Old 03-25-2010, 08:51 AM   #196
Light Rider
Light Rider's Avatar
Oddometer: 51
Originally Posted by XRider
So you want to add a brake light and a horn without installing a DSK or even a dual sport handle bar switch? They don't ask much in Colorado do they?
It's pretty straight forward: Behind the headlight you'll find a green wire and a blue wire. They power the headlight and are regulated 12 vac. Tap into the blue wire and run that to one side of your horn. Get an old kill switch, the type that grounds out to the handle bar, and connect it to the other side of the horn. Press the kill button and it should beep. Although I've never tried to power one of those horns with AC but I think it will work....
Thanks XRider... according to the horn box it's just "12v" (no AC/DC info) - so I'll give that a try. (BTW - I'm assuming DSK= Dual sport kit?)
On the BajaDesigns tail light I just noticed that the angle of the LEDs on my piggie are pointed down a bit, so it makes the running light relatively hard to see. Haven't tried the brake yet. Is it possible to leave the stock running light plugged in as well (hook both lights into the same lead)? I can't imagine they draw much juice.
Yeah - I'm a bit of a hack, but I do like having my wiring organized so i already have a full electrical kit/crimps etc... I'm using shrink on all the connections as well to keep it as water tight as possible.
Thanks again.
'13 500 xc-w Plated
01 XR400R - Plated
Light Rider is offline   Reply With Quote
Old 03-25-2010, 02:54 PM   #197
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
I replaced the socket on the stock running light so it will accept an 1157 bulb. So now both tail lights (the B.D. LED & the stocker)are functional running/brake lights. If you make the stock tail light just a running light then no one will notice the LED brake light when it goes on. That's trimming from your safety margin.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 03-25-2010, 09:31 PM   #198
Light Rider
Oddometer: 51
Now we're talking... Any old 3 wire socket, or would you recommend a particular vendor?
'13 500 xc-w Plated
01 XR400R - Plated
Old 03-26-2010, 02:53 AM   #199
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Get the smallest and shortest all metal socket you can find. Then take a welding rod (or a coat hanger) and bend it in a U. Solder the socket into the U. Then bend the legs into feet with little hoops. Use pop rivets through the hoops to hold the socket on. For it to fit under the lens it has to be as low to the fender as possible and the back of the socket should be right on the wire grommet (in the fender).
Old 03-26-2010, 03:02 AM   #200
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,327
For what it's worth, I first ran a regular bulb holder in my XR650R rear light, but even then the bulb touched the lens...
I recommend the DRC LED insert - it's only about $15 as I recall, and gives you a really nice bright tail and brake light.
Also, I doubt you'll get a regular [most are DC] horn to work with AC - I tried on my XR400 years ago and it just went 'neh' and then died...
I ended up replacing the regulator with a reg/rectifier (and a capacitor to help smooth the charge) thus supplying DC which makes everything work much better, and gives you a feed for a GPS too if you want it...
J xx
JMo (& piglet) is offline   Reply With Quote
Old 03-26-2010, 07:27 AM   #201
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,257
Thanks again.
Unless you specifically ordered an A/C horn (They're somewhat rare) your horn isn't going to work on the XRs A/C system. 99.9 % of the horns being sold are a DC horn.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-26-2010, 09:53 PM   #202
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
I've made several of the sockets with the welding rod brackets but I do like to use the LED version of an 1157 bulb in them. The vibration back there is hell on regular bulbs.
Old 03-27-2010, 02:08 AM   #203
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,327
Yes, that's what I do on my XR400 - like you say, regular bulbs don't seem to last that long...
J x
Old 04-04-2010, 08:54 AM   #204
Light Rider
Oddometer: 51
Nice guys... thanks. Great info!
'13 500 xc-w Plated
01 XR400R - Plated
Old 04-05-2010, 01:55 PM   #205
mattc
mattc's Avatar
Oddometer: 443
Originally Posted by mattc
I'm setting up my XR with a simple DC system, just so I can use my GPS.
Stock stator
DC reg/rect
Capacitor
What, if anything will I have to do to keep the capacitor from draining my GPS's internal battery?
TIA
Ok, I broke down and decided to put together a big DC system. But, I need help!
I got the RS 200w stator, the regulator/rectifier to go with it, and a small 1.5Ah battery. I'm ready to put it on, but it seems like I'm missing something. A switch to keep the battery from draining? Where? What kind?
It seems I heard of a wiring diagram for a similar setup?
Please give me some guidance!
mattc is offline   Reply With Quote
Old 04-05-2010, 08:33 PM   #206
mattc
mattc's Avatar
Oddometer: 443
Ok, Scratch that. I wired it up as 100w AC and 100w DC, as shown in the RickyStator instructions. Only have my GPS on the DC side, with no switch. Anyone see any problems with that??
Old 04-05-2010, 10:08 PM   #207
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
It should be fine, constant power to the gps is the way to go. If you're not going to ride the bike for an extended period be sure to unplug the gps or it will drain the battery.
Old 04-05-2010, 10:14 PM   #208
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
I get a lot of requests for schematics and I know I've forgoten to send them to some of you. So if I forgot to send them to you or you'd like to request a copy PM me your email address and I'll shoot them off to you.
Old 04-18-2010, 04:09 PM   #209
trackhead
Utard Wankster
trackhead's Avatar
Oddometer: 2,754
So I just put this stator in my XR650R. It's all plug and play, and then you have two 100w outputs left to use as you wish. I have one 100w output (single lead, no ground) going to an AC regulator and a 100w halogen that is working great. The other 100w output (single lead, no ground) I would like to run through this regulator/rectifier to the small dual sport battery I have running the blinkers/horn/etc.
My question is, the input for the regulator/rectifier has two yellow wires. Do I run one yellow to ground/frame, the other to the single lead output on the stator, then red to + black to - on the battery?
Thanks.
Utah Moto Ride Reports
trackhead is offline   Reply With Quote
Old 04-18-2010, 04:43 PM   #210
Countdown
Oddometer: 5,793
Thanks.
Yes but the DC system must float from the frame.
Jerry Counts
Countdown is offline   Reply With Quote
Times are GMT -7.   It's 10:53 PM.
