Old 07-01-2009, 04:45 AM   #46
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
Hey Berg, For more gain consider getting in touch with Wayne McDonald from Tuneboy. He does a lot of work remapping KTM ECU's. Once he has a base map of your ECU he then can upload various maps via a connectible cable and laptop which you have stored maps. The guy is a genius and can also address fuel maps etc. He can spread the torque, make it more linear down low and certainly fine tune to any pipe and header mods you have doen to the bike. Only problem is he is in Sydney.
Cheers
Steve
Agito ergo sum - I ride therefore I am!
http://www.adventuremoto.com.au
Your ride.. Your adventure!
SteveRed is offline   Reply With Quote
Old 07-01-2009, 04:51 AM   #47
SafariBerg OP
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,059
Cheers
Steve
thanks for that.
Richie Nyhouse the team head mechanic is in Melbourne and is talking to Richard Muurling of Vortex ignition etc along similar lines, but I will keep Wayne in mind as well.
2013 Husaberg FE501
2014 Arctic Cat Wildcat Z1 1100T Rallye
SafariBerg is offline   Reply With Quote
Old 07-01-2009, 05:28 PM   #48
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
I was talking to richard from Vortex the other day , he add allredy started is KTM injection project ,( he owns a 690motard) i believe the Berg & KTM are the same type ECU's I think ,the 690's have more bullshit hanging off the injection ( fly by wire butterfly valve )
If more people show interest he will get craking , he is currectly working on RMZ, KXF
Mudguts is offline   Reply With Quote
Old 07-01-2009, 05:37 PM   #49
SafariBerg OP
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,059
the Berg & 690 injector is the same part, ECU likely to be very similar as well.
2013 Husaberg FE501
Old 07-01-2009, 05:54 PM   #50
Mudguts
Mudguts's Avatar
Oddometer: 2,123
i have head that the Berg FI tool works on the 690's At $1600 , out of my price range being unempolyed
Old 07-04-2009, 11:28 PM   #51
hicksamunga
hicksamunga's Avatar
Oddometer: 16
The "Flush mount LED blinkers courtesy of CPW Safari" what brand are they? I've been looking around for something similar and they are the best looking example I've seen, a brand name or part number would make it easy to track down over this side of the country
Has CPW got a web site?
07 Berg FE650e
http://www.facebook.com/pages/Hicksa...3013893?ref=ts
hicksamunga is offline   Reply With Quote
Old 07-04-2009, 11:44 PM   #52
SafariBerg OP
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,059
PM him, his ADV id is CPWSAFARI
2013 Husaberg FE501
Old 07-05-2009, 02:43 AM   #53
InertiaDRZ400
AusSafari Addict
InertiaDRZ400's Avatar
Oddometer: 583
Are you using the flush mounts for the front and rear indicators? I tried wiring them up today using the DRC LED flasher unit to find that there wasnt enough resistance for the system to realise they were there and thus flashed all 4 indicators!
Whats your setup?
Safari 2011 ! ........anticipation!
InertiaDRZ400 is offline   Reply With Quote
Old 07-05-2009, 02:46 AM   #54
SafariBerg OP
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,059
Whats your setup?
flush mounts just on the rear
try them with just the stock flasher unit
2013 Husaberg FE501
Old 07-05-2009, 03:32 AM   #55
JayBo1
JayBo1's Avatar
Oddometer: 2,805
Whats your setup?
I used them front and rear and replaced the standard flasher relay with one that SuperCheap had on sale the other week. Works a treat . I have noticed that if only the front or only the rear are connected the remaining ones do not work at all.
JayBo on Safari/Dakar
#101 Dakar 2015, Kiwi Safari Team, Perth, WA
KTM 450 Rally ... Dakar ready
KTM 530 EXC-R
Cagiva 750 Elefant - Lucky Explorer '88
JayBo1 is offline   Reply With Quote
Old 07-05-2009, 03:36 AM   #56
JayBo1
JayBo1's Avatar
Oddometer: 2,805
Or give the shop a ring because he's going on holiday for the week so the shop will have to look after you.
(08) 9434 1653 WST.
The shop is Cycle Products West.
I bought mine from KTM-Parts.com. I'll go and find the packet and let you know what brand they are but CPW's price is good and he has heaps of them in stock because his new order just came in.
KTM 530 EXC-R
Old 07-05-2009, 05:33 AM   #57
hicksamunga
Oddometer: 16
(08) 9434 1653 WST.
cheers i'll give the shop a call
07 Berg FE650e
Old 07-06-2009, 04:34 AM   #58
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
thanks for that.
I spoke to Wayne and he reckons he can apply multiple maps to the Berg for different riding conditions. The difference is he re flashes the ECU at each throttle position rather than say a Vortex where it corrects the ECU. He has already flashed a mates 690 with some success. You could have a map for hard racing, a map for snotty trail where you want the throttle less peaky and more linear and you could even have a map for economy for the transport legs. Ahhh.. The magic of Fuel injection
Old 07-06-2009, 06:34 AM   #59
pete40
Life Behind Bars
pete40's Avatar
Oddometer: 1,311
The 690 map switch has a heap of unused positions after #3 on the dial. I assume all of these could be assigned a different map. Just need to get that switch on the handlebars somehow.
After trying out the programs that are available, you can really notice the difference. I have the Akra map in mine now and it's better than standard one. The #1 position really slows the throttle response right down. it feels like a slug but has a definite purpose in really greasy conditions. I haven't tried the #0 position yet - bad fuel supposedly. Wonder what that does..
pete40 is offline   Reply With Quote
Old 07-06-2009, 02:53 PM   #60
Mudguts
Mudguts's Avatar
Oddometer: 2,123
I'll be extending the map switch cable to handle bar mount or next to the ignition key if possible , I'll let you know how i go, ( hoping just to make a double ended cable with the same connections a simple plug and play , ) but hours of work to make the bloody thing ,
Times are GMT -7.   It's 09:24 AM.
