Old 07-16-2013, 08:09 PM   #24421
Greenflyfarmer
I'm better now.
Greenflyfarmer's Avatar
Oddometer: 1,780
Love my Blackbird with a thermarest. The shelf is great on a hammock. The bug net can be used or not its top load. I'll never sleep on the ground when trees are available anymore. I've been comfortable to below 20 degrees.
I ain't a going without my hog, my gun, my whisky and my Bible.
Greenflyfarmer is offline   Reply With Quote
Old 07-16-2013, 08:28 PM   #24422
ddlewis
squirrel
ddlewis's Avatar
Oddometer: 1,649
Originally Posted by HalfPlate View Post
Dirt
Before you buy a hammock come out to the house and take a nap in some of mine. I swear I think I have one of every brand and type. Find one you like and you're welcome to take it for a trip. Btw that goes for anyone on here. Hammocks and a trial and error thing which can get very expensive.
That's a great offer to try before you buy. some people don't take to it.
Since buying and camping with mine maybe a dozen or so times since last summer I've had a chance to try several much nicers one. I can't tell a ton of difference between them honestly. I think either you can sleep in one or not.. some lay flatter than others, but it's not dramatic. to me.
Blackbird will probably replace this one at some point..
ddlewis is offline   Reply With Quote
Old 07-17-2013, 04:06 AM   #24423
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,289
When you sleep in a hammock where do you put your riding gear so that it isn't full of dew, critters etc in the morning?
jgiacobbe is offline   Reply With Quote
Old 07-17-2013, 04:31 AM   #24424
HalfPlate
What? Where?
HalfPlate's Avatar
Oddometer: 1,092
you cover the hammock and gear with a tarp, normally hung over a ridge line above you. It is actually much less cramped then a tent.
This was at the brr ride a few years back. Well below freezing that morning, I was brewing my morning coffee from inside the hammock before climbing out into the cold.
-07 R1200GS, -09 XT250 (Wife's Ride)
BMW GS Trophy Challenge Qualifier (3rd 2012, 5th 2013)
HalfPlate is offline   Reply With Quote
Old 07-17-2013, 05:14 AM   #24425
dljocky
Oddometer: 864
That is one nice setup!
dljocky is offline   Reply With Quote
Old 07-17-2013, 05:14 AM   #24426
skychs
chuck smith
skychs's Avatar
Oddometer: 1,052
Hammock
Andrew,
I'd like to take you up on your offer. Have always wanted to try a hammock. I already have the tarp. Sounds like a great way to drop the weight and bulk of a tent.
skychs is offline   Reply With Quote
Old 07-17-2013, 05:45 AM   #24427
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,547
So just a sleeping bag inside? No need for a pad?
B.E. Coyote is online now   Reply With Quote
Old 07-17-2013, 08:37 AM   #24428
HalfPlate
What? Where?
HalfPlate's Avatar
Oddometer: 1,092
B.E.
That is my winter set-up it consists of: a ENO double nest (no bug net for the winter), JRB under quilt, JRB top quilt, and a Kelty 60 degree down bag used as a pea pod. It would probably work down to 0 but I have only used it down to 20. I don't use pads (to bulky for my pack) but from what I understand they do two things one help keep you warm and two help stop shoulder squeeze. The ENO squeezes you really tight but in the winter I like that, makes me feel snug and warm. During the spring summer and fall I use a JRB Bear Mountain Bridge that lays completely flat and also does not need a pad if you use a under quilt to stay warm. If your nervous about laying flat look into the bridge hammock. It works like a suspension bridge, the hanging lines arch but the "road bed" lays flat as a board.
Jacks are Better (JRB) is a local company based in Yorktown, the two guys that started it are AT hikers but also ride. If you want more info or want to have a look around their "factory" just give them a call. They are supper nice and will have you out for a look around and set you up with everything you need. Plus their stuff is very well made and comfortable.
Skychs,
Any time you want, just let me know. I have a couple ENOs, a Hennessy, and some home made stuff. I only use the JRB now and tent it when it gets cold, so if you find a set-up you like I am always in need of a good Scotch or something.
BTW Hammocks have a following that is crazy. There is an entire forum for nothing but hammocks, and guys can get very opinionated about the subject. From my experance its best to talk to some local guys about, try out some different hammocks, and then start small and cheap untill you decide on your final set-up. Also remember its no cheaper then a good tent, good down bag, and a good sleeping pad, so plan on spending that for a quality set-up.
Old 07-17-2013, 09:09 AM   #24429
jdrocks
Gravel Runner
Oddometer: 4,492
BTW Hammocks have a following that is crazy...
i've looked at hammocks over the years, but decided to stay with a tent, about 6 lbs. i've camped so many places that have no trees suitable for a hammock, or if trees were nearby, you would end up in dense brush where the bugs would eat you alive. on this last trip, there was only one campsite where it would have been feasible to hang a hammock or hammock/tarp combo, the others, not a chance. i can always find a location to set a tent.
jdrocks is online now   Reply With Quote
Old 07-17-2013, 09:12 AM   #24430
HBN
lostwithmike.com
HBN's Avatar
Oddometer: 11,999
+1
I bring both a hammock and a tent when I'm really travelling
Lost with Mike
12' Ruckus, 01' R1150GS, 75' XL250
Old 07-17-2013, 09:35 AM   #24431
ddlewis
squirrel
ddlewis's Avatar
Oddometer: 1,649
For me the beauty of a hammock is in the summer.. small, light to pack and cooler to sleep in than a tent.
Night temps below 50F starts to get chilly for my light setup. At which point I'd go with the tent. At least until I get some sort of underquilt. Then having to bring extra gear/bulk for the hammock narrows the gap between it and tent and I'm not sure it's worth it after that unless you just love hammocks.
Old 07-17-2013, 10:19 AM   #24432
Dirtmonkey8
VA is for Riders
Dirtmonkey8's Avatar
Oddometer: 1,186
I had never hear of JRB. I am so excited by a "local" business making this stuff I am sending them an order right now. I support local business whenever I can and I have never had the opportunity to do so for any type of gear. Thanks HP.
A little dirt don't hurt.
Dirtmonkey8 is offline   Reply With Quote
Old 07-17-2013, 10:29 AM   #24433
HalfPlate
What? Where?
HalfPlate's Avatar
Oddometer: 1,092
I'll have mine with this weekend if you want to test it out before you buy.
Old 07-17-2013, 10:34 AM   #24434
Dirtmonkey8
VA is for Riders
Oddometer: 1,186
Too late brother. Considering how many you went through I figured it was going to be close enough. Really supporting a local business made it an easy decision. You can help me get mine setup since it may be dark and I will have never even opened the thing up...
Old 07-17-2013, 11:40 AM   #24435
Defaultgateway
Oddometer: 87
2nd option: Satellite Phone
Two choices, spot and delorme
http://www.delorme.com/byIndustry/en...oneworker.aspx
Defaultgateway is offline   Reply With Quote
Times are GMT -7.   It's 03:31 PM.
