Old 09-02-2013, 06:40 PM   #931
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,769
HA! I need a curse word activated camera, so it always catches you fly over the bars, after hearing you shout...OH SHIIIIIIT!!!
Old 09-16-2013, 10:51 AM   #932
Prutser
Prutser's Avatar
Oddometer: 967
Motogadget.
AW are you going to use a breakout Box for the speedo ?
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 09-16-2013, 01:09 PM   #933
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
Yep. I got the B breakout box which will do oil pressure and temp if I add those sensors later. Now I'll just run the basics - turn signal indicator, neutral light, oil pressure switch. I haven't had a chance to mess with the speedo much yet, but I'm pretty impressed with it. The accelerometer can be used like a crude dyno, so it might come in handy for jetting purposes. Better than an ass-dyno at least. There's also an automatic 0-60 timer function.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 09-16-2013, 02:02 PM   #934
Prutser
Prutser's Avatar
Oddometer: 967
For that dyno reason I ordered one today. I'm going to swap the motoscoop mini I have on my ST for the motoscope pro.
I have the motoscope classic on my sidecar and its great.
Ride Report 2012
Old 09-17-2013, 09:03 AM   #935
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,462
My only complaint is that the wires are SO small. They're tough to work with. They're so small that I couldn't find terminals small enough to fit them and had to solder on larger wire to each one to run it into a terminal block.
Old 09-17-2013, 11:03 AM   #936
Prutser
Prutser's Avatar
Oddometer: 967
I know, I did the same thing. but so far mine are still ok with the deutsch connectors. Although I would like to have some thicker wires coming from the speedo.
Ride Report 2012
Old 09-23-2013, 10:49 AM   #937
Prutser
Prutser's Avatar
Oddometer: 967
Did you find the time to mount the speedo AW ?
Just mounted mine and its pure bike porn......!!!
I Was wondering if you are going to use all the temp. and the fuel connections ?
Ride Report 2012
Old 09-23-2013, 11:07 AM   #938
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,462
Yep, I've gotten it hooked up and been out for a few rides with it. I like it a lot. I haven't hooked up the breakout box yet. I don't plan on doing the fuel level sensor as I don't want to mess with drilling holes in my tanks. I'll probably do the oil temp and oil pressure sensors though. I'm still looking for a new house (and garage) so the only work I'm doing on my bike right now happens out at Fubar's shop, half an hour away. Progress is slow right now.
Old 09-23-2013, 11:21 AM   #939
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,288
Hey. I want to hear this thing!!! Got a video??
Old 09-23-2013, 11:24 AM   #940
Prutser
Prutser's Avatar
Oddometer: 967
That your not going to drill holes in the tank doesn't surprise me
I'm planning to put it in my auxiliary tank.
For the oil/water temp I need to start drilling too.
I can't wait to test the G force meter
Ride Report 2012
Old 09-23-2013, 11:34 AM   #941
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,462
Aw, balls. I just fitted up my r100rt mono 2-2 exhaust the other day. Suffice it to say that the 2-1 is LOUD. Not too bad when just cruising along, but when you give it full juice it verges on waking the dead. When I took it off, I weighed the Y pipe, muffler and clamps at a total of 5.5 lbs though - supalight.
Airhead Wrangler screwed with this post 09-23-2013 at 02:51 PM
Old 09-23-2013, 12:57 PM   #942
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 631
with collector box?
Is that system going to affect your performance?
I have the 80RT system and it sounds like a throttled sewing-machine
Ras Thurlo is offline   Reply With Quote
Old 09-23-2013, 01:07 PM   #943
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,462
Originally Posted by Ras Thurlo View Post
with collector box?
Yes, with the collector.
I can't feel any considerable difference in performance, but then again, I haven't dialed in my jetting yet either. I suspect it's more than a bit off. On top of that the top end only has a couple hundred miles on it so far, so it still has some loosening up to do.
I believe the mono 80RT system is exactly the same. It's a LOT quieter now. I still haven't wired up a horn and now that I can't rev my engine and scare the paint off nearby cars, I really need to hook one up before I ride it any more. Also, the rear brake pedal hits the collector box, so I'll need to ask fubar to modify that (still looking for my own garage). Rear brakes are useful.
Airhead Wrangler screwed with this post 09-23-2013 at 02:54 PM
Old 09-23-2013, 02:13 PM   #944
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 631
i thought rear brakes were an optional extra on airheads
I can't feel any considerable difference in performance, It's a LOT quieter now.
I am also thinking of changing my exhaust set-up to something more mellow. Had just got a second hand 100GS 2-into-1 collector box as part of that process.
From what I figured out the Keihan repro collector box is 2 into 2 only, at which point you are probably right to go for a s/h RT set-up.
I like the thud thud sound that these bikes can make, but otherwise want it to be inconspicuous - for both offroad or city riding I think thats a great plus. But judging by the db level of most aftermarket systems I am in the minority on this one.
Ras Thurlo screwed with this post 09-23-2013 at 02:20 PM
Old 09-23-2013, 02:39 PM   #945
igormortis
igormortis's Avatar
Oddometer: 1,298
Add me to that minority. I find loud exhausts wearying over long distances. Maybe AW has the right idea though, a sensible system for travel, and a hooligan exhaust for grins.
igormortis is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
