Old 06-09-2009, 05:27 PM   #181
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,477
drrags ! You bought one too ha ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 06-13-2009, 08:40 AM   #182
hardbern
Oddometer: 4
Stalling in rain for some F800GS and F650GS
If your F800GS or F650GS runs great but stalls in heavy rain at no or low throttle settings, it is due to water getting into the airbox, pooling in the bottom until it gets sucked into the Idle Air Control pathway. The idle air path is the only way air is reaching the motor when the throttle butterflies are closed (and during that small transition when butterflies are slighly opened). What kills the motor (when throttle is nearly closed/chopped closed) is that the idle air is passage is essentially closed by the water. This is also why it surges at small throttle openings, and runs fine at larger throttle opening. Water sucked into the combustion chamber only makes it run rough - water vapor makes it run a little better. But no air makes it no a'run at all.
In my case the water wasn't getting sucked in the snorkles, it was creeping past the seal that is supossed to be formed by the rubber edge of the airfilter element. This was evident by the snorkles still being dusty with pollen and a cobweb intact in the airfliter cover (and I ride everyday-?!), but a slathering of dried dirt/mud around the base of the airfilter cover. Take it apart and you can see that it would be easy for someone, at the factory say, to be sloppy in putting the cover on. I believe some people are not having the problem because their filter is making a good seal. If you took it apart between the problem happening and instituting some form of 'fix', then you may have reinstalled it correctly, thus eliminating the problem and convincing you that your fix did the trick.
Once the watersource is turned off, the waterpool at the bottom inside of the airbox dries up pretty quickly during running by evaporating into the flow of intake air.
I do not discount the idea that water may also get in thru the snorkels. It may enter on all bikes with similar intake setups, but the water does not clog important idle airways in those bikes (such as f800S/ST).
BMW's fix, if they ever get around to it, will likely be to either improve the airfilter element gasket edge or redesign the airfilter cover so that sloppy assembly doesn't creat the problem in the first place. Maybe they will do the right thing and redesign the airbox to put the idle control valve intake hole higher up.
hardbern is offline   Reply With Quote
Old 06-13-2009, 05:20 PM   #183
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 177
Heavy Rain - My GS stalled !
Oh my god - my worse fears are about to be realized. The "go anywhere" and "do anything" combat touring motorcycle didn't make it back form the first storm of the season. BMW's F800 GS does not run in the rain.
OK - if you want to be ready for rain you should go out and practice before you're a thousand miles form home. So the clouds rolled in and I went for a spin. The rain was very hard and it came down in buckets. I was traveling along in traffic when the tach goes to ZERO and I'm rolling down the road at 40 mph. I gently slipped the clutch and the compression almost cause a high speed skid so I rolled to the side of the road to get out of the way of all the cars and trucks.
At first the engine would NOT restart and I sat in the rain for a long while - in a complete state of shock and dismay. It eventually restarted but ran very rough all the way back.
I ran my Honda 750 in the rain - the 919 was never bothered and the VFR ate up miles of interstate in thunderstorm after thunderstorm on my last tour - high speed touring with torrential wind driven RAIN for hour after hour. My rain gear worked and so did my motorcycle!
Today I was stuck on the side of the road five minutes from home - some %$#*ing adventure type guy am I. FIRST TIME EVER. The most expensive bike I ever bought and it won't run in the rain. Ten minutes into a storm and the party is over!
Anyone want to comment?
Yea the new guy is pissed.
solohvs is offline   Reply With Quote
Old 06-13-2009, 06:21 PM   #184
DockingPilot
Oddometer: 9,477
Make sure you report it to your dealer or BMW NA.
Frank Reinbold
Old 06-20-2009, 06:21 PM   #185
solohvs
solohvs's Avatar
Oddometer: 177
They took my new bike
The dealer went over my bike on Friday for the stalling issue and there were no fault codes and no sign of any water. There was no information available to suggest an ongoing problem with this model and nothing from BMW NA.
On Saturday I was caught in the rain again and within minutes the stalling was enough to cause me to cancel my plans to tour all weekend and head for the dealer. A real let down.
Water is backing up into the evap canister and the fuel tank can't breath. There is a problem with the vacuum system that could not be resolved. A drain tube was added to just divert the water, but the mechanic was NOT comfortable with all the loose ends and I was asked to leave with a DEMO F800 GS (and not ride in the rain).
