Old 01-21-2009, 06:28 AM   #16
Bucko OP
In a parallel world
Bucko's Avatar
Oddometer: 819
Got my recall notice in the mail yesterday. It says they will remove all sprocket fasteners, inspect them, and replace damaged ones.
Und ze vant it done IMMEDIATELY! Do you sink zay have ze pahrts?
Recall campaign is 08V-692.
Bucko is offline   Reply With Quote
Old 01-21-2009, 08:14 AM   #17
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,835
Got mine
guess I know what I'm doing soon...
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is online now   Reply With Quote
Old 01-21-2009, 10:40 AM   #18
Navaho
Navaho's Avatar
Oddometer: 1,043
There are two recalls, one for the rear sprocket bolts that may have been torqued wrong and the other for questionable bolt length on the front brake disc.
Navaho is offline   Reply With Quote
Old 01-21-2009, 11:06 AM   #19
Bucko OP
In a parallel world
Bucko's Avatar
Oddometer: 819
Do you have a campaign number for the front brake recall? I haven't gotten the word on that one from BMW.
Old 01-21-2009, 12:38 PM   #20
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,213
When did you purchase your GS? I'm trying to determine (based on when I bought mine) if I'm in the risk category. I've yet to receive a notice. But then I purchased in late November.
IIRC, the front brake bolt recall is for F650GS bikes only.
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 01-21-2009, 12:59 PM   #21
markymcd
markymcd's Avatar
Oddometer: 888
On the note of recalls, you may want to check your upper radiator hose where it connects to the engine. if it looks like your hose is not on properly... it isn't. There is a "service recall notice" which i was told they will not let you know about until you approach them AFTER your hose has come off or leaked fluid all over your engine and pipes (which is what just happened to me).
I've heard lot's of rumbling about the possible issue with that hose, so if it looks bad on yours, take it to your dealer and have them order the replacement 'longer' hose before it pops off when you're in the middle of nowhere.
The fluid seems to have pitted my header pipes so i'm waiting to hear if they are going to replace them.
THANKS BMW!
Mark
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 01-21-2009, 02:35 PM   #22
ROYAL COACHMAN
ROYAL COACHMAN's Avatar
Oddometer: 937
THANKS BMW!
Mark
If I understand you correctly, the problem is with the hose and not the clamp, correct?
Glen
ROYAL COACHMAN is offline   Reply With Quote
Old 01-21-2009, 03:36 PM   #23
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,488
I got my notice today regarding the sprocket.
PhilSpace is offline   Reply With Quote
Old 01-21-2009, 03:46 PM   #24
markymcd
markymcd's Avatar
Oddometer: 888
Glen
well, they say it's the hose, but that clamp doesn't look like it's cuttin' the mustard either. when i get it back i'm going to keep an eye on it and if it moves i'm gonna add a better hose clamp on it.
Old 01-22-2009, 07:15 AM   #25
Bucko OP
In a parallel world
Bucko's Avatar
Oddometer: 819
I bought my bike in September. Called the dealer yesterday and they have the parts for the sprocket recall. I'm not on the brake rotor recall. Will check the rad hose this weekend. Sounds like a mess if it fails.
Old 01-22-2009, 06:44 PM   #26
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,835
Here's the skinny on the sprocket recall:
The original procedure called for the sprocket nuts to be torqued to 25 newton-meters.
this has, apparently (haven't actually heard of any) led to a few cases of one or more of the nuts coming loose.
The new procedure calls for them to be tightened to 10 newton meters, plus 90 degrees.
the recall calls for each nut (one at a time, not all at once) to be loosened, then retightened using the updated procedure.
If any nuts are loose, then prior to retightening the sprocket is to be removed, and all parts inspected for damage, and replaced if necessary.
Old 01-23-2009, 09:05 PM   #27
Dr. Zaius
Dr. Zaius's Avatar
Oddometer: 244
Got my notice today as well for the rear sprockets.
Dr. Zaius is offline   Reply With Quote
Old 01-24-2009, 04:31 AM   #28
Dieselboy
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,176
Originally Posted by ]I)Money
...The new procedure calls for them to be tightened to 10 newton meters, plus 90 degrees...
Got mine done two days ago. This was the procedure, 10+90. Dealer was a bit pissed by not being aware of the recall. I brought my notice in and they hunted it up.
A word of advice: don't assume that your dealer has been alerted by BMW.
I've not seen the bolt nor hose issue. Anyone got more solid info, perhaps a reference number to the bulletin or recall?
Dieselboy
The Adventure Continues
Dieselboy is offline   Reply With Quote
Old 01-24-2009, 08:03 PM   #29
Nemesis
just ride the damn thing
Nemesis's Avatar
Oddometer: 422
You've got it backwards, don't assume your dealer takes the time to read the bulletins BMW sends to ALL dealers.
The notice hit the dealer network website in December.
"I can tell you with no ego, this is my finest sword. If on your journey, you should encounter God, God will be cut." - Hattori Hanzo
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats " - H. L. Mencken
Nemesis is offline   Reply With Quote
Old 01-25-2009, 08:13 PM   #30
OaklandLion
Oddometer: 295
I go in tuesday for the fix. Dealer had to order the parts, so be sure to call ahead.
The hose thing will be discussed when I go in, thanks.
OaklandLion is offline   Reply With Quote
Times are GMT -7.   It's 01:07 PM.
