Old 07-05-2010, 03:46 PM   #316
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
A standard reg/rect is rated at about 150w and the easiest way to wire it into your stock harness is with a dual sport kit. If you don't want to go that route you'll have to make your own harness that connects to your stator. Not a small job and more than I can explain with just words here.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 07-05-2010, 03:48 PM   #317
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Thumb
DeathDealer, nice job! Sano installation.
Old 07-06-2010, 04:40 AM   #318
REDRIDERS
RIDE RED
Oddometer: 9
Thanks for the help so far I have an Australian spec 650R so it comes with a duelsport kit .Blinkers horn and switches bright dim etc .
REDRIDERS is offline   Reply With Quote
Old 07-13-2010, 11:33 PM   #319
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I killed my capacitor. I had everything wired up with all my positives on the postive pole of the cap and all my negatives on the negative pole of the cap. I had been meaning to change the negative wiring but I got excited/lazy and just wanted to ride! Apparently something made it fail, I don't know if the negative wiring caused it but its my guess. I got a new slightly higher voltage(20v, 18000mf) cap, and wired that in with my grounds on the frame and the blue wire on the negative of my cap.
So far so good, we will see if I get more than a couple weeks out of this second cap.(Although granted with all my "tests" and mistakes I may have shortened the first capacitor's life)
I'll go to a battery if I have to, but at 6 bucks a cap I can afford to experiment a little.
Thanks again for all your help. I really learned a lot. It only took 30 minutes to diagnose and repair it this time(I found my multimeter so that helped). I love riding this thing around at night and being able to see where I'm going!
lstzephyr is offline   Reply With Quote
Old 07-14-2010, 01:48 PM   #320
arrcrussell
Gimme Dirt
arrcrussell's Avatar
Oddometer: 604
Of all the people I know that have tried to re-wind their own stator not one of them stood the test of time.
Mine is going on its 4th year with no problem. However, you don't know me so I guess your statement still holds.
All kidding aside, mine is on its 4th year. No battey, running an all AC circuit with twin 100 watt RickyStator lights and his regulator. I'sd say I put 3,000-5000 miles a year. The Xr650 is a effin' hoot on fire roads.
arrcrussell is offline   Reply With Quote
Old 07-19-2010, 09:34 PM   #321
chevsuz12
chevsuz12's Avatar
Oddometer: 187
Pissed Electrical Problems
My bike is an 2000 Xrr with BD kit, I rewound the stator myself, and was running a 50w bulb, LED everything else, with Acewell Computer. The headlight is rarely used except at night, I run a white LED strip light for DRL in the daytime.
I recently had my local Batteries Plus build a battery pack to replace the aging Baja Designs one that would no longer take a charge.
The bike worked great for about a month, then I started noticing the computer would work erratically, and the turn signals would stop flashing. I pulled the seat and found the new battery pack had melted!
I did not blow the fuse, and I removed the battery. If I run without the battery the Acewell computer still works very erratically.
I am not sure what would have caused the battery pack to fail. Would it be better to use a lead acid battery, or a capacitor instead of the nicd pack? Not sure what to do at this point.
Any help is appreciated!
chevsuz12 is offline   Reply With Quote
Old 07-20-2010, 12:21 AM   #322
af300e
Oddometer: 283
Check the charge voltage with engine running. Much more than 14v will cook batteries. If it's too high the rec/reg is rogered.
af300e is offline   Reply With Quote
Old 07-20-2010, 05:40 AM   #323
chevsuz12
chevsuz12's Avatar
Oddometer: 187
Without a battery connected I am getting:
@ idle............ @7000rpm
11.8v .............8.5v .............Red wire
5.8v............... 5.8v............ 1st yellow wire
4.8v............... 2.4v ............2nd yellow wire
Old 07-28-2010, 09:44 PM   #324
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Hmm, that just seems wonky. The voltage on the red wire should rise slightly for a couple rpm then stabilize. Try testing it again, but keep the yellow wires plugged in and check across red/black on your rectifier.
The yellow wires should be hooked to your chassis stator wires. They should be pretty high voltage(a/c)
Edit:if you weren't running your headlight during the day its likely that you over charged the battery and fried either the battery or the regulator. The regulator should be fine but if the voltage is too high without having a load(headlight) it can fry it. What kind of regulator do you have? On the trailtech there is a voltage limiter for small batteries. I'm not sure if the BD is the same but it may be something to check for.
Old 07-28-2010, 10:03 PM   #325
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,184
Originally Posted by chevsuz12
....Batteries Plus....
There's your problem.
Sounds about right to me for no battery. If your regulator packs in it'll kill your battery too, but then without a battery you'd get higher voltage rather than lower.
Luke is offline   Reply With Quote
Old 07-29-2010, 07:21 AM   #326
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
The DC (red) is low, it should stabilize at 13.5~14.5 VDC at anything above 2200 RPM and the most accurate check for DC is going to be with your battery in, VR/Rect can get flakey in a few different ways when connected to a load.
You're checking the A/C (yellow leads) incorrectly, ac needs to be checked across the 2 yellow leads, and it should be a considerably higher reading then what you're showing even with the AC regulator in the system.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 08-07-2010, 09:29 AM   #327
brp2004
Orygun
brp2004's Avatar
Oddometer: 200
Wiring diagram for baja designs quick release kit
I need a wiring diagram for baja designs quick release kit. Anyone have a link?
brp2004 is offline   Reply With Quote
Old 08-07-2010, 02:18 PM   #328
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,364
Go to B/D web site, they have pdf's on all the stuff they sell.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 08-07-2010, 09:58 PM   #329
chevsuz12
chevsuz12's Avatar
Oddometer: 187
Problem Solved!
I returned the melted battery pack to batteries plus, and they gave me an even exchange on a lead acid battery that is 12v, 1400ah. It just barely fits under the seat, but works great.
All voltages are good now. All electrical issues are gone!
Lets hope it lasts.
Old 08-08-2010, 07:39 AM   #330
brp2004
Orygun
brp2004's Avatar
Oddometer: 200
Thanks for the help, but I'm looking for the quick release schematic, they only have the standard schematic on their site, I guess I will have to contact them directly on Monday. I was hoping someone had one saved somewhere.
Times are GMT -7.   It's 05:24 PM.
