Old 07-28-2009, 08:47 PM   #241
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,056
Originally Posted by Grafspee
Put another 60 miles on the bike today - no issue so far. I am starting to think the paste did it, Solo Lobo. Thanks for the tip - I obviously misunderstood Rick.
Maybe I better ride and camp this weekend.
Glad it helped!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 07-28-2009, 09:11 PM   #242
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,238
If the bike dies again on you, there is a way to check if it's the bean can. Pull the front cover and disconnect the three pin plug running from the ICU to the bean can. Pull one of the plugs and lay it on the head connected to the plug wire. Reconnect the battery and turn on the ignition. Now ground the middle connection in that plug - the spark plug should fire. Every time that connection gets grounded the plug should fire. If it doesn't it's the ICU or wiring or connections, not the bean can.
Here's some data for you - and half way down the page is the info on testing. http://bmwmotorcycletech.info/Ignition.htm
Old 07-29-2009, 07:11 AM   #243
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
and keep that little scrap of info tucked away in your brain somewhere. it may save your butt in Mexico one day
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 07-29-2009, 07:20 AM   #244
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,575
I don't have the plug with three contacts anymore.
I use this instead now.
Now I only have 1 wire.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-29-2009, 08:11 AM   #245
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
Points Snob
Old 07-29-2009, 09:31 AM   #246
Grafspee
one bike is never enough
Oddometer: 209
Wink Points snob?
Wrangler - He's just too independent, probably doen't play well with others.
Grafspee screwed with this post 07-29-2009 at 01:37 PM
Grafspee is offline   Reply With Quote
Old 07-29-2009, 09:40 AM   #247
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,575
Wrangler - He just too independent, probably doen't play well with others.
No, Brad's right. I'm a points snob. You're also right, I don't play well with others.
Old 07-29-2009, 11:34 AM   #248
Grafspee
Oddometer: 209
A big THANK YOU to everyone for all the help and suggestions!
Another short ride finished this mornning and bike has run fine, looks like I'm back on the road.
Old 07-29-2009, 03:00 PM   #249
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
So all that D&D time was online or something?
Points ARE where it's at if you need to fix it in the middle of nowhere.
datchew is offline   Reply With Quote
Old 07-29-2009, 05:33 PM   #250
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
I talked to Rick at Motorrad Elektrik this morning about his new system(I'm finally stateside). It sounds really good. The fact that the hall sensor he uses is a commonly available Honeywell part that can be swapped out by any ham-fisted goon is a big plus.
Still, he said if he was going to ride into the bush he said he'd use points too. Oddly enough, that makes me trust his ignition system more knowing that he'd admit that.
Old 07-29-2009, 09:05 PM   #251
igormortis
igormortis's Avatar
Oddometer: 1,382
Way to sneak in quietly without being noticed!
igormortis is offline   Reply With Quote
Old 07-29-2009, 10:34 PM   #252
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,609
yeah I had to do it like that. I smuggled in 50 pounds of illegal fireworks of 15 black market babies.
Old 07-30-2009, 07:42 AM   #253
Wirespokes
Wirespokes's Avatar
Oddometer: 8,238
That was one of the mods I'd heard world travellers made to the G/S. And, frankly, with the points protected inside that can, they last much much longer than the earlier beemers.
Old 07-30-2009, 08:26 AM   #254
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,575
Points aside, (welcome home, Brad) I have another question to address here. What do all of you use to tighten your output flange bolts? I just got my transmission back the other day and have heard several differing opinions on this: the factory manual advises the use of a torque wrench with adapter to get in there, the local dealership said "don't worry about a torque wrench, just wrap a rag around a 10 point 10mm and crank it as HARD as you can. There's no way you're going to break it." Well I did. I stripped the threads right off the bolt - luckily not out of the output flange. The dealership said not to use any loctite. Why not? I think my problem was that I was putting all my heft into it and the threads were lightly lubed with gear oil. Of course it was the very last one of the 4 that stripped.
Also, at the time it was 102 degrees here. That didn't help either. The perfect temperature to stew your anger at.
So my plan for now is just to blast the gear oil out of the threads (after extracting the bolt threads which are still stuck in there, give them a drop of blue loctite and be a LITTLE gentler. Any objections?
Old 07-30-2009, 08:45 AM   #255
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
I use the bolts as dry as possible, no locktite, BMW stock 10mm ring spanner, tap the breaks and give it a good tighten until the ring spanner really hurts the palm of my hand. Never came loose.
I re-use the bolts a couple of times before I replace them.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Times are GMT -7.   It's 05:43 PM.
