Old 04-16-2012, 06:10 AM   #15076
bwalsh
bwalsh's Avatar
Oddometer: 12,043
Originally Posted by teeter View Post
I had a great time on my little trip west Friday night. I took bwalsh's suggestion and hit North River CG. When I got to the CG it was chock full of other campers, so I turned around and found a nice cleared site off the road along the stream.
Nice! I was wondering if the campground would be busy. Glad you found a nice spot away from the other campers.
Just read in the paper the Wolf Gap fire is 95% contained.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 04-16-2012, 06:10 AM   #15077
teeter
Frank Zappa the 6th
teeter's Avatar
Oddometer: 939
Originally Posted by dawgwhat View Post
I can't see it...I would like to see it compared to how my VFR does on dirt...lol
I ditched the slideshow.. didn't seem to be working.
FZ6... VFR.. I say that they are ALL made for dirt.
teeter is offline   Reply With Quote
Old 04-16-2012, 07:11 AM   #15078
rctr
Oddometer: 440
Lunch
I think today looks like a BBQ day at Pierces!
Jimmy
Rctr
09 klr 650 (nikita)
rctr is offline   Reply With Quote
Old 04-16-2012, 09:33 AM   #15079
Guy Young
Guy Young's Avatar
Oddometer: 8,502
So, as I was riding around on those forest roads the sharp rocks and harsh chuck holes got me thinking about the possibility of a slashed tire. I always air-down when I'm on those roads, but the PRII's just look like they could get damaged pretty easy regardless. On solo excursions especially, I would like to A. do what I can to avoid a problem and B. resolve it if possible.
The tire pressure recommendations for the bike are below. I generally run them at roughly 34 and 39 respectively and drop it down to the "bottom" limit of 33/36 for rough terrain.
Question #1 - Am I dropping the pressure down enough?
Qustion #2+ - If I slash a tire out there by myself could an inner tube tube potentially save the day? I carry a plug kit and pump, but that can't fix a cut or a slash. I'd happily carry a tube if it would work in a pinch.
0-198 LB
Front:
225 kPa (33 psi) (2.25 kgf/cm²)
Rear:
250 kPa (36 psi) (2.50 kgf/cm²)
198-up
Front:
Rear:
290 kPa (42 psi) (2.90 kgf/cm²)
Bad choice of words.
Yes, a tube in a cut tire with a minor wound would certainly get you out of the woods, so to speak - but - the severity of the cut will dictate just how far you'll get.
When Jason cut his tire on the Brrr Ride, we reinforced the inside of the tire with several layers of duct tape. It didn't look pretty, but it got him all the way back home in Johnstown, PA.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 04-16-2012, 09:35 AM   #15080
Guy Young
Guy Young's Avatar
Oddometer: 8,502
I had a great time on my little trip west Friday night. I took bwalsh's suggestion and hit North River CG. When I got to the CG it was chock full of other campers, so I turned around and found a nice cleared site off the road along the stream. It was a nice little site with enough downed wood to make for a great fire. Saturday morning I got up early and started somewhat randomly picking landmarks on page 66 of the VA A&G and riding to them. As always the FZ6 handled the forest roads beautifully.
Roads musta been really rough. Jiggled your license plate numbers all around.
Old 04-16-2012, 09:43 AM   #15081
teeter
Frank Zappa the 6th
teeter's Avatar
Oddometer: 939
good one!
Old 04-16-2012, 10:41 AM   #15082
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
if thats the case wht kind of tires do you use? and what oil would you recommend?
I got a booger, want some?
dawgwhat is offline   Reply With Quote
Old 04-16-2012, 11:12 AM   #15083
teeter
Frank Zappa the 6th
teeter's Avatar
Oddometer: 939
Not sure about the tires, but you have to use Shell Rotella T Synthetic oil for riding forest roads. It improves traction and could lower your insurance rate by up to 20%.
Old 04-16-2012, 11:58 AM   #15084
ddlewis
squirrel
ddlewis's Avatar
Oddometer: 1,655
...drop it down to the "bottom" limit of 33/36 for rough terrain.
I drop lower than that, like low 20's psi on street radials.. it makes the ride nicer on dirt/gravel. less skittish. this for < 40 mph riding.
Combine 20 psi on FS roads with Rotella and you will notice your teeth getting whiter and brighter!
ddlewis is online now   Reply With Quote
Old 04-16-2012, 12:09 PM   #15085
teeter
Frank Zappa the 6th
teeter's Avatar
Oddometer: 939
Regarding the "low 20's"... Is that a problem when you find pavement again? I guess I'm wondering if you fill up with a pump/compressor as soon as you hit tarmac again or do wait til you hit a gas station. Sometimes I end up going back and forth dirt/pavement/dirt/pavement and can't see wanting to adjust pressure at every transition.
Old 04-16-2012, 12:20 PM   #15086
MotoMujer
Adventurette
MotoMujer's Avatar
Oddometer: 696
This thread is rating high in entertainment value today.
Priors: 73 CB500, 06 F650GS. Next: work in progress.
We're not heroic like the great travelers but all the same we amateurs are a pretty tough breed. No matter how horrendous the last journey we never give up hope for the next one, God knows why. - Martha Gellhorn
MotoMujer is offline   Reply With Quote
Old 04-16-2012, 12:36 PM   #15087
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
I'll have to call my insurance adjuster and get a discount, that's all I use is Rotella...good stuff
maybe my Road Smart tires aren't good enough for dirt !!!!!!!!
Old 04-16-2012, 12:52 PM   #15088
ddlewis
squirrel
ddlewis's Avatar
Oddometer: 1,655
Yep! 20 psi handles like crap on pavement. I'm just saying you CAN in a pinch go lower and it definitely helps. But you're right - it's not worth it unless you have a long ways. (A mile of soft sand is a long ways in my book ) Otherwise best to just suck it up. I carry a little electric pump that plugs into my lectric vest harness.
Old 04-16-2012, 01:06 PM   #15089
teeter
Frank Zappa the 6th
teeter's Avatar
Oddometer: 939
My Pilot Road II's do seem to do well on dirt. I run skeered from mud though. I've gone though little patches of mud and as you can expect those ST shoes slide all over the place.
And for some reason nobody makes a knobby 180...
Old 04-16-2012, 03:23 PM   #15090
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,302
That is my problem. I have not switched the little bike to Rotella yet.
2009 Wee-Strom, 2002 VFR800
Sidecar hack coming soon
jgiacobbe is offline   Reply With Quote
Times are GMT -7.   It's 12:00 AM.
