Old 07-12-2011, 09:28 AM   #7891
moymurfs
moymurfs's Avatar
Oddometer: 2,215
Duzn't the ECU give the diagnostic computer a code? Then the code is cross referenced to tell the mechanic what specifically is screwing up ?... I doubt the diagnostic computer spit out.. "There's a running problem"........... Could be one of 3 things.. a sensor is out of whack...a mechanical problem..or the ECU itself is screwing up causing the error code..
Sent from my Radio Shack TRS-80 using a keyboard and electricity.
moymurfs is offline   Reply With Quote
Old 07-12-2011, 01:28 PM   #7892
dhillr
dhillr's Avatar
Oddometer: 1,644
The DL 1000 had some ECU recalls in the 06 and 07 timeframe. Worth making a quick call to Suzuki with your VIN and checking on it. Some ECU can be reflashed and some can't. Never heard of a reflash kit for the Stroms. Popular with the 'Busa crowd but never heard of it on a V-strom.
Take the bike to a Suzuki dealer. If I talk trash about Redline ACS gets all spun-up, so I'll leave it at that. I've had great luck with Casey Cycle City.
Goofed around with my 1000 for about two months...tweaking TB's and the like. Still ran like shite so I went with a Power Commander III & a custom map I found on the StromTroopers site. A guy named Chef had the same basic setup as me. Bike was smooth a butter after that.
EDIT
Also, there is a "Self Diagnosis Mode" on the '07 and up ECU's that can tell you quite a bit. If you can get to the bike, give me a call and I can walk you through those checks. Number is in your PM. The "Dealer Diagnosis Mode" is easy to activate once you find the right connector. You just put a jumper on the left two connectors. Code list is below:
Dealer Mode Linky
C00 No error
C11 Camshaft Position Sensor (CMPS) - 1000 Only
C12 Crankshaft Position Sensor (CKPS)
C13 Intake Air Pressure Sensor (IAPS)
C14 Throttle Position Sensor
C15 Engine Coolant Temp. Sensor (ECTS)
C17 Intake Air Pressure Sensor (IAPS) - 07 & Up 650 Only
C21 Intake Air Temp. Sensor (IATS)
C22 Atmospheric Pressure Sensor (APS) - 1000 Only
C23 Tip Over Sensor (TOS)
C24 Ignition Signal #1 (Front Coil)
C25 Ignition Signal #2 (Rear Coil)
C28 Secondary Throttle Valve Actuator (STVA)
C29 Secondary Throttle Position Sensor (STPS)
C31 Gear Position Sensor (GPS)
C32 Injector Signal #1 ( Front)
C33 Injector Signal #2 (Rear)
C40 ISC Valve - 07 & Up 650 Only
C41 Fuel Pump Control System (Fuel Pump Relay)
C42 Ignition Switch Signal (Anti-Theft)
C44 Heated Oxygen Sensor (HO2S)
C49 PAIR Control Solenoid Valve
dhillr screwed with this post 07-12-2011 at 01:50 PM
dhillr is offline   Reply With Quote
Old 07-12-2011, 01:36 PM   #7893
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,549
PcIII really made a difference on my 1k too. Fun playing with diff maps
B.E. Coyote is offline   Reply With Quote
Old 07-12-2011, 09:28 PM   #7894
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Originally Posted by The Stone View Post
Lock your bikes up boys and girls. Some punk ass stole my CRF150 Friday night/Sat morning. Had the back wheel chained to the frame so they must of dragged it somewhere.
As light as that is, they threw it in the back of a truck and were gone. I found three dirt bikes in the back of a van one night, the driver said, "they're not mine." Well no shit genius.
screamin injin is offline   Reply With Quote
Old 07-13-2011, 02:31 AM   #7895
roger123 OP
roger123's Avatar
Oddometer: 1,621
Well we're in cell phone range of the good ole US of A!! Yipppeee. Have I mentioned that I'm looking forward to getting off this ship?