1300 miles and my new GS is in the shop and cannot be repaired.
The Dealer will contact BMW NA on Monday and determine what the "fix" will be. I have seen as many posts explaining that the problem does NOT exist as I have seen where the problem does exist.
What now?
Brian
Old 06-20-2009, 07:45 PM   #186
GB
Mod Squad
GB's Avatar
Oddometer: 55,995
How about you remove the evaporative cannister.. the US is the only market in the world to have it.. I've ridden in the rain with mine without any issues. My bike has no cannister.
Old 06-21-2009, 01:18 PM   #187
outpostbabu
outpostbabu's Avatar
Oddometer: 202
What now?
Brian
Each complaint is a vote for a fix so bringing it up to the dealer, BMW NA, and posting in forums like this is helpful to the rest of us experiencing the problem. My dealer claimed to have never of heard of such a problem with the bike. I find it hard to believe given the number of people experiencing issues.
http://www.fortunemegastore.com
outpostbabu is offline   Reply With Quote
Old 06-21-2009, 09:49 PM   #188
never.ride
never.ride's Avatar
Oddometer: 326
Stalling - NO Rain riding!!
My bike, which has 1300 miles on it now has had stalling issues with NO rain involved. Been riding about 70/30, dirt to street.
First time was with approx 300 miles on the clock. Happened after a bout 3 hours high up in the mtns, over 8500 feet. It would cut out in 1st or second at low/idle RPM's. Then, when I tried to start it would instantly die. Had to rev the RPM's and drop in in first to get going.
Took it in for the 600 miles and they said, "weird". They re-set the "adaptations" saying I probably messed them up when I rev'ed the engine to start it. I had to pay for this.
Now, 1300 miles in, and I'm having the same thing, but worse and more often. Only happens after I riding for a few hours, which always ends up being over 8500 (I live in Boulder, CO). It would just cut out all the time, especially after I shut it off for a few minutes. Would be really hard to start as well, jut cut right out. Caused me to drop the bike on pavement once, which was a total drag.
Let it sit in my cool garage for a 2 hours once I got home and the same thing, sputtering and then cut out in neutral.
Obviously I'm gonna call the dealer, but anyone have any suggestions or thoughts?
Thanks in advance!!
never.ride is offline   Reply With Quote
Old 06-22-2009, 06:07 AM   #189
solohvs
solohvs's Avatar
Oddometer: 177
Stalling in the rain - What will BMW Do Now?
Today my Dealer will contact BMW NA asking what to do as a remedy to this RAIN/STALLING problem. I doubt they can authorize the removal of the canister without considering the emissions requirements that put the canister there in the first place. Although the removal of the canister might be the fastest way to get MY F800 GS back on the road. That would seem like FORD telling the dealers to remove.... a catalytic converter if a design flaw made engines run rough IN CERTAIN CONDITIONS.
It seems like the vacuum lines at the back of the box will need to be relocated, but I don't like the idea that my Dealer will have to drill holes and IMPROVISE. I like the people at the Dealer. When I showed up in the pouring rain they waved me into the service area immediately and began work on my bike before I even had my helmet off.
I don't want them caught in the middle.
I have respect for what they tried to do for me, but I just cancelled a three day tour with four of my friends. A 1200 GS a couple of KLRs and a FJR - I just told them keep riding and not to look back. I would try to have my bike repaired and ready for the next trip.
Was the engine damaged after 45 minutes of misfiring and uneven fuel delivery?
Was water sucked into the engine?
Will there be long term issues with reliability because of IMPROVISED modifications?
Is my motorcycle ALREADY at risk for future problems?
Did water intrude into other places the engineers never dreamed possible?
With every passing day my mind races ahead with seemingly stupid questions. I plan to spend the entire afternoon on this project. I'll give the Dealer a chance to communicate with BMW NA and then I'll get on the phone. I will have to admit that I have been quite shaken by nearly crashing when the engine stalled the first time AND all that has happened so far.
Brian
Item - overfilling the fuel tank can cause extra fuel to drain into the evap canister.
Can this also happen during "spirited" off road use?
