Old 09-23-2013, 01:41 PM   #946
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,575
Originally Posted by Ras Thurlo View Post
I like the thud thud sound that these bikes can make, but otherwise want it to be inconspicuous
I also really like the sound boxers make wide open - I just don't want to be the guy making the sound. That said, the crackling on overrun with straight through baffle 2-1 was intoxicating.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 09-23-2013 at 01:47 PM
Old 09-23-2013, 01:46 PM   #947
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,575
Originally Posted by igormortis View Post
a sensible system for travel, and a hooligan exhaust for grins.
Exactly what I had in mind.
Old 09-23-2013, 07:02 PM   #948
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,824
Hey AW..you should be making some good headway on the bike right now..quit holding out post some picts!!!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley is online now   Reply With Quote
Old 09-24-2013, 08:33 AM   #949
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,575
I still don't have my own place to work on it though (still looking for a house) and all my tools are in storage, so that presents a few obstacles.
Old 09-24-2013, 08:41 AM   #950
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,575
Originally Posted by Prutser View Post
Did you find the time to mount the speedo AW ?
Just mounted mine and its pure bike porn......!!!
Question. Where are you pulling switched positive power off your m-unit for the motoscope? I'm pulling positive straight off the positive terminal on the m-unit and switched positive off the 'aux' output, but when I hit the starter button it seems to cut power for a moment and reset the motogadget. Not a big deal, but kind of annoying. I tried pulling switched positive from the ignition switch, but it backfed current somehow and kept the m-unit switched on even when the switch was off. How do you have yours wired? I was thinking of hooking it back up to the ignition switch with a diode.
Airhead Wrangler screwed with this post 09-24-2013 at 08:59 AM
Old 09-24-2013, 10:01 AM   #951
Prutser
Prutser's Avatar
Oddometer: 1,030
I Don't have the M-unit on this bike. I mounted it on another R100GS and have one still in the box for a different project.
The switched positive comes from the ignition switch on my bike.
After riding the bike a few times what do you think about the driveshaft without the damper ?
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser screwed with this post 09-26-2013 at 02:21 PM
Prutser is offline   Reply With Quote
Old 10-29-2013, 03:53 AM   #952
ms-oz
Mike
ms-oz's Avatar
Oddometer: 69
Ignition
what ignition/altenator is the one on the photo
Slight wrench in my engine lightening plans. I had forgotten that the engine on Rooney's race bike is a R65 bottom end with 1000cc top end. It appears that he used a R65 case due to the lack of a breather oil condensing tunnel which the R80 and R100 blocks have. See the difference?
It would require a complete redesign of the breather system if I were to remove the upper right part of the engine block casting as well as plugging the small oil drain-back hole into the crankcase. With that whole tunnel arrangement, hose fitting and longer hose, it also means the prize for removing all that mess is even greater: even more weight lost. My only concern with eliminating that long tunnel is increased oil consumption, but if the R65 operated without this arrangement, how much worse could it be?
ms-oz is offline   Reply With Quote
Old 10-29-2013, 06:04 AM   #953
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,979
Hi, Mike!
That looks like a powerdynamo magneto.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 10-29-2013, 06:54 AM   #954
DiabloADV
Semi-Occasional
Oddometer: 2,326
How is the power output on the power dynamo? It's the best price for a combined system, but will it run a bike, driving lights and a gps/phone charger? I don't need heated grips or clothes ...
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 10-29-2013, 08:11 AM   #955
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,979
PD is stock output, so like 180w? Will act like a regular system
Old 10-29-2013, 08:55 AM   #956
DiabloADV
Semi-Occasional
Oddometer: 2,326
Decisions...
PowerDynamo @ ~$700
Silent Hektik @ ~$1100
EME Enduralast @ ~$850
(all w/shipping)
Given the problems reported with the latest batches of EME hardware, that's out for now.
$400 more for SH system...more power, more history, more tuning options...
Gotta think about it some more.
EDIT: SH kit includes coil and cables...closes the gap a bit.
DiabloADV screwed with this post 10-29-2013 at 09:56 AM
Old 10-30-2013, 03:04 AM   #957
ms-oz
Mike
ms-oz's Avatar
Oddometer: 69
Hi Jasen
also thought its powerdynamo but looks like the rotor is closer to the back as on the standard one, and the pick up is mounted to the timing chain cover
Originally Posted by Stagehand View Post
Hi, Mike!
Old 10-30-2013, 03:09 AM   #958
ms-oz
Mike
ms-oz's Avatar
Oddometer: 69
back in good old Germany I had a lot of trouble with SH on guzzis and these memories are so bad I wouldn't try one of his system's even if he would give it to me but I'm pretty safe the owner is a tight ass
I love the powerDynamo for single and dual plugged airheads and what are heated grips?
Decisions...
PowerDynamo @ ~$700
(all w/shipping)
Old 11-04-2013, 09:04 PM   #959
DiabloADV
Semi-Occasional
Oddometer: 2,326
I'm setting up a Baja light and Vapor speedo on my project. Did you put the stock connector board inside the Baja shell? Or....something else...?
Old 11-04-2013, 11:17 PM   #960
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,361
The ST doesn't have the circuit board in the light like earlier BMWs.
I have a Baja Designs light on Gus. I've put in a Boatmans H4 conversion, which is run with some relays held in the bucket. But there isn't a huge amount of space in there.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Times are GMT -7.   It's 06:01 PM.