'14 Tenere ES
COG 5903
roger123 is offline   Reply With Quote
Old 07-13-2011, 04:30 AM   #7896
Dash2
Always Learning
Oddometer: 106
welcome home!
Dash2 is offline   Reply With Quote
Old 07-13-2011, 04:36 AM   #7897
UpST8
turnin gas to noise
UpST8's Avatar
Oddometer: 7,226
Welcome home Roger!! Thank you for your service
WHERE AM I RIDING
cRAzY
UpST8 is offline   Reply With Quote
Old 07-13-2011, 05:12 AM   #7898
nuggets
Fries with that?
nuggets's Avatar
Oddometer: 1,821
Wink High sided yesterday
I got tossed pretty good by the little XT yesterday. The picture illustrates what I was doing:
I was happily doing tailslides in a gravel lot, and the rear tire caught and tossed me like a sack of potatos.
My supersuit, gloves, and the ol' tuck-n-roll saved me from suffering any significant consquences from the crash.
My mistake was doing the tailslides on gravel over old pavement. The rear dug through the gravel and grabbed.
Dirtbikes are the best though, just realign the front end with a kick to the wheel, and bend the front brake back, and good to go.
2001 400 EXC "Punkin" | 2005 Sherco 290 "Tree Climber" | OSET 16.0 | OSET 16.0 hard tail
nuggets is offline   Reply With Quote
Old 07-13-2011, 08:18 AM   #7899
screamin injin
FUBAR
Oddometer: 2,519
Welcome home
Old 07-13-2011, 09:52 AM   #7900
HeadShrinker
Lost for a Reason
HeadShrinker's Avatar
Oddometer: 1,459
Originally Posted by screamin injin View Post
Welcome home
+1
HeadShrinker is offline   Reply With Quote
Old 07-13-2011, 10:02 AM   #7901
moymurfs
moymurfs's Avatar
Oddometer: 2,215
+ 3 or 4.
I liked my dad coming home from deployments in the summer a lot better than during the school year......... The niceness of it all lasted longer since report cards weren't in the picture .. (that translates into a longer spell before my next ass whippin')
Old 07-14-2011, 04:11 AM   #7902
BlakKrauStudios
I'm cool... right?
BlakKrauStudios's Avatar
Oddometer: 1,662
I've had good experiences with them, and fewer problems than other shops. So I tend to defend them.
Kinda like someone insulting your wife, and then expecting you to keep quiet.
If I had to venture a guess, it's that it's riding season, everyone has their bikes in for work, and they're getting to it as quickly as they can. Redline's a pretty small shop, and I don't know how many techs they have, but I think the owner runs a pretty tight ship there. Can't imagine him letting anyone screw around and waste time.
For what it's worth, I talked with a guy at Bike Night last night who said he's had his bike into Casey for a tire change for 3 weeks now. For tires.
Working my way towards fascism... one bike at a time.
2009 Ducati Sport 1000
2003 BMW F650GS Dakar
BlakKrauStudios is offline   Reply With Quote
Old 07-14-2011, 04:13 AM   #7903
Henderson757
Adventure~Rugby
Henderson757's Avatar
Oddometer: 414
Pissed
going on 8 days that the bike has been @ . . . LINE motorsports?!? WTF mate why is this taking so long!
Henderson757 is offline   Reply With Quote
Old 07-14-2011, 04:34 AM   #7904
BlakKrauStudios
I'm cool... right?
Oddometer: 1,662
I dunno. Wish I had an answer. All I have is theories.
Old 07-14-2011, 05:55 AM   #7905
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
last call until tomorrow at 9am at
Tony's Famous Grill Inc
2872 Pruden Boulevard, Suffolk, VA 23434-7231
and off to
http://www.boyerstation.com/Welcome/
I got a booger, want some?
dawgwhat is offline   Reply With Quote
Times are GMT -7.   It's 09:16 AM.
