Old 04-07-2012, 11:28 PM   #796
Erndog
dirt relocation service
Erndog's Avatar
Oddometer: 111
XR progress
http://www.xr650rforum.com/t1416-baj...stator-install
Instead of burying the info here I thought I'd start a fresh (short) thread with plenty of pics. Enjoy..... :)
Erndog is offline   Reply With Quote
Old 04-08-2012, 12:59 AM   #797
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,978
I think you guys are worrying over nothing, good discussion but I doubt it's applicable in this situation. Typically heat is generated by high current flow, that being the case, the 250W stator under full load (everything running) is going to be the biggest heat generator. My system when run unloaded has never caused any issue and I've done it all day long, basically 200W going nowhere. I've also ridden with the battery unhooked with no issues. BD systems and many Baja racers run WFO all day with zero or almost zero load on their stators, at night they mount up lights in the pits, plug 'em up and finish the race. Automotive systems that put out much more wattage than ours have run under very small loads during daytime running for years. Motorcycles used to have off on switches on the lights, when turned off they were basically running unloaded. I just don't see it as being an issue in our case.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 04-08-2012, 02:01 AM   #798
oldxr
oldxr's Avatar
Oddometer: 1,121
My xrr has the ricky stator 100x2 stator and I only use 1 leg.but my current draw is very low.The only standard bulbs are the front turn signals and they are 3 watt bulbs.the rest of the bike has all led's including the head light.the head light draw is about 1.5 amps.I have a 4" spal fan on the rh radiator and I have no problems running all the lights and fan together.I have that cheasy baja designs nicad and i am thinking about 1 of the new lithium batteries for an upgrade .It would be nice to use the headlight for 1/2 hour or so with the motor off.If i was was going to run a heated vest I would try to run it on the other leg of the stator with the oem honda a/c voltage regulator.rough math calculations give 100 watts= 8.3 amps.My headlight will run about 3 minutes with the engine off
oldxr is offline   Reply With Quote
Old 04-08-2012, 02:15 AM   #799
Gildus
Gildus's Avatar
Oddometer: 206
I agree. Heat hasn't proven to be a reason to avoid a full power stator. Seems to me it's only a good thing to have power available when needed, especially for a bike as versatile as the XRR.
Gildus screwed with this post 04-08-2012 at 02:26 AM
Gildus is offline   Reply With Quote
Old 04-08-2012, 10:18 AM   #800
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
Stator install
Nice thread you have, and thanks for sharing it. Looking forward to seeing your progress.
So, in going "all DC" what does this involve?
What is the battery you are running (cant make out the specs in the pics)
Did you consider one of the new Shorai batteries?
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 04-08-2012, 10:41 AM   #801
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Very helpful insights, thanks. Only thing I'll point out is a car alternator is in open air, allowing for far easier cooling. but it sounds like as long as the wire is not too small, it is not a problem. Thanks again.
"Get the hell out of my way." - John Galt
'78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
XRx is offline   Reply With Quote
Old 04-08-2012, 12:10 PM   #802
crypto666
Oddometer: 1,231
If you are worried about heat from a 200w stator, don't.
A good rule of thumb for motors (or alternators/generator) is 3w per gram of weight. So we have 200w and the stator weighs how much? Yeh, I wouldn't worry about it.
crypto666 is offline   Reply With Quote
Old 04-08-2012, 01:14 PM   #803
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Good writeup. I've never removed my shifter to remove the cover though, I just click it down out of the way as if shifting into first, then it's out of the way, well on my bike anyway.
Old 04-08-2012, 04:18 PM   #804
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,978
No problem XRX but gotta I disagree with ya on the alternators. Temps inside a car's motor compartment get pretty high, esp with an alternators proximity to the exhaust manifold. The majority of automotive alternator failures are caused by caused by cheap mass produced componets (usally the diodes) that breakdown over time due to heat, not by exceeding their electrical specifications. Both BD and RS stators are good quality and rarely suffer from problems with the windings. The home wound stators are a different story, some guys do a great job with zero issues, some don't.
If you read this entire thread you'll discover most of our failures are caused by crappy wiring harnesses, bad batteries, faulty DS designs or overloaded regulators in the case of the BD units. I'm not familiar with the Electrosports stuff but the RS or BD stator in a dual configuration is about as reliable as as you're going to get for a do all DS setup. IMO, time is best spent doing a good job on the wiring where most of the problems seem to come from. Quality connectors, proper guaged wire and good wire managment are the key to avoiding the majority of problems discussed here.
Chris
Old 04-08-2012, 09:39 PM   #805
DocAxeYarYar
RideDualSport.com
Oddometer: 784
wiring
RideFreak
"IMO, time is best spent doing a good job on the wiring where most of the problems seem to come from. Quality connectors, proper guaged wire and good wire managment are the key to avoiding the majority of problems discussed here."
Great advice! I can see how rushing the job could lead to some poor wiring and/or bad connections. Thx!
My XR650R Build:
Old 04-08-2012, 11:03 PM   #806
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,978
Originally Posted by Buell78753 View Post
RideFreak
Thx, don't forget a well thought out plan also, it took me 2x to get the system how I wanted it.
Chris
Old 04-09-2012, 01:06 AM   #807
Gildus
Gildus's Avatar
Oddometer: 206
RideFreak
Yeah, exactly, not rushing the job is the challenge. In my case, I didn't take enough time planning the wire management. Now I'm having to redo part of my harness.
Old 04-09-2012, 06:33 AM   #808
DOD
idiot dirt rider
DOD's Avatar
Oddometer: 2,330
What did you do with the other leg? Leave it open?
I'm rewiring a new to me XR and it came with a 200W Ricky Stator and until I upgrade the lights I only need about 60W.
Thanks,
dod
This is my only chance to assemble a disreputable past
DOD is offline   Reply With Quote
Old 04-09-2012, 12:15 PM   #809
Kevlar49
Oddometer: 12
Wanted to share some of the leg-work I've done in converting my XR-R to DC-only. I completely rewired my bike very similar to this when I went to make it street-legal, but I'm doing a major engine rebuild, and adding a hi-low HID kit while I'm at it, so I'm cleaning up and redoing the wiring harness again (just for fun?).
I rewound the stator myself with a single output (in addition to the stock ignition output). Should be ~200 W. Running that through a Tympanium regulator/rectifier, with a quad-cell A123 lithium ion battery (primarily for the headlight). Hope this is helpful to others!
Ohhh yeah MS Paint...
Kevlar49 screwed with this post 04-09-2012 at 12:35 PM Reason: Updated drawing
Kevlar49 is offline   Reply With Quote
Old 04-09-2012, 01:25 PM   #810
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,978
Kevlar, nice job esp for MS Paint.
Only issue I see is it looks like the battery is on all the time
Procycle sells a dual circuit key switch that's pretty nice, grounds the kill wire in the off pos and opens the battery circuit, no more secure then the hidden kill but it performs both functions. For an HID application I'd probably use the key circuit it to fire a mini relay since I'm not sure what it's rated at and the HIDs initial surge current is up there.
Do you have a link to that VR/Reg? I got a rewire job going on right now (non XR) and it's a 300W that I want to run all DC.
Chris
Times are GMT -7.   It's 09:58 AM.
