570 it has finally arrived today
So its been a long gestation Now its straight into converting it to rallye spec for use in '09
![]() Still in the womb ! ![]() giving birth ![]() ![]() ![]() ![]() Specs will be: 2009 FE 570 new out of the crate * Talon cush drive rear hub * Excel Pro Signature 2.5" rear rim laced to Heavy Duty 12g stainless spokes * Force Accesories 2L Safari alloy bashplate * Rear subframe fuel tank mod ~4L * Aqualine Safari main tank ~22-24L total fuel * Ego Barkbusters * Akrapovic carbon slipon muffler * Ohlins SD MX 2.0 steering dampner * BRP 25mm riser submount bracket * HB Thermo fan kit * HB clutch protector * HB frameguards * MD roadbook * ICO VR Light odo X 2 (Main & Backup) * KTM Roadbook carrier frame * KTM Fork bleeders * Stelth rear sprockets * Michelin Baja and Desert rear tires with Michelin MO2 mousses * Pirelli MT410 front tires with Michelin M15 mousses * Motul 300V 4T Factoryline 15W/50 oil * LED dust light * changing springs and setting up suspension * RS Concepts fairing * HID headlights * team graphics ![]()
2013 Husaberg FE501 ![]() 2012 Arctic Cat Wildcat 1000 Rallye
SafariBerg screwed with this post 12-20-2008 at 03:55 AM |
12-19-2008, 08:19 AM
#3 |
dude
Oddometer: 1,589
sweet
ill be watching this one!!!!!!
thanks for sharing. Please post as many photos as you can. THANKS firstworks
dude on a bike... Be who you are and say how you feel because those who mind don't matter and those who matter don't mind~ Dr. Seuss Much of life is simply timing or luck.~Zerk |
12-19-2008, 08:30 AM
#4 |
Life Behind Bars
Oddometer: 1,134
Big Kev may be dead. But I'm excited. Good one mate - have fun building that baby up.
12-19-2008, 12:01 PM
#5 |
Cant ride for crap
Oddometer: 3,408
I like seeing an artist at work. Love the 'berg
Pezz :) Airhead Tragic ![]() I'm not a complete idiot -- Some parts are missing |
12-19-2008, 03:59 PM
#6 |
Oz Safari Addict
Oddometer: 2,819
Sub-frame extra fuel tank
The rear subframe on the new '09 Bergs is plastic, same material as the fuel tank and is a great potential extra fuel cell.
see here http://www.husaberg.org/index.php?na...r=asc&start=15 It has been tested now with no leaks from the fasteners etc, and has a 4 litre capacity, ~50% increase on standard, not bad. Fuel is mainly to the left side, but given that it is carried low, should not be a problem with bike balance. Wall thickness is approximately 3mm. This should be more than enough material for the vent fitting (plus sealing goo). Fitting the balance line, would be best to do similar to the fuel pump with a mounting plate/gasket goo and bolts. With the standard 8.5L it will give 12.5L all up, that will be good enough for Condo and Yilgarn etc. all with the standard slim line body work Great stuff to be able to do that and use the stock body work. I reckon some clever Swede had this at the back of their mind with the design...................why else ?? and given its the same material as the tank !! ![]() Plus it means that only about another 10 L needs to be found with the larger Safari tank for the long range rallyes ![]() ![]() ![]() ![]()
12-19-2008, 04:15 PM
#7 |
Oz Safari Addict
Oddometer: 2,819
NO frivalous bling bits here, no siree, just serious stuff mate !
Some bits already have and will go across from the '08 FE650 to the new one ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
SafariBerg screwed with this post 12-20-2008 at 12:32 AM |
12-19-2008, 04:24 PM
#8 |
vir sapit qui pauca loqui
Oddometer: 2,786
So much bling, so little time.
Nice ride Gary. Congratulations mate. See you at Condo.
Slightly Orange |
12-19-2008, 06:26 PM
#9 |
Commonist
Oddometer: 14,238
Read the write up on them - some innovative features - sub frame, straight inlet, mass centralsation etc. What a beautiful project - best of luck.
7th Day Adventourist. Terrafied It's like comparing Sao's to Monte Carlo's |
12-19-2008, 06:50 PM
#10 |
Oddometer: 2,442
Hey SafariBerg - do they do "rider ability" in anodized blue as well?
JayBo on Safari Bro 1, Kiwi Safari Team, Perth, WA KTM 450 Rally ... arrived ![]() ![]() KTM 530 EXC-R (R for Rally, right!!) ... or Retired or Redundant ![]() Cagiva 750 Elefant - Lucky Explorer '88 |
12-19-2008, 08:11 PM
#11 |
Who dares gets a kebab
Oddometer: 253
Congrats Gary. Must be nice to have a factory funded ride and farkles. Will be watching your progress in the respective races, mate.
And on the seventh day she said, "Go get yourself another bike". The rest is his-story. |
12-19-2008, 08:16 PM
#12 |
Nipple boy
Oddometer: 4,101
One person has a life but the rest of you are just internet nerds
I'm off to the pub (on my bike) . |
12-19-2008, 09:43 PM
#13 |
i like stuff
Oddometer: 4,325
you bastard
those new bergs are a very nice thing. Aqualine making a tank for them is a surprise. the EFi will keep the fuel economy good, what are the oil capacity on them? Titanium valves? is it 6 spd wide ratio? mmmm
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..." |
12-19-2008, 10:01 PM
#14 |
Now sans KLX...
Oddometer: 1,879
Lovely. You'll be trying extra hard not to rub it against too many roos I expect.
"There's nothing I can do about it now" |
12-20-2008, 12:29 AM
#15 |
Oz Safari Addict
Oddometer: 2,819
ok ok I repent
Now that the new bike endorphin euphoria has subsided I will tread the righteous path and not be led into temptation of frivalous andodised blue bling Afterall it is supposed to be a serious rallye bike ! (besides which I just realised how expensive it all is )So will save the sheckels for the Safari costs instead With that aim in mind have amended the proposed bits list below on post #7
SafariBerg screwed with this post 12-20-2008 at 12:51 AM |
