01-23-2011, 10:09 AM
#3361 |
jack of all terrain
Oddometer: 3,092
That was a good race!! Can't wait till INDY! We barely got tickets last year. Think I'll get them ordered up now.
Villopoto will get injured, Stewart will keep choking. GO DUNGEY!! Yellow bikes for life!!....(at least until I can afford an orange bike. HA!)
01-23-2011, 10:17 AM
#3362 |
Oddometer: 2,574
Well I parted ways with the Yellow thing I used to ride,they are not bad bikes for dirt only,but heavier than I would like.
I will be going over to the "dark" side and get on an Orange bike again, one that goes ring ding ding. If anyone runs across a used 250 or 300 EXC or MXC,let me know. May even look at 200exc/mxc. I hear good things about that little motor and single track
everything looks cool on motorcycle "I got so drunk last night I woke this morning and someone had shit my pants" Ron White |
01-23-2011, 10:37 AM
#3363 | |
Oddometer: 2,574
And I have considered a KDX 200/220. I had a pretty well modded 220 back in 98, and it was the MOST dependable bike I have ever owned. I only sold it when the YZ400f's first came out......I really thought I needed one of those. The power of the KDX even modded is not close to the KTM 250,and not even in the ballpark on the 300. And yes I know that most that HP is useless on the type of trails I like,but the 250/300 KTM's also have a lot of lug power on the bottom.
01-23-2011, 12:09 PM
#3364 | |
Shielded by the power of my intense disinterest Save 5 bucks when signing up for SmugMug. Enter coupon code: hgeNbdcSOWAXM |
01-23-2011, 01:35 PM
#3365 |
jack of all terrain
Oddometer: 3,092
01-23-2011, 01:56 PM
#3366 |
jack of all terrain
Oddometer: 3,092
01-23-2011, 03:17 PM
#3367 | |
2 Wheel Wonder Rider
2003 KTM 525 E/XC - APC (Austrian Punkin' Chucker II) 2005 Yamaha FJR1300ABS Honda XR "Complete" S/M Wheels For Sale ---> http://www.advrider.com/forums/showt...9#post20028089 |
01-24-2011, 05:44 AM
#3368 | ||
However; the older you get, I think the less you want to have to use the clutch lever, which is why I got a 250 instead of a 125 for my first dirt bike. But its like Woodsrat says: what do I know. How easily the bike stalls has a lot to do with gear ratio, condition of the tire, condition of the engine (compression), what you are used to, and probably other things that I cant even think of. also, the 200exc has a 6 speed trans, and I thought they all came with a somewhat decent flywheel weight.
01-24-2011, 09:32 AM
#3369 |
Thisweek on Lifetime
Got some serious work done on the uly this weekend. Went through the electrical system, installed some header wrap (i can start growing hair back on my right leg) and got my pannier mounts on the bike. And they just started a 300 dollar deal in the vender section for new panniers. GOODBYE paycheck.
"It was like beating a unicorn to death with a bag of rainbows....sigh.... I'll never forget it" CURRENT WHIP DR650 "Darknesses" |
01-24-2011, 11:40 AM
#3370 | |
Oddometer: 2,574
I bet that was a long talk ![]() That guy knows more about KTM's than KTM. I spent a little time on a 300MXC and I have got to say that thing would lug to almost zero and not stall the motor or hit an open section and flat smoke about anything else out there. BTW Tpar has that beast now I'm sure he will verify this spring. I know I am nowhere near a fast rider but I dont think an EXC will disapoint me out riding. Hope not anyway looks like I will be picking a 250exc up Wed.
01-24-2011, 11:43 AM
#3371 | |
Oddometer: 210
Havn't dealt with him in ages,always thought he was an ok guy,but didn't stop in there without plenty of time to kill... Maybe Beta will bring back the Alp or Ryan Young will get Scorpa going with a street legal T-ride,I know I'm in the market for something along those lines myself.
Doug 2011 Sherco 250 trials,83 Fantic 240 trials,1992 Fantic 309 trials,2009 Kawasaki KLX250s,2001 Super Sherpa |
01-24-2011, 12:31 PM
#3372 | |
Chris
Oddometer: 1,684
With properly setup suspension a hard section should still allow you to motor through. The only bikes that shouldn't use momentum to get through anything are trials bikes (and even then many sections use momentum to help get through) which if ridden at high speeds on trails would typically bottom out and be slower. Their suspension and geometery is set up vastly different. Will you get through the section? Absolutly but it may be easier on a regular bike. But lets go back to the slow guy but now he is on the xr250r mentioned above or something with similiar charactoristics like a slow rev out speed, soft(er) suspension, low power, and a linear power band. These all add up to a bike that doesn't naturally spin its tires, it will be very good at gaining traction in the worst conditions where a two stroke or something with a snappier powerband will break traction much easier. This is where you would want to have plenty of speed going into the obstacle that way you can pull the clutch before you hit it that way you just float through the section then get back on the gas when your past the obstacle. For a reference, I find that when I try and ride slow I tend to wreck much more often and my XR650R definatly doesn't have a low first gear. In fact when I geared it down it made it harder to controll because it gave me too much power in first for damn near everything but it wasn't low enough for second gear. When you go faster the power starts to smooth out because your in a larger ratio, this makes it more forgiving, also big obstacles seem to disappear when hit at a higher speed. Modern suspension with the correct setup will work better at speed unless its setup for just going slow which seems to have a harder time working in fast sections than suspension setup for fast sections works in slow stuff. Its all still relative but thats my 2c
01-24-2011, 01:58 PM
#3373 |
jack of all terrain
Oddometer: 3,092
![]() ![]() ![]() ![]() ![]() Too many words on this page. When in doubt, twist it some more. ![]()
01-24-2011, 02:20 PM
#3374 |
Chris
Oddometer: 1,684
Here ill add some more
This works for me 9 times out of 10, it goes back to holding enough momentum to let the bike carrie you through rather than you having to ride the bike through, but it doesn't work if you slow way down then gas it through, as opposed to continuing with the speed you already have then adding a burst of speed once shit starts hitting the fan. Plus the centrifical force of the tires spinning and the engine spinning will tend to keep you up. Also something to keep in mind. Whenever you hit the brakes hard the bike will dive some, or a lot depending on set up, and this will give you more traction for the front tire and less for the rear but it also changes the geometry of rake and trail. This will throw off the bikes handling and stability so if you do find yourself in shit creek and you need to slam on the brakes, stand up and stick your but way out the back to try and counteract the weight shift as much as possible. This will also allow more braking power from your rear brake before it locks up. Then just double everything when going downhill. header screwed with this post 01-24-2011 at 02:26 PM |
01-24-2011, 04:50 PM
#3375 |
jack of all terrain
Oddometer: 3,092
I just ride for fun. Other than that I have no idea what's going on.