Old 06-22-2009, 07:34 PM   #190
RogerA
Continually Confused
RogerA's Avatar
Oddometer: 73
http://www.bmwmoa.org/forum/showthre...d=1#post471324
My wife called BMW Customer service today, she spoke to "Richard".
She explained what happened on both her F650GS and F800GS,
she explained that the stalling problem had left her sitting in the road on an exit ramp,
she explained that for the first time in many years she was afraid to ride her bike in the rain, and
she explained that there several pages on f800riders.org forum detailing this problem, including several owners who have stated that they have reported it to BMW.
Richard said he would check and call her back, when he did he stated that "they have not heard of this problem".
Very reassuring
Roger
2011 BMW R1200GS Adventure / 2009 Triumph Thruxton
Bikes I never should have sold: Honda 90 / Honda CB 250 / 1961 Triumph T110 / 1971 Triumph Bonneville / 2000 Kawasaki ZRX1100 / 2002 Kawasaki ZRX1200 / 2005 Kawasaki ZX636 / 2005 Kawasaki ZX12R / 2007 R1200GSA
RogerA is offline   Reply With Quote
Old 06-22-2009, 08:40 PM   #191
Benjava
Benjava's Avatar
Oddometer: 1,920
"Took it in for the 600 miles and they said, "weird". They re-set the "adaptations" saying I probably messed them up when I rev'ed the engine to start it. I had to pay for this. "
What? Just unbelievable.
"Limbautomy" what's the Rush?
Benjava is offline   Reply With Quote
Old 06-22-2009, 09:27 PM   #192
anodyne
anodyne's Avatar
Oddometer: 235
I'd like to know which area dealer this was. If you could PM or post that would be appreciated. Thanks.
anodyne is offline   Reply With Quote
Old 06-22-2009, 10:09 PM   #193
never.ride
never.ride's Avatar
Oddometer: 326
Well, I'll see how they handle it when I take it in tomorrow, before I chuck them under the bus. I don't have an appointment, but I want to get it fixed and I'm just gonna leave it. It won't start in my garage right now, so we'll see.....
Old 06-26-2009, 08:47 AM   #194
Calibob
Lost Soul
Calibob's Avatar
Oddometer: 23
Rain surging
Just returned from a trip and had a couple of instances where my 800gs would surge as if it was running out of gas. The bike never completely stalled but the surging was very unnerving. Both instances were in heavy rain. We'll have to see if the dealer can find anything. These types of issues are a pain since they are difficult, if not impossible to recreate for the dealer.
09 F800GS
7500 miles
Calibob
Big Bear Trail Riders
Calibob is offline   Reply With Quote
Old 06-26-2009, 08:41 PM   #195
RogerA
RogerA's Avatar
Oddometer: 73
BMW of SE Michigan arranged for Kathy's F800GS to be checked by BMW of Denver.
Before we arrived in Denver Richard from BMW NA called twice to see how the bike was running.
We arrived in Denver on Wednesday.
Eli Myrick (Master Technician) inspected the bike and immediatly commented that the vent tube from the charcoal cannister was lower than he would have expected and very close to the rear wheel.
He sprayed water into both intakes with the engine running - no problem - no stall.
He then put the vent tube into a container of water and continued to run the motor - within 2 minutes the motor stalled. - the exact same period of time that the engine stalled after we ran into rain. The charcaol container was full of water.
He rerouted the vent tube away from the spray from the rear wheel.
Since that time we have run into light to moderate rain - NO STALL - we can't be sure the problem has gone away until we run into heavy rain, but so far it looks good.
I had pretty much given up on BMW Dealers, they didn't seem to have any concept of customer service. It's time to eat my words.
BMW of SE Michigan, Owen B, John (Owner), and the sales staff could not have been more friendly and helpful when we were there. They have called several times to see how we are doing,
BMW of Denver are from the same mold, Rick Zimmerman (Service manager), Joe Francis (Service Advisor), Eli Myrick (Master Technician), and Chris (Sales) were all customer service oriented, the service was exceptional. They have also followed up to see if the rerouted vent tube fixed the problem.
We have another 2 days to get back to Florida, as soon as we get heavy rain I'll post a defintive result.
Roger
Roger
Times are GMT -7.   It's 02:40 AM.
