Old 04-29-2009, 02:44 PM   #16
ADVHOOLIGAN
DRZ400SM Do-All Sport
ADVHOOLIGAN's Avatar
Oddometer: 41
First post here. Been lurking, purchasing a F800GS in the next 1-2 months.
Anyway, I read an article on the new BMW F800R due out in May and it stated "redesigned throttle linkage for improved response". Could this be a re-design of the current linkage on the F800GS or F650GS? If it turns out to be better, I wonder if the "new" linkage would fit the F800GS? Maybe BMW has been listening to customer complaints and found a solution.
ADVHOOLIGAN is offline   Reply With Quote
Old 04-29-2009, 03:32 PM   #17
tmex
tmex's Avatar
Oddometer: 2,039
BMW never listens to customer complaints. They know what is best for us, and they are usually right.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 04-30-2009, 03:39 AM   #18
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,350
I don't have a 800, but a couple of years aga, I had a KTM 990 with FI. It had the same problem and nearly drove me crazy at first. I did these things and all helped a little, but put together, totally cured it.
First, I put Akra pipes on it and it helped meybe 25%.
Then I dremeled the slot that the throttle cable slides in. A G2 will do the same thing. Helped a little more
Thirdly, KTM finally came out with a remap and problem was totaelly cured.
Then the next week, I sold it and bought a GSA, then I was really happy!!
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 04-30-2009, 08:15 AM   #19
itsatdm
itsatdm's Avatar
Oddometer: 4,970
My bike had very little throttle resistance, which meant a lot of inadverdent throttle apps on rocky roads. Carefully took the slack out which helped a lot. My OEM battery conveniently died at the same time, so was disconnected for 24 hrs. Seems much better now with the new battery. Anybody know if the ECU has a rider learning curve? or am I just imagining further improvement.
Old 04-30-2009, 07:38 PM   #20
Bok Befok
Bok Befok's Avatar
Oddometer: 325
the ktm adv's had the same problem, the G2 throttle came makes the biggest improvement, i assume they would make one for the F800.
Bok Befok is offline   Reply With Quote
Old 05-04-2009, 01:43 PM   #21
robhar54
robhar54's Avatar
Oddometer: 476
Not yet. At least not listed on their website, and they haven't gotten back to me about when it might be coming. I sent an e-mail a couple months ago. I would bet its on the way though.
Rob in Seattle
Adventure Bikes: Rivendell Saluki + Rawland rSogn
robhar54 is offline   Reply With Quote
Old 05-04-2009, 02:27 PM   #22
lawe
lawe
Oddometer: 141
I got a remap at the dealer a couple of weeks ago and after that No Problemo. Much better I think. At least I'm not bothered at all by the throttle response now as I was before.
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 05-04-2009, 02:45 PM   #23
ADVHOOLIGAN
Oddometer: 41
FWIW, I found the article on the F800R and this was the exact quote.......
"A revised linkage makes throttle response even more precise and easy to modulate".
Translation: BMW initially F'd up, but we have now quietly fixed it on the newer bikes, so it should work better, but don't tell anyone, except the moto press.
The bike I took on a demo ride was a 2009 model and I assume it had the newer maps and it was quite noticable. This bike only had 270 miles on it though.
My Sponsor? MasterCard! I only wish it was priceless!
Old 05-04-2009, 04:56 PM   #24
Bayner
Oddometer: 1,608
Rob in Seattle
They took a while to get back to me also Rob. But they did confirm there is one available. They did not give me a part number however....
I asked specifically regarding the heated grip option and their response stated they were not making one as the element is part of the grip and thus the standard model should work. I haven't checked into anything further personally. I would like to have a little more travel initially for offroad but using the traditional 'fingers on brake' method works well enough for now.
Bayner is offline   Reply With Quote
Old 05-04-2009, 06:50 PM   #25
itsatdm
itsatdm's Avatar
Oddometer: 4,970
I have posted on this before. I have had the G2 bmw grip in my hand. It does not have a heating element but the BMW heating element is one of those sticky element pads that goes under the rubber grip. If you are lucky you may be able to peel off the old one and reuse or go aftermarket. The G2 was $70 from my BMW dealer.
Old 05-05-2009, 07:15 AM   #26
tmex
tmex's Avatar
Oddometer: 2,039
I'm not at all sure there are a lot of degrees of freedom here. BMW could remap the throttle position sensors to make the response just about anything they want. All the remapping in the world or different throttle cam shape or throttle linkage design is not going to alter the fact that you have an 85 HP bike off road. I've ridden KX500's and CR500's and other high HP bikes off road, and the feeling is always the same - yikes this thing wants to get away from you. I think you just have to get used to it, and adjust your riding style and technique to accomodate the physics.
Old 05-05-2009, 07:26 AM   #27
lawe
lawe
Oddometer: 141
Yes. tmex, that's true. But the bike actually feels a bit smoother after a software upgrade. Or maybe i just got used to it :-)
No matter what. I just love this bike more and more. Of course there are things that could have been done better on it, but owerall it's a great bike!
Lars
Umeň, Sweden
Times are GMT -7.   It's 06:31 AM.
