Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 04-28-2013, 07:32 AM   #11086
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,567
Originally Posted by AC909 View Post
Daaaang somebody is feeling feisty today
naa, paul is gonna bust my chops at every opportunity.. so i gotta get my shots in when i get the chance.
but he, amy and jett got to work at redbird saturday and cleared trails to make it better for us all to ride and not get slapped in face by thorny branches. and... removed that tricky root on the big hill on 41..
was a good day..
this thing is AWESOME... and makes the mach V look like a vagina!
There will only be two things left moving after WW3.
Cockroaches & KLRs.
tpar1220 is offline   Reply With Quote
Old 04-28-2013, 08:51 AM   #11087
RedBirdStation
RedBirdStation's Avatar
Oddometer: 537
Originally Posted by oPAULo View Post
Due to all the go-arounds, root hill is no longer root hill.
Thanks to all who showed up and helped out. Hoping to get some new trails soon out there.
2007 KLR 650
2009 XR650L
Some people try to turn back their odometers.
Not me! I want people to know "why" I look this way.
I've traveled a long way and some of the roads weren't paved.
RedBirdStation is offline   Reply With Quote
Old 04-28-2013, 10:10 AM   #11088
RedBirdStation
Oddometer: 537
Rick, I got your bow saw in my truck. Did anybody end up with a flat red shovel...mine is missing
2007 KLR 650
2009 XR650L
Old 04-28-2013, 11:23 AM   #11089
indypup
indypup's Avatar
Oddometer: 3,761
A little get off while riding in Wayne NF yesterday. I think I had too much air in front tire. I've had a problem of the front end washing out for a while now so any advice from you guys would be appreciated. Tire is like new Dunlop MX51 still with sharp edges. :(
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 04-28-2013, 12:25 PM   #11090
dougfromindy
I smell premix
dougfromindy's Avatar
Oddometer: 2,332
funny because the trail does not look slick.
Did you brake ??
Tires should be at 13/14/15 off road imo.
Stand up, lean back, steer with rear wheel.
After looking at it a few times , the bottom of tire was on slicker trail and the higher part of front tire may have hooked up on grassy sod at trails edge. ????
Suspension set up could be a factor.
dougfromindy is offline   Reply With Quote
Old 04-28-2013, 12:46 PM   #11091
indypup
indypup's Avatar
Oddometer: 3,761
Did you brake ??
I'm not sure what my air pressure was because I didn't check it right before riding. I have the tubliss system installed and have a slow leak in my front tire. The day before I put in about 18 PSI. :(
I hit a ridge in the middle of the trail that had loose stuff and lost it. :(
I think it was a combo of too much air pressure and suspension setup. My rebound and compression on front was set to really soft and my rear preload is at max plus I pulled the forks up in triple about 3/4 in.
I'm going to set everything back to stock and try to get a baseline to work from.
Old 04-28-2013, 01:11 PM   #11092
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,040
Motocross / flat track style
Butt on the seat, outside knee locked on the gas tank, inside leg out, weight forward for more front end traction.
Watch some youtube videos. MX bike seats go way up the gas tank for a reason. Flat trackers pop up into the corners and scoot forward on the seat.
If you've got loaded side and fender cases you should probably sit on the gas tank to help front traction.
I run 20 psi front always unless it's muddy or a race. Then 15.
oPAULo is offline   Reply With Quote
Old 04-28-2013, 02:29 PM   #11093
indypup
indypup's Avatar
Oddometer: 3,761
That could be another problem I have too. I have a scoped out lowered step seat that kind of locks me into position. I also have that tank bag on that prevents me from scooting forward. :( I may just put the stock seat back on and get rid of the tank bag. I know I need to figure this out because this is not the first time I've lost the front end. Landon and I were sort of racing each other down a gravel road out in Colorado and I slowed down and let him win because of my front end washing out in the turns. I told him that's why I let him win even though he didn't believe me. lol
Old 04-28-2013, 02:34 PM   #11094
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,567
was/is your bead on front tire fully seated? in ohio last september i rode with front tire not seated fully on both sides.. i knew it but could not get em seated for nuttin.. decided.... fook it, gonna ride it anyway as i was outta time and sittin at campground with no way to fix it.
i was runnin 12psi. i never had such a hard time on a motorcycle in my life. threw it down at least 6 times, almost threw it down all day. got home and fixed it and all is good.
Cockroaches & KLRs.
Old 04-28-2013, 02:37 PM   #11095
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,496
That remind me of the time Tpar took me riding off road for the first time and put 60psi in my front tire. That dick.
2003 Sv650s; 2012 BMW F650GS; 1999 Suzuki Dr 350se
The Nightmares of Others
In memory of IMPD Officer Perry W Renn. E.O.W July 5, 2014. "I will always get out of my car."
nickgindy is offline   Reply With Quote
Old 04-28-2013, 02:41 PM   #11096
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,567
i just watched your video, you went down awfully close to that tree.. yikes! the way you steered towards it makes me think you lost the rear end first..
were you riding alone?
Cockroaches & KLRs.
Old 04-28-2013, 02:43 PM   #11097
tpar1220 OP
such a pud..
tpar1220's Avatar
Oddometer: 2,567
well... you had bout 100psi in it! so i was tryin to do you a solid..
Cockroaches & KLRs.
Old 04-28-2013, 02:48 PM   #11098
zamboni9
zamboni9's Avatar
Oddometer: 1,312
Awful lot of chatter in this board for a 60 degree Sunday afternoon. Shouldnt you all be out riding? I would be but "working".
Riders for Striders Charity Ride May 16, 2015
http://www.ridersforstriders.org
Suzuki DR-Z400SM, Ural T
"...a Ural is to gravel, what a hovercraft is to water.."-IndyChizzle
zamboni9 is offline   Reply With Quote
Old 04-28-2013, 02:52 PM   #11099
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 2,496
Originally Posted by Small's View Post
Finally go to look through these. Man I'm excited for my trip in September.
Old 04-28-2013, 03:02 PM   #11100
indypup
indypup's Avatar
Oddometer: 3,761
No, not this time. My buddy was ahead of me. I didn't realize how close I came to that tree until I watched the video. :(
I really don't know what happened or why but would like to find out!
Times are GMT -7.   It's 09:38 PM.
